The Mother's headlight restoration kit was on sale at Autozone for $10, so I picked one up.
I was skeptical that it would work, but so far, so good.
The kit included some rubbing-compound-like liquid and an attachment for your drill.
before:
headlight lens before by ChurchOfBK, on Flickr
after:
Headlight lens after by ChurchOfBK, on Flickr
It's only been a week, so who knows how it will last, but initial results are good.
Just FYI.
Impressive! I usually use 1K grit wet-sand, buffing compound, and then Royal Blue (or any other good quality polish). But for $10, you can't beat that. The drill attachment alone is worth that. Looks like I'm headed to AutoZone tomorrow, and hope it's still on sale.
Nice work! I used the 3M kit with similar results - it's amazing how much it freshens up the front of the car.
I wonder what causes the plastic to become cloudy. Abrasive scrubbing, cleaning with the wrong chemical, hot sun, ozone? My car was built in 10/96 and its plastic is clear as new.
BMW MOA 696, BMW CCA 1405
Very nice job. It made a significant difference.
I bought the 3M kit, very inexpensive and quite effective. I'll never trust the kits that just provide like a wax coating or something that needs re-application.... I used the 3M resto kit but then went over it with clear coat
It's a Hybrid--Burns Gas and Rubber
This is on the money, the poly-carbonate is covered in a sealer that eventually wears out and becomes oxidized. I personally like a few products: the 3m kit that comes with the drill attachments are a great professional substitute, Crystal View is a nice professional kit, and Meguires plastx is great for removing oxidation.
Jordan
To update the thread, as I had feared, this was a temporary solution. The lights have a heavy haze again.
It should be noted that my car is parked outside almost all the time. Ahh the joys of a one-car garage and no way to permit an extension. :p
Maybe hit them again with another kit and throw some lamin-x on?
I did this with my second hand OEM M5 headlights I bought off a friend for $200 and they look very nice. I've been hesitant to do my m coupe headlights because they look relatively good at the moment.
http://www.lamin-x.com/BMW-Z3-1996-to-2003-s/817.htm
You need some sort of UV protection coat. Lamin x should work. Some people mix urethane and mineral spirits and paint it on. I think there was a thread recently posted about special headlights clearcoat.
Applying a urethane is the way to go. And that is, after some serious elbow grease (sanding). Mine are holding up very well after about a year with an occasional plexus application.
Here's a thread I posted with the results: LINK
If you keep the lights coated with sealant/wax, they also seem to cloud up much more slowly.
This applies with acrylic sealants, at least. Carnauba might not turn out as well.
I suggest you do the same process again, but this time invest in some Lamin-X, it'll keep your lights looking like new for a really long time.
My lights on the Z4 are EXTREMELY yellow. I've had them done a few times but I was told that much of the haze went through to the inside and that nothing can be done now :/
