Page 1 of 7 1234567 LastLast
Results 1 to 25 of 162
Thread: FMZIP's Fat Daddio Electric Fan DIY
    New England
    2019 M850i - 2016 228i
    I took the best information from all the threads and began tackling the fan clutch removal and installation of an electric fan in my 530.
    I would like to thank particularly forum members 16Valex for his write up & johnstern .
    JimLev's endless contributions and the way he mounted his electric fan lead to the discovery of the Fat Daddio, the key to a super easy electric fan install!
    So here are the key components needed for this DIY
    Fat Daddio Aluminum Cake Pan 18" x 2 " $23.99 from Amazon. This shroud opening is exactly 18 inches, this pan fits the shroud absolutely perfectly!
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    Summit Racing Fan PN SUM-G4904 $86.97- I followed 16Valex's recommendation on this because it's a curved fan which lowers the noise level.
    http://www.summitracing.com/parts/sum-g4904
    Derale 16749 Fan Control 16749 $46.97- Kudo again to 16Valex. This controller is ideal for its adjustable temperature setting.
    http://www.summitracing.com/parts/der-16749
    Autometer 2283 Radiator Hose Adapter $46.97 - This is the adapter of choice as everyone seems to use it. It offers the ability to maintain the factory lower hose which is ideal. Seems a bit cheaply made to me but it should serve the purpose find.
    http://www.summitracing.com/parts/atm-2283
    BMW Fan Shroud- I already have a new one in my car but decided to buy another to play with. It's not necessary but depending how old yours is and how fragile it is, you may want to replace it for $50
    http://www.eeuroparts.com/Parts/2975...d-17101438457/
    Here's 16 Valex's photos of where to cut the lower radiator hose to install the ATM-2283. Make sure you use teflon tape on threads or a loctite product specific to this application. I used Loctite 565
    After receiving the Fat Daddio cake pan, I checked for fitment, absolutely perfect. This pan is solid as well, nice and thick and lightweight!
    Next I traced a circle just larger than the pan. It should be 15 3/8 round if you desire to draw a perfect circle.
    Next either cut the lip off the pan first or the center. I used a jig saw for both. Cut slowly with a fine tooth metal blade It's a bit awkward to cut the lip off and hold the pan at the same time so be careful
    If I were to do it over again, I'd cut the lip first and the center second. Here's a pic of the center cut out. Remove the lip off the pan next
    Next, I cut just the plastic top vent holes from the shroud just because I wanted a cleaner look with the aluminum being consistent all around. It's not really necessary
    Test fit into shroud looks perfect, stainless steel 1/4 20 hardware and loctite used on the nuts.
    You will need to grind off a bit of the plastic off the fan in order for it fit in the pan. Here is a photo showing a test fit before I cut the lip of the Fat Daddio
    I used this connector from NAPA for a quick disconnect in case I ever needed to remove the shroud
    Here's the finished product. Make sure your fan blade orientation looks like the picture below, if not take off clip and turn the blade over. Black wire is negative, blue wire is power. Remember, the air blows towards the engine
    Make sure you don't mount the fan too far back. You don't want it resting against the radiator. Check side view for clearance
    If you want another 1/4 inch of added clearance, remove the fan blade, then remove the three torx screws. As you can see, there are three spare hole.Rotate the fan
    and reinstall screws into the other three holes. Pic below courtesy of 16Valex
    You can simply follow the Derale's instructions to wire this into the car. Thanks to 16Valex for the electrical hookup suggestions:
    http://www.bimmerfest.com/forums/sho...36&postcount=7
    For 12V constant, I will likely go straight to the positive post on top of the engine for safety
    You will need to unlock the ODB in your BMW to set the temp. I plan to follow 16Valex's advice and set it to come on at 95C.
    I used this video and you are accessing feature number 7. If you can't access #7, access #19 first first. Watch both video's it's self explanatory
    https://www.youtube.com/watch?v=UlIi89xN_IE
    If your instrument cluster has two reset buttons, the procedure is similar
    https://www.youtube.com/watch?v=cO_tBe58ew8
    If you'd like more features, read on.....
