In the process of replacing my RTABs, but I think the I might have the bushings oriented the wrong direction. Because of that, I'm having trouble to aligning the trailing arms with the carrier.
One side/lip of each of the rear trailing arm bushings is thicker than the other.
I believe the orientation should be: (same for left and right)
Inner Bushing: Thick side faces in toward diff
Outer Bushing: Thick side faces out toward wheel
Can anyone verify this?
Any suggestions on aligning the trailing arm with the carrier?
Thick sides are outermost for each trailing arm.
Finally found a few more pictures like those online. Surprised it really hasn't been brought up more.
Thanks for the validation as always.
To bring this thread back from the dead. What is the preferences on RTABs for our cars?
2005 ZCP Schwarz II/Imolarot 6spd ///M3 || 1999 ///M Coupe Estorilblau/Estorilblau "Clownshoe"
2014 Alpinweiss Uni/Mokka X5 ///M Package (wifey)
WWW.CHICANEMOTORSPORT.COM
I used the OEM style made by Lemforder. Almost a month now. So far no issues. For RSFB, i used the power flex bushing.
see picture below with new bushings..
Old RTAB's were in good shape (as far as i can tell). 14 years old and so changed it.
