Is there a write up on how to remove/replace the Z3's fuel door actuator?
I'm talking about the part that is supposed to lock/unlock the fuel door with the central locking.
Can you do it by removing the fender liner or do you need to remove the entire metal fender?
I searched but the mobile search function doesn't work well.
Drink wine! BMW CCA #373875 - 2007 M Coupe (project) - 2000 Z3 Coupe - 2015 Impreza wagon
I'm not sure. The plastic rod is intact, and if I pull the rod out the actuator will unlock the door but not re-lock it.
I think there's only two wires going to the actuator...(?) So that would mean both wires are good.
I'm able to put my fingers between the fender and rubber gasket around the filler neck.
The plastic rod in mine was broken when I bought the roadster, I hope it is easy to replace and not one of those parts that you have to buy a huge kit of pieces to replace that one part. I know the actuator on mine works, I just lock/unlock the passenger door with the fuel door open, I can hear and feel movement but that plastic rod is just too short (likely broke since it doesn't even make it into the backside of the slot where it would exit the body of the car and into the slot of the fuel door.)
"A people that values its privileges above its principles soon loses both."
- Dwight D. Eisenhower
CPR Turbocharged '14.5 Deep Impact Blue GT/CS Mustang #278 (ORDERED 3-19-14) Delivered 5-15-14!
'11 BMW Z4 35is ///M Sport Black Sapphire Metallic
'04 Sonic Blue SVT Lightning #3535-3781 (GONE & Forever missed!)
BMW ///M Roadster '00 Titanium Silver/Black (gone)
I had to replace that cable when I first bought my M Coupe. I don't remember a thing about it so it must not have been too bad.
Brian
Update: You can access the actuator by removing the wheel well liner.
There are two wires that go to the actuator and, of course, one can disconnect them at the rear of the actuator but there's also another wire connection just inside the trunk. This is where my problem was. The wire connector had become corroded so I sprayed some electrical cleaner on it and all is well.
Yes, the fuel door actuator is behind the wheel well liner; 4 screws and a lot of maneuvering to get it out and not much room to work.
My fuel door actuator would not work remotely. If I locked the door with the key it would work and it would unlock remotely.
So, my convoluted logic told me to replace the actuator, a real PITA and guess what, it still does not lock, BUT UNLOCKS remotely.
Has anyone had the same problem? Does anyone have any ideas? I'm at a total loss.
2001 ///M Roadster - Titanium Silver
F: TC Kline/Koni coilover struts, Eibach, TC Kline Camber Plates, Wilwood big front brakes, GC tubular swaybar, Dinan Strut Brace R: TC Kline springs, short Bilsteins, IE sub & swingarm bushings & shock mounts, 3.23 gear, Rogue dual-ear cover, Eisenmann 4x83 Sport pipes. MISC: Sport mode, Rogue pulleys, keyless, RG Motorsport CAI, Randy Forbes rear end fix.
2007 335i Coupe, Sport, Black inside and out, Bone Stock Rocket Ship.
Can you tell me where the connection in the trunk is? I need to check to see if it is disconnected because I am having the same problem (Fuel Door NOT locking) Thanks.
Edit: Here is what I found in my trunk.
1. A disconnected connector circle in red (3-prong black connector)
2. Cut wired (also circled in red)
I would like to know where this connector is supposed to be plugged into. Any help appreciated.
This thread made me go look at my 98M. I had a 97 2.8 before this M, and never heard of a locking door. .......... There is no locking mechanism; no place I can see where there could be one. The door opens and closes freely regardless of locks on/off. There is a rubber cup that seems to seal the area; no holes or other signs of a missing lock. ........... It does have locking gas cap which takes the ignition key.
I was under the assumption that the gas door locked when you locked the car. I'll have to check mine when I get home.
My 1999 2.8 fuel door does not lock but there is a provision for a locking mechanism. There is a cutout in the panel that corresponds with an opening in the fuel door where a locking pin could be installed. I suspect a locking fuel door was an option or maybe a part of a package. In any case, I'd personally rather use a locking gas cap. A locking door is too easily pried open resulting in not only the loss of a tank of gas but a trashed fuel door and a scratched and dented rear fender.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
Early models had a locking gas cap keyed to the ignition key
Some later models had a locking fuel filler door though I am not entirely sure what models did or did not receive it. I believe all M's did, because they were the higher end model but I am not sure when that went into effect.
My 1999 "2.3" does not even have the slot in the filler door for the locking pin. 02 M has the complete assembly and the fuel door locks when the doors are locked
PRICE CUT on ALL FABRICS
Locking door introduced in April 1999 as part of the minor facelift