    If you'd like to have the fan run at approximately 20% at all times you will need the following items. Otherwise the fan will only kick on when it hits the specified temp you dictate
    www.digikey.com
    Thanks johnstern for the PN's * below
    1 relay 255-1828-ND *
    2 resistors 10ohm 50watt KAL50FB10R0-ND * these resistors will get hot and need to be heatsinked to metal.
    1 thermal grease part for underneath above resitors 345-1006-ND *
    1 1Amp switch of your choice
    Using JimLev's schematic below, you can tie in all the above parts with the Derale controller. Note Jim's schematic shows one resistor but there are two tied in parallel. See john stern's photo below.
    The switch in the schematic will let you bypass this feature in winter months etc.The setup below was my first attempt at mounting parts, not acceptable. Disregard the second switch in the photo that is for the next feature....
    JimLev also came up with the idea to let the fan fun for an additional 2 minutes after killing the ignition to allow engine/plastic parts to cool. I loved this idea as it should
    help prolong the life of all the plastic parts under our hoods!
    An electrical engineer friend of mine discovered a perfect Time delay relay and came up with the ciruitry to tie it into JimLev's above schematic. Here it is:
    1 Time delay Relay TDR-PMF
    http://www.wolstentech.com/products/...delayrelay.php
    2 Diodes 2 1N5400-ND Digikey
    1 1 Amp Switch
    Here's the schematic:
    That's all for now. It takes a week to get the Wolsten Relay and I am waiting for a nice anodized box to mount all the electronics. I may install everything but the added electronics this weekend if I have some time.
    Nov 2010
    Charlotte, NC
    03 M5/05 RR/06 Cayman S
    Nice! Are you going to paint the aluminum cake pan shroud? I would think if it was flat black with black hardware, it would look close to factory.
    -Paul
    2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers,
    Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread
    2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    That mount is genious. New standard may have set here. Nice work.
    A cake pan... awesome
    SoCal
    F10 N52
    Awesome thread! Leave it to Jim to come up with an ingenious way to do things.
    Sep 2010
    Ooltewah, TN
    2010 BMW M6*2019 X3 M40i
    Very nice and professional look. The reason I was successful in my conversions is because of JimLev and many others here to contribute.
    2010 BMW M6 SMG Coupe * Black Saphire Metallic * Full Leather Merino Black
    2019 BMW X3 M40i * Alpine White * Mocha Leather
    Former:
    1997 BMW 532M (528i with 3.2 S52 engine from E36 M3 / 5 speed manual)
    1998 BMW 540i 6 Speed
    2003 BMW M5
    CA
    2003 530iA (SOLD)
    Very clean job with that cake pan!
    2003 DINAN 5 | M54B30 | Titanium Gray Metallic | Stage 3 Engine Software | High Flow Throttle Body | Cold Air Intake | Free Flow Exhaust | Performance Automatic Transmission Software | Front Strut Brace | OE 18x9 BBS RS745 Style 42 on 265/35-18 MY BUILD THREAD: [Click]
    New England
    It was a piece of cake.... Lol
    New England
    Quote Originally Posted by blackknight530i View Post
    No, I like the aluminum contrast. Spray paint never cuts it for me.
    Jun 2013
    Stockton CA
    '12 Maxima '02 540i
    wow, that is simply ingenious... MASTA-BAKER!! lol, This will also be on my list to do!
    Jul 2006
    GA, NY
    2001 530i 5spd/2001 M5
    So legit. I've been doing all your mods. lol. This is next on the list!
    SoCal
    F10 N52
    Regarding the radiator hose adapter:
    Does anyone know if it will also work for the V8 cooling hoses? I believe they are the same size as the I6, correct?
    Do you know what is the size thread opening of the female brass adapter on top of the radiator hose adapter?
    Any details on how you placed that wire in there? What is that black stuff?
    Thank.
