And the rubber band trick wont do any more?
No longer!
Raises hand and slumps shoulders....
You are busy, Sky!
DIY/Project Links:_TC Kline D/A & Suspension Refresh_|_Oil/Engine Cooling Options / Install_|_
Dinan/Fikse FM-5 Build_|_Stereo Install_|_HID Retrofit_|_
The right side of the panel is starting to feel a little loose. Please don't tell me this isn't normal and that my baby is falling to ****. PLEEEEASE.
'02 M Coupe, Estoril Blue on Estoril
'02 M Coupe, -???-Who knows-???-
‘02 M Coupe, Alpine White on Black
'06 M Coupe, Interlagos Blue/Black Carbon Leather
’99 M3 Coupe, Technoviolet/Black
’04 VW R32, Reflex Silver/Black Cloth
The 3d print company quotes about 20$ each for the new surround parts. Ill get one done as a test part, if it works well.... you guys let me know how many I need to order.
I sent the completed files to the 3d print company. I should have part in hand by about the 1st they say.
And the results are in! ill let the pics speak for themselves.
I don't have an issue with my switch, but this is an awesome solution for those who do! Nice job, Sky! I'll probably snag one while I can, because it seems like it's bound to be an issue at some point.
Oh, very clever.
The 3d Print company did good work. And beat the delivery estimate by 10 days. Im happy with it. The surface finish is a little rougher than I had hoped, but that's a minor downside in my eyes. And... they offer it printed in any color or material.... hell even sterling silver if your pockets are deep enough.
Just got asked about why my switch looked stuck. went out to car and the switch wasn't pushed all the way flush. Now its flat and flush. I think it could stand to have the retention lip made a little bigger so that it would hold in case someone's headliner was really worn out. But it works perfect in mine.
Bravo. Had this issue in my '99 and would have loved this back prior to Fall '08!
Does it have the tabs, or is it snug fit?
Mods: A Few...Rod Bearings, VF Eng. SC stage 1 - 5 lbs, HP Coil packs, Underdrive Pulleys, Organic race Clutch, CDV Delete, Shift pins, Short shift kit w/bushings, Shortened shift lever, Randy's Subframe, IE Bushings, TCKline suspension, Adj. Cast. Camb. (front), Adj. Camb. (rear) 700# springs, RSM, Rogue cover, Metric Mechanix trick variable ramp LSD 3.46, Wilwood Big Brakes, 18" CCW LM's, 315 30R 18, PSII's Complete custom exhaust… Ceramic coated headers ID/OD, Race cats, Eisenmann sport w/83 mm, Custom gauge pod, Custom gauges, Dual Wide band Air/Fuel monitoring, Built-in scan gauge, Becker Traffic Pro, Seat hump removal-both sides, Seat front raise, ACS rare low profile rear wing, Smoked tails, HID's Lightly smoked,
Special Thanks To: Randy Forbes Rocknroad 2Kredz3 MC28REPSOL IslandS62 Clintjg jonesmechanical Ron Stygar and many more on our board!
Both, it has some small angled tabs but is also about .140 larger overall on width and length.
I'm ready to order one in black.
If you want one contact me and I will show you the link to the 3d print shop
Did the 3D shop quote you a different price if you had ordered in bulk?
I definitely need one of these. I hate that my button is always trying to fall out.
-Joe
No, the shop charges by volume of material used. So that volume wouldn't change based on number of parts. The only variable would be the shipping. But by the time I ordered several and then had to reship them out to people it would be the same or maybe more. Easiest to just order straight from them than having me as the middleman.
