Results 1 to 23 of 23
Thread: :: ECS Tuning :: ECS Teflon Shifter Bushings and Shifter Rebuild Kits
    Wadsworth, Ohio
    BMW
    No matter how smooth your 3 Series runs or how tight your suspension setup is, loose and vague shift action destroys all the confidence you have in your driving. The rebuild kits available at ECS include everything you need to rebuild your shifter assembly, from the bushings and clips to the dowel pin. To improve your shift feel from factory, you may also choose to replace the soft factory rubber with virgin Teflon rod, an advanced formula that contains no fillers or impurities, resulting in a long lasting and extremely precise feel.
    E82/E88 128i
    Click HERE for your E82 128i ECS Teflon Shifter Bushing Kit
    Click HERE for your E82 128i Non M ECS Shifter Rebuild Kit
    -featuring ECS Teflon Bushings-
    Click HERE for your E82 182i genuine BMW Shifter Rebuild Kit
    E36 M3
    Click HERE for your E36 M3 ECS Teflon Shifter Bushing Kit
    Click HERE for your E36 M3 ECS Shifter Rebuild Kit
    Click HERE for your E36 M3 genuine BMW Shifter Rebuild Kit
    E46 M3
    Click HERE for your E46 M3 ECS Teflon Shifter Bushing Kit
    Click HERE for your E46 M3 ECS Shifter Rebuild Kit
    Click HERE for your E46 M3 genuine BMW Shifter Rebuild Kit
    E46 Non M
    Click HERE for your E46 Non M ECS Teflon Shifter Bushing Kit
    Click HERE for your E46 Non M ECS Shifter Rebuild Kit
    Click HERE for your E46 Non M genuine BMW Shifter Rebuild Kit
    E9X 325/328/330
    Click HERE for your E9X 325/328/330 ECS Teflon Shifter Bushing Kit
    Click HERE for your E9X 325/328/330 Non M ECS Shifter Rebuild Kit
    Click HERE for your E9X 325/328/330 genuine BMW Shifter Rebuild Kit
    Wadsworth, Ohio
    BMW
    Wadsworth, Ohio
    BMW
    Wadsworth, Ohio
    BMW
    Wadsworth, Ohio
    BMW
    Wadsworth, Ohio
    BMW
    Wadsworth, Ohio
    BMW
    Wadsworth, Ohio
    BMW
    Wadsworth, Ohio
    BMW
    Wadsworth, Ohio
    BMW
    Wadsworth, Ohio
    BMW
    Wadsworth, Ohio
    BMW
    Wadsworth, Ohio
    BMW
    Wadsworth, Ohio
    BMW
    Wadsworth, Ohio
    BMW
    Need the perfect knob to know with your new crispy shifter?
    Click HERE for BMW ZHP And Performance Shift Knobs
    Wadsworth, Ohio
    BMW
    Wadsworth, Ohio
    BMW
    Wadsworth, Ohio
    BMW
    Wadsworth, Ohio
    BMW
    Wadsworth, Ohio
    BMW
    Click HERE for your BME E36 328i/is Shifter Rebuild and Upgrade Kits
    If you haven't already refreshed the stock shift assembly, then you are most likely experiencing sloppy and muted shifts. Revive the precise feel of your E36 328 with our Shifter Rebuild Kits.
    Wadsworth, Ohio
    BMW
    Wadsworth, Ohio
    BMW
    Wadsworth, Ohio
    BMW
