Before I get told to search... I did a fair amount of research and couldn't come up with a clear cut answer. I have a 99' Coupe with OE suspension, for the time being I would like to get some spacers to push the Roadstars out flush to the fenders.
I believe I need a 20mm rear and a 12 mm front? Before I pull the trigger can someone verify? Possibly post photos of before/after with the correct setup.
Thanks in advance.
-Kyle
2005 ZCP Schwarz II/Imolarot 6spd ///M3 || 1999 ///M Coupe Estorilblau/Estorilblau "Clownshoe"
2014 Alpinweiss Uni/Mokka X5 ///M Package (wifey)
WWW.CHICANEMOTORSPORT.COM
It can vary, what works for me may not work the same for you. Best bet is to go out and actually measure it
PRICE CUT on ALL FABRICS
I run 18 in the rear and 5 in the front and it looks pretty good. I never measured for the roadstars, I just transferred them from my Work wheels and it worked out. There is probably a little room to go further as you state. I never really took a pic to show spacing but this is the only pic I have with this set up.
1999 M Coupe Boston Green, Beige, H&R/Bilsteins, Underdrive Pulleys, Euro 6 speed, UUC SSK and Randy Forbes in the back
2002 2.5 Z3 roadster Oxford Green, auto, all stock
2013 Ram 3500 Crew Cab Dually 385 HP, 850 ft lbs torque at 1600 rpm, all stock and staying that way
2004 Mini Cooper Chili Red, daily driver, modified almost daily
I'll get ya better pictures when it's not raining
FWIW I ran 15 rear / 12.5 front then later 17.5 rear / 15 fronts and they both looked good. The 15 in the front rubbed a bit for me though on a lowered suspension without camber adjustments.
Nice... Thanks guys. I just ordered 12mm Front/20mm Rear. I will post before/after photos once I get them installed.
-Kyle
Which brand(s) did you go with? Something from the list?
Went with Motorsport Hardware for 82mm studs & spacers front/rear.
This can vary and it depends on Tire size plus how personal preference. Some people like the tire to poke out more than others but here goes.
Front: 5 - 12.5mm
Rear 12.5 - 20mm
Anything in those ranges can work. Also, some don't even bother with spacers in the front since the rear is what looks worst without the spacers.
