Well, i just got a z3 5-speed with the 2.5L engine in it. Any good write ups on changing the tranny fluid? How much does it use? Kind? I'll be searching up threads after i post this but feel free to give any advice to a BMW newbie Thanks!
Welcome to forum------keep searching---a million threads and post on how much and what oil to use and how to change it.
I couldn't find a definite answer on what fluid to use.
This will answer you------ http://forums.bimmerforums.com/forum...ht=redline+mtf
Amsoil MTF 5-30, its the most recomended and the best one to use, will smooth out your shifting, http://www.amsoil.com/shop/by-produc...n-fluid-5w-30/
That is a fine manual transmission fluid, and it feels good, but AMSOIL does not recommend it for Z3 transmission. For our transmissions, they plainly state "No AMSOIL Product Recommendation."
http://www.amsoil.com/mygarage/Produ...=1997+BMW+Z3+1
The Bentley Manual also warns against using multi-grade oil transmission fluid. BMW only recommends ATF fluids, of which their own ATF, or Dexron III, or Royal Purple Synchromax are examples.
Just changed mine last night. Went with the Amsoil MTF. Seems to be working fine, maybe a little smoother than with the BMW oil that it replaced. Took just over a US quart.
And you never will.
The best thing to do is read the threads in the Manual Transmission Gear Oil section of The Manifesto and then make up your own mind.
I just switched to Redline D4 ATF in both my Z3, and my ZHP. Great stuff, shifts super good so far.
I want the tranny to last as long as possible. Purely street/occasional spiritedly driving.
No doubt. That still doesn't supply a definitive answer.
Your intended usage matches what BMW/ZF envisioned. ZF called for ATF. BMW called for a special long life fluid that is the same characteristics as ATF. Amsoil MTL is thicker. Some put forth the argument that thicker is better. Some are happier sticking to the BMW/ZF spec. I've tried both, and I'm happier with the ATF.
/.randy
http://www.mobiloil.com/USA-English/...etic_ATF.aspx#
Will that suffice then?
will that suffice then?
Will mobil 1 synthetic ATF suffice?
There are some here running mobil-1, yes. Anything with a Dexron III rating will be in the correct viscosity range, as is several of the OE manual trans lubes. Pentosin MTF2 is marketed as a direct replacement for the BMW fluid. The choices are wide and confusing...
/.randy
i have a 96 and have been thinking about this issue as well. not sure what i should be using.
You could use what BMW recommends. ATF.
Like BMW ATF, or Dexron III, or Pentosin, or RP Synchromax.
On the other hand, you could use what neither BMW, nor Bentley, nor AMSOIL recommend. Multigrade 5W-30 oil-based fluid.
It is a difficult choice.
side note, im not going to change the tranny oil w/o changing the diff as well. does anyone know the correct weight for a 1.9 LSD rear diff? during my search i keep seeing 75-90 then 75-110 or even 75-140. anyone know the correct weight for my rear diff? sure i can go to BMW, but they are 15-20 miles from my house and would rather not take the trip for just some oil.
For the Diff, it depends a little on where you live. I'm in Ohio and used Amsoil Severe Gear 75W110 in the differential based on the recommendation of Kelly at ModSquad Motorsports. His contact info is in this thread, among others: http://forums.bimmerforums.com/forum...Amsoil-mtf-WOW. You may want something heavier in a hot climate. Here are a couple of pointers on changing the diff fluid: Remove the fill plug first in case you can't get it out. You will need a pump to get the fluid in there. It might be a good time to replace the drain plug with a magnetic one, such as the Dimple drain plug.
Ok, going with Mobil 1 synthetic ATF. How many qts do i need? 2?
i think im going with mobil1 as well.. looks to be the cheapest out of all the big brand synthetics. i think its like 1.1 quarts for the tranny.
thanks for the tip Blanklane
Just enough so you have to but two, but its not like brake fluid its OK to store an opened container, use it next time. It was mentioned earlier but always make sure the fill plug is out before draining, and the plugs are tapered I use some soft permatex to seal and don't over-tighten. The first time I pulled my plugs I thought I was going to knock the car off the stands. I use a clean funnel with a long piece of clear tubing and fill from the engine compartment, don't mess with the various pumps out there.
A pump isn't necessary for the transmission, but really helps for the differential. I used this one that just screws into the oil bottle. Very handy.http://www.amsoil.com/shop/by-produc...tle-hand-pump/
