I didn't discover this, but the person who did isn't active here. It's a very simple modification
MSS52: Search for "64 00 46 00 00" and set the first "00" to a non-zero value
MSS54/HP: Search for "64 00 5A 00 00" and set the first "00" to a non-zero value
If you want, you can also delete any DTCs that show up, but it's not necessary. None of them actually throw a CEL or interfere with DME operation in any way.
What software can you use to do this?
Basically you'd need to read out the software with something like BMWFlash or Galetto, change the byte I mentioned above (with a hex editor or something), correct checksums, and flash back. There's a lot of info on tuning these ECUs at M3forum now. Should be quite helpful for any of you who want to do swaps into older chassis.
Terra, do you know which values to modify to get rid of the suction jet pump and kombi codes ?(both E46 M item that I deleted/not using in my E36)
Current:
Alpine White E46 325i Touring S54 6MT
Titanium Silver E39 540i Touring M-Sport S62 6MT
Past:
Alpine White E46 330i ZHP Sedan S54 6MT
Interlagos Blue E85 Z4 M Roadster 6MT
Le Mans Blue E92 M3 6MT
Japan Red E46 325i Touring S54 6MT
Estoril Blue Individual E46 M3 Coupe 6MT
Cosmos Black E36 M3 Coupe S54 6MT
Alpine White E92 M3 6MT
Alpine White E90 M3 6MT
Laguna Seca Blue E46 M3 Coupe 6MT
Jet Black E36 325is S52 5MT
Lagoon Green E36 325is 5MT
Follow this for whatever the error code numbers are: http://www.m3forum.net/m3forum/showthread.php?t=458115
I can't be more specific without knowing what the actual error numbers are and which version of the MSS54 software you're running
When you say the first 00 to non zero, Do you mean the 00 between the 64 and 46? to like "01"?
or one of the two "00" before the 64?
I've changed it to 64 01 46 00 00, However I have "engine failsafe" and two codes 150 and 157 both are for internal memory faults. I also changed the sport button memory and SAI delete.
Engine program is 7837952
UPDATE....
I had an incorrect checksum. Was fixed and all is good and ready for the swap!
Trevor
01 749i sporty, build 12/00 "Sports Barge",S62
92 VW Corrado VR6,AAA
81 Delorean,B28F
81 VW Rabbit Pickup 1.8T,AWW
03 VW Passat wagon 4.0 W8 6spd
Current:
Past:
i know this is a old thread, but its worth the question.
s this the way how to detele EWS on the MSs54, because its not working.IMG_4762 (1).JPG
Send me the file to my email, I'll look it over and disable ews for you. As well as any dtc codes that may pop up.
Performance Tuning and EWS Delete for MSS52/MSS54/MSS54HP/MS41/MS42/MS43/ME7.2/M5.2
Virgnize DME service available to unlock DME to sync to another vehicle on EWS3 vehicles 98+. M5.2.1, M7.2, MS42, MS43, MS45, ME9.2 and more.
Easiest way to contact me is to send me a message on my facebook page "DUDMD Tuning"
I sent you my file via facebook.
I could not privately message you.
Thank you for the help.
The picture looks correct to me. If the car doesn't start, that suggests something else could be wrong.