    New England
    Quote Originally Posted by GreenTiger View Post
    Thank.
    This guy used the 2283 on his 540 and 528. I almost went with the Spal fan he mentioned but the current draw concerns me:
    http://forums.bimmerforums.com/forum...on-97-BMW-528i
    The thread size is 3/8. The black wires are attached to the one piece brass sensor from the Derale 16749 kit. This sensor is then threaded into the Autometer 2283 aluminum piece. The 3/8 brass piece as pictured below that comes the 2283 is not used.
    Quote Originally Posted by carlova789 View Post
    It's my duty to keep you young-guns busy modding
    Quote Originally Posted by bighman209 View Post
    LOL....masta-baker!
    Just call me Chef-zip
    Quote Originally Posted by philly98540 View Post
    Thank you for the kind words.
    I was pretty stoked with it myself. I couldn't have found a more perfect aluminum piece to work with.
    Queens, NY
    destiny
    That cake pan looks quite sharp. I have a 14" fan from my s4, I may try to adapt it
    Current
    2008 E70 4.8 BSM/Black - 100% Options2007 335i SG/Coral Red - 6MT - Ets, Spec, BMS, VRSF, Broadway Static
    2004 325i AW/Black
    Past
    2000 M5 Silverstone/Silverstone - ST Coilovers
    1998 E36 M3 - Tiag, Bride Gias, RK Tunes, M50, AA Track Pipe..
    Aug 2013
    Sydney
    01 E39 530i,05 E53 4.8IS
    Looking good!
    01 E39 530i - SOLD !
    05 E53 4.8is
    Pics of Bianca (E39) and Betsy (E53)
    Jan 2013
    Northeastern MA
    2003 BMW 540i ///MSport
    Gonna start to buy these parts soon. Even if they don't go on my current car I can hold on to them.
    2003 540iA///MSport
    Mods:
    ///M5 Automatic Folding Mirrors,
    ///M5 Rear view Mirror(Thanks to LaLaRay),
    ///M-Tech 1 Dual stage steering wheel (Thanks to tmvE39E53Z32TT),
    Old Style "Wolf Whistle" Alarm Siren,
    E38 18-Way Contour Seats (Thanks to GSXRliterbikz),
    E53 x5 4.6 Sport Cluster (Thanks to GSXRliterbikz),
    E38 center armrest with iPhone 4 craddle (Thanks to GSXRliterbikz),
    Slotted & Drilled Rotors with Stainless Steel Brake Lines,
    19" M Parallel wheels
    (Thanks to DennisCooper)
    Brushed Titanium Trim Vynil Wrap
    Dec 2003
    houston
    540i/6
    bookmarked
    Nick
    2003 540i/6
    Intro/clean-up thread
    New England
    Quote Originally Posted by MarlberCruz View Post
    Better get your fat daddio before there's a shortage in supply!
    Jan 2013
    Northeastern MA
    ^Ha! No Kidding!
    2003 540iA///MSport
    Mods:
    CA
    2003 530iA (SOLD)
    Well, I just bought a $33 cake pan just in case I ever want to do this, LOL!!
    Mar 2012
    Lansdale, Pa
    Cake pan global shortage!
    New England
    Quote Originally Posted by Aryana View Post
    It's a bimmerforum bake sale.
    Let's get baked!
    Got a few goodies in the mail today.
    New aluminum housing from Amazon to mount all the electronics on/in:
    , snagged up a few black anodized heatsinks for the resistors from work today.
    And the Wolsten time delay relay showed up, super fast delivery
    CA
    2003 530iA (SOLD)
    Looking forward to seeing it all in your engine bay.
    New England
    Got my parts installed on the new box.
    Planning to do the install tomorrow
    Minneapolis,MN
    2003 M5, 2014 535i
    Tidy work as always.
    2003 M5 LSx l 6 Spd Manual l 4.10 LSD
    Build Thread
    The chassis must always be regarded as a means to an end and never as an end itself
    In the wood
    02-530 stick Blown
    Good to hear! Nice work BTW!
