Question above^ Of course, this is for the non-s54 owners.
Yes, I just changed to this weight this year as it looks to be more compatible with the Wisconsin cold. Currently in the S52, M44-DASC and two M54s (Z3 & X3).
DIY/Project Links:_TC Kline D/A & Suspension Refresh_|_Oil/Engine Cooling Options / Install_|_
Dinan/Fikse FM-5 Build_|_Stereo Install_|_HID Retrofit_|_
I just put it in mine today. 7500 changes. Screw the maintenance light.
i use it as well
Yep.
Brian
It's a smoother running oil in my car than Amsoil 0-30. I was surprised to say the least.
Yes--I run it in my Volvo's and Saab too.
Yes
I've used it! Decent stuff I usually run a little thicker in the m44 but it sees the track and redline a lot.
Sent from my Galaxy SIII
yep
yes and cheap at Walmart
I live in Florida and use it in our Z3 and 325iT.
why wouldn't it be?
the second number is the important number in oil classifications.
the first number is just how it operates at "low" temps. At "low" temps, I'd prefer my oil to be as thin as possible, bc at "low" temps even the thinnest (aka zero weight) oil is too thick.
I use it in my BMWs and VWs, 5 quart jugs are a good deal too.
“Great wisdom is generous; petty wisdom is contentious.” 无为
I've used it in the Z for years, a few years ago when it became hard to find I switched to Lubro Moly 0w-40, but now Walmart is carrying the 5qt jugs again. If you cant find it, Amazon has it and its prime eligible!
Current Cars
2008 BMW M5 6 spd
1995 BMW 540i 6 Spd
2016 M4 Cabrio 6 spd
2017 X5 35d MSport
2017 i3 94ah Rex
Former Cars
2013 135i MSport Cabrio DCT
2012 BMW X5 35d Sport
2000 BMW Z3 2.8 Roadster MSport Impala Brown
1992 BMW 535i 5 Spd
2011 BMW X3 2.8i MSport Alpine White
1995 BMW 530iA Artic Silver
1986 BMW 635CSi Bronze Mettalic
2009 Dodge Ram 2500
Yes. 5 qt jugs at wally-world FTW!
-Bill
Yes, I use it in both of our beloved Bimmers. (M44 and N52).
The only oil i use in my 135i/N55
Alpina Lip/Muffler Delete/ Shadowline Trim/ Shadowline Grill/CF Roundels /CF Door Pillars/18' TSWs Staggered/Smoked LED Tails/Corners/Side Markers/ 8000K Lows/Fogs/ LED Dual Color Switch Back Turn Signals
Led Reverse Bulbs/LED Interior/Cargo Area/ Puddle Lights
48 SMD LED License Plate Housings
I have used it for years in E39-540i, E46-325Ci and my Z. Never had any negative issues.
