Results 1 to 25 of 58
Thread: SHouldn't both rear wheels spin when an LSD is installed...?
    Feb 2012
    Northern Virginia
    1995 BMW 540 M-Sport
    Guys,
    Am I missing something (like a working LSD)?
    1995 540 M-Sport Cosmos Schwarz on Parchment w/ (Open) 3.15 LSD - http://forums.bimmerforums.com/forum....php?t=1805972
    Current Status : I SOLD HATE MEH... LOVE my car.
    Jan 2003
    Bay Area, Ca.
    94 M5T
    stock is only 25% lock up, so not necessarily all of the time. but looking at the video, i'd expect you to get some motivation from the right rear. Probably worn out.
    Mike
    93 M5 3.8 Sterling Silver/Black (euro)
    94 M5 Touring Madeiraschwarz/Black
    80 745i (project)
    83 735i / 5 speed (euro)
    86 735i / 5 speed (US)
    86 745i (project)
    Apr 2008
    CA
    E34 M5
    fried clutch pack
    Massachusetts
    1987 BMW 535is
    Have you had both rear wheels off the ground and rotated one wheel with the e brake off in neutral?
    If both wheels rotate the same direction you have a limited slip differential.
    If the wheels rotate opposite of one another you have a open differential.
    If you don't know what I am talking about ask whoever installed the "3.15"
    Feb 2012
    Northern Virginia
    Sorry. I should have given some backstory... My brother and I installed the diff and it had the coveted "S" on it...
    The donor car never ran so it wasn't pre-tested. Would a "fried clutch pack" essentially turn an LSD into an open diff? Any way to check w/out taking everything out?
    Jul 2012
    MA
    ///M5
    Yes, yes they should.
    Current
    2005 E55 AMG
    1998 Silverado K1500
    1964 Impala
    ​1964 Chevelle 496ci
    Past
    2000 Avus M5
    1988 Suburban K1500
    1987 Suburban K2500
    2007 Suburban
    1999 K2500 Suburban
    2000 MGM
    1999 K2500 Suburban
    2001 Stratus 740i Msport
    1990 750iL
    1995 540i/6
    1996 MGM
    Dec 2004
    CT, USA
    e28, e34, e39
    Quote Originally Posted by shaytanabyad View Post
    Would a "fried clutch pack" essentially turn an LSD into an open diff? Any way to check w/out tacking everything out?
    Have someone slowly turn a wheel in one direction. If you can freely turn the other wheel in the other direction without any resistance the clutch is gone. On a bad diff, I could easily turn the output flanges in opposite directions by hand. On a good diff, I could not. There are write-ups on changing the clutches. It doesn't look too complicated.
    demet
    Mar 2011
    Neverland
    E34 525i
    Seems like fried clutches from the whine.
    Also lol at 'stupidest thing ive done'
    Butte, Montana
    Suck
    Quote Originally Posted by Hofmeister View Post
    Fried clutches won't whine, they just don't grip. Whining is bearing noise.
    Mar 2003
    Winnipeg, Manitoba
    1997 BMW M3
    both my wheels chirp.
    97 BMW M3 (s52b32) - VF-Supercharger kit ( Vortech V2-SQ supercharger, 32 pound injectors, VF tuning ), VDO/LeatherZ Gauge Kit (Oil Temp, Oil Pressure, and Boost), UUC Motorwerks RSC36 Exhaust, Stainless Steel 6-2 Exhaust Headers, Bilstein Sports, Rear Adjustable Camber bushings, Wheel Spacers 10mm in front 25mm in back, Uprated Clutch, UUC Shift Knob, Short Shifter and Clutch Stop, Cross Brace, Mason Engineering front strut bar, Contour Wheels, Euro Ellipsoid (Angel Eyes) HID Headlights, braided steel brake lines, aluminum thermostat housing, mishimoto aluminum radiator and silicone hoses and a partridge in a pear tree
    Feb 2012
    Northern Virginia
    Quote Originally Posted by Binjammin View Post
    Which bearings, where?
    From what I'm hearing, I think, moving forward, assuming a fried clutch pack is the thing to do.
