Hey Guys,
So I've heard some conflicting information on the difference in the rear fenders, between the Z3 2.8/3.0 Coupe & the M Coupe. I know from experience that the rear subframe, trailing arms and axles are in fact different, but are the M Coupe fenders any different from the non-M?
Reason I ask is I already have an entire M Coupe rear suspension available and I'm really trying to justify if I really care to have the M. Granted aesthetically, I really do prefer the rear M bumper, quad exhaust, and the license plate being on the hatch. That being said, I will be swapping in an LS6, with T56 6 speed, doing all poly urethane bushings, bigger brakes, and coil-overs. Therefore the S52 and ZF (not trying to spend the money on an s54 model), along with the stock suspension and brakes aren't worth the extra money for me.
Basically I just want to know if I get a non-M z3 coupe, and install the complete M Coupe rear suspension, that I can still fit the same width wheels and tires (my whole reason for choosing the z3 M Coupe chassis).
I'm not a noob, and I'm not here to waste anyone's time. That being said I hate Bimmerforums search function, as it's terrible in comparison to other forums for actually providing the threads and posts I really want.
Thanks in advance!
www.facebook.com/Undr8dEmpireLlc Instagram: @UNDR8D_EMPIRE
Scarlet V2 - #Project333Ti - http://www.bimmerforums.com/forum/sh...(-Project333Ti)
There should be no conflicting information. The chassis and exterior body panels are absolutely 100% identical. Only the suspension is different (and the rear wheel offset, to compensate).
So absolutely, you can get to exactly the same place by starting with a non-M.
I like the unicorns.
'99 Z3 Coupe - Jet Black/Black (1-of-114)
'99 M Coupe - Estoril Blue/Black (1-of-82)
'03 540iT - Sterling Gray/Black (1-of-24)
'16 Z4 sDrive35i - Estoril Blue/Walnut (1-of-8)
When I saw the title of this thread, I was about to get peeved... ANOTHER Z3 Coupe vs. M Coupe thread? Geez. Thankfully, this is just a tad different.
Unless I'm mistaken, you can get the same width of wheels back there whether M or Zed - the difference will be the offset. Honestly, you might be better off with the standard Z rear configuration, because finding rear wheels with the very low offset required for the M fitment is a pain in the derriere unless you go with custom modular wheels, or are not averse to spacers.
Anyhow, this thread gives some good insight. Many of the cars in it are Ms, but there are some Zeds. I noted one Zed with 9.5" rears. I'm guessing that the lack of really wide rear wheels on non-Ms is due to the lower hp numbers, perhaps? However, there are a handful of folks with S/C-ed M52/54s... so maybe I'm wrong
DIY/Project Links:_TC Kline D/A & Suspension Refresh_|_Oil/Engine Cooling Options / Install_|_
Dinan/Fikse FM-5 Build_|_Stereo Install_|_HID Retrofit_|_
http://forums.bimmerforums.com/forum...0#post21797700
Old thread, but answers the questions about M vs non M wheel setups pretty well.
Having an Z3M rear suspension means nothing to me. The stock units for M or non M Z3's weren't that different except maybe a little ride height and certain nothing to crow about. All the aftermarket units for M vs. non-M are the same. You may be able to fit a little more tire in an M with the shorter half shafts but that's probably not worth the trade off of having use funky offsets. If you are swapping in a LS6 and that trans, the suspension will be an afterthought. Should be a beast.
Now in E92 M3 ZCP -- Absolute beast
Thanks for the clarification guys. The final offsets for the rear are of great concern to me, as I already have quite the low offset wheel collection from my E30 M3 and E34 touring, which I would attempt to utilize for this project.
Swapping over the Z3 M rear suspension, trailing arms and axles to be able to suit my wheel and tire goals if crucial for my decision. I need to be able to fit 305s out back, and plan to widen a couple pairs of rears from my wheels sets to accomplish my goals.
I have no high offset wheels, nor do I care to acquire any. I would simply sell the Z3 rear 5 lug to an E30 guy and call it a day.
Thanks, but my sig doesn't match current reality. Since that pic, I installed 600# rear springs and the static height is actually a bit taller than the 400#ers they replaced, so I'm about 1/4" up from the ideal. I'll eventually get short springs to install with ride-height adjusters (which I have in a box), but for now I deal with it.
I'm all about the squared (vice stretched) shoulder. It's the look I prefer on myself, and my car.
That's a spicy meatball!!!
I am assuming you are not going to putting flares on the front. If you go all the way to 305's with maybe 255's out front, your car is going to understeer like a total pig. If you can't get traction with 285's which is what Sky1Z3 is running, with 255's out front, then you have some real issues. Specifically, do you want a cool looking straight line M coupe or do you want to be able to also corner competently. Personally, I'd buy the stickiest tires possible (I notice you live in LA, CA so NT01's is an option) and go 255 using 9" wheels/285 using 10" wheels.
I have to agree here. I am running 245 F 285 R and while I don't experience much understeer, if you added another 20mm of contact patch then added sticky tires (im on sumitomo cheap street tires) you would have a problem. Im all for big wheel packages, but if you are gonna go as big as 305 rears, you really need to fit a 265 front like Jones did on his coupe.
I don't plan on running flares up front, as I don't believe any are offered. The 285 with a 10" may work, but it will be a handful with 400+whp/400+wtq. The under-steer could be aided by spring rates, sway bar size and bushing compound. I could always run stiffer springs out back with a bigger bar, race vs. street compound poly bushings and if that's not enough, then control with throttle modulation.
I've had multiple swapped e30s, which have similar wheel bases and suspension and I know how to set-up the suspensions for different applications. I had 17x8.5 front, with 235/40/17 front and 17x9.5 rear with 255/40/17s and it felt perfect with a soft bar, with 550# front/600# rear and poly street compound rear bushings, with a 16mm 3 way adjustable bar. If I ran a 305, with a 255 up front, I would probably run 500 or 550 front, and a 700-800 rear with a 18 or 19mm rear bar and race compound poly bushings. I know it would take a while to dial in the spring rates, but I'm up for that. I also plan to run long gears, so either the stock 3.23 gears from an M-Coupe or a 2.93 if need be with the Camaro T56 (Camaro comes with 3.42 final drive stock). Long term goal would be to fabricate the Corvette 4-link rear suspension to work.
Funny, I asked the same question(s) and more similar in this thread: (Newbie Z3-coupé thread) Differences between M models and non-M?
(Coincidentally, it is linked in The Manifesto.)
Edit: JoshS seems to love these threads. =D
Hey Polak, run, don't walk. 8.5K M coupe in your area
http://losangeles.craigslist.org/sfv...274475571.html
Sounds like what you need up front is similar to what is done in this wide body Z3 thread. http://forums.bimmerforums.com/forum...ight=wide+body
