- What is this?
Heureka!
Finally I found it. The secret of the thing is unfolded here: http://www.meeknet.co.uk/e31/E31_840..._Tick-Over.htm
No wonder neither you guys nor the British knew what it was, it's only found on German and (probably by laziness on BMW's part) for example Swedish cars. "So, I blocked the T-piece where the cap fell off and was pleasantly surprised to find that the tick-over was perfect - and more interestingly, the error codes didn't return and the adaptations settled at very low figures. Only models for certain countries (Germany for instance) have anything other than a blanking cap fitted to the T-piece. In Germany there is a 'disturbance air valve' - Reinhard tells me that the valve is used for the emissions test, opening the valve allows un-metered air into the manifold which the ECU should be able to compensate for:"
Thx for help and input. One more riddle solved!
Per
Great work Kornknarr. Now we have a new section in The Manifesto.
Disturbance Air Valve (emissions test MAF by-pass unmetered air test fuel trim test)
What is this?
- You may not post replies
- You may not edit your posts
Forum Rules