    Thank you for all the help.
    Butte, Montana
    Suck
    Didn't watch the video, but if someone was hearing a whining noise, that's what my post was referring to.
    Feb 2008
    USA
    1995 E34 540i M-Sport
    Looks like it could be a broken pinion gear, but I'm no expert. Have you tried to spin them on dry? If its a healthy LSD it should be able to do this.
    they expected to see a mustang or a muscle car and then its like WTF? a BMW?
    Aug 2009
    Greeley, CO
    540i6, 540iA, RX7, RdBlk
    Yep. So it's just all tired and worn out. Aside from having to remove the diff to do it, the rebuild isn't too bad. Plus, if you want to, you can upgrade the clutch pack to 40% lockup. Jon (5nail5) has info in one of his threads.
    Fox
    Quote Originally Posted by slippyM395 View Post
    Uh, on this one I think not. Generally a broken pinion would make the car not move - the pinion is the input point for power. So I highly doubt it's that (like 99.9995% sure). I'm about that sure it's the clutch pack - the 'whining' that someone mentioned could easily be the clutches slipping and chattering at a high pitch.
    OP - do you know how many miles the car the S3.15 came out of had? Still going to end up needing a rebuild, but I'm just curious.
    Feb 2012
    Northern Virginia
    Not sure how many miles in the donor car but I look through my records and can try to find out. Anyone have a good source for new clutch packs? I'm not sure if I need 40% but will look into it more.
    Found this...
    http://www.bimmerdiffs.com/products/...-kit-25-lockup
    Thoughts? 2-clutch set gives 25% lock-up and there's a 3-clutch option, which requires some machining, that gives 40% lock-up. I think 25% will be just fine for me.
    Also, check out Jon K's AWESOME video here...
    http://www.bimmerdiffs.com/pages/guides-videos
    Oct 2008
    From Maryland to New York
    E46 M3
    Jon posted some videos on youtube doing this.
    Feb 2012
    Northern Virginia
    Quote Originally Posted by ShapeShifter View Post
    Pat - Thanks. I posted a link to one of them above...ha.
    Aug 2009
    Greeley, CO
    Found this...
    IF you've already got to rebuild it, why not 'do it right'? The 40% option doesn't really have any drawbacks, so why not? I'll be going that exact route when I get a 3.15 myself (hopefully sometime this spring). My $.02
    Fox
    Jul 2012
    MA
    ///M5
    Fox there's a 3.15 for sale in the classifieds.
    Current
    2005 E55 AMG
    1964 Impala
    Past
    2000 Avus M5
    1988 Suburban K1500
    1987 Suburban K2500
    2007 Suburban
    1999 K2500 Suburban
    2000 MGM
    1999 K2500 Suburban
    1990 750iL
    1995 540i/6
    1996 MGM
    Feb 2012
    Northern Virginia
    Quote Originally Posted by K Fox View Post
    ... why not 'do it right'?
    Honestly, it's a bit scary (to me) because of the machining required. Plus it's a bit more expensive... But I might...ha.
    Baudette Mn
    18 Cummins 3500 00 330t
    Does the s on the case itself mean lsd or is it only a s on the tag?
    I seem to remember my 3.15 lsd having a s on the case, but I don't remember the stocker.
    Dec 2005
    North Carolina
    540i/6 M-sport GA65474
    Check this out:
    http://diffsonline.com/bmw-540-diffe...l#.UuxUqdiYa4Q
    they also have 6speed Getrag transmissions for our cars
    http://diffsonline.com/getrag-6-spee...l#.UuxVj9iYa4Q
    Cool stuff
    Gixxer wants^
    Gone but not forgotten:
    '95 540i/6 M-Sport. GA65474. Alpineweiss/Parchment.
    Supercharger project
    Mar 2011
    Neverland
    E34 525i
    Quote Originally Posted by me78569 View Post
    Both mean that. My current lsd had 2 S's on the case.
    Baudette Mn
    thanks for the insight
    Mar 2011
    Neverland
    E34 525i
    Lsd cases are also painted black.
