Nice thread, keep it up. Excited to see the headlamps finished.
^thanks! You and me both on the headlights!
- 1of1 rebuild (build thread) -
- Wanted Car items - FS: PnP aftermarket alarm details -
- Coupe Custom Subwoofer box - FS: Z3 Coupe LED 3rd brake lights -My Website for DIY content and parts: Double Bee Garage
Got some good work done over the weekend, unfortunately the entire week was a wash for progess on the Coupe since my DD was down due to a missing cam bolt that was suspected in the oil pan (it wasn't luckily) and my focus being on getting it running again.
Delrin/oilite pedal bushings installed
Swapped some parts from the center console over (in process of reinstalling)
Attempted to paint some more parts for my retrofit that came out poorly so I will be sanding and reattempting this week. 2 week deadline to a local show and 3 week deadline to DSS are coming up QUICK!
On a side note, I dont think they could have made our center consoles ANY more complicated. Seriously how many screws do you need to hold this thing together and if you have that many if the first palce, why cant you make it two pieces like ever other center console on earth ever made?!
^ how difficult is it? I sourced a new grey center console piece that goes around the shift boot because mine has a minor spider web from the mirror leaking on it. Please tell me install isn't a pain in the ass
///M
Agreed. Plan on pulling both lower dashes (Driver and glove box). Radio. Cupholder (etall). Shift boots. pull AC knobs, disconnect the controller from the console. Disconnect all our switches (Blind since you cant get an eye on the back side).
To replace just the shift surround plastic you have to remove all the guages, boomerangs, and upper plastic.
While you're in there I would highly suggest swapping all the bulbs. Two for A/C controls, and the Three for guage bulbs. the guage bulbs are fragile, I broke 3 of the 6 filaments when swapping mine around (luckily just 3).
I replaced the upper and lower platics (radio and shifter surrounds), swapped a guage, replaced my AC bulbs, installed the switch panel in the read for the small useless pocket, and installed a leatherZ armrest and swapped my shift boots.
It is not something I want to need to do again. I'm going to verify all my bulbs are good before 100% install just to be safe because I DO NOT want to have to go into this thing again.
Console is 100% back installed, that is a PITA. I do not wish that work upon my worst enemies.
Box via Fedex requires signature tried to come yesterday at 12:30. Left note saying I'd be home after 4:30, but I doubt they'll be there today late, or take my signature on the slip.
Pulled my alarm since my window relays aren't working right, I think my diodes are in wrong since they arent working at all. Going to get that sorted tonight so I can button up the interior completely today/tomorrow. The weather cooled down a bunch to be painting and rolling around on concrete to be doing other things.
8 days to a local car show. 15 to DSS... woohoo!
Also have the extended leather center console I snagged up for sale in the classified if anyone is interested in it.
teaser update:
Interior should be 100% installed tomorrow...
Way to go! I'm diggin the socket cover. Details?
You put your asc and window heater buttons in backwards..car show minus points
ps love the socket plug too
Ahh, the 3D printed plug from the other thread. Very nice. I guess some people have time for these custom things.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
Sky1Z3 made them. I put more in his thread where he was producing them, you can probably still get them from him or through the company he used to do them. IIRC they were <$20.
Thanks, and you noticed the two switches flipped, but not the oil pressure and clock, or the black radio/shifter surround in a beige center console? Rearranged to make more important buttons/guages closer to me to my preference. It's custom!
Devil is in the details.... You guys just wait till I get my headlights sorted... that is the last big thing on my list before my car is road worthy again.
Todo list:
Reinstall lower dash- driver & passenger
Reinstall mufflers
Finish Retrofit (still hours to invest here)
Tow to my shop for an alignment
Reinstall Pass rear fender liner
Adjust ride height (as required)
DRIVE
If I get frisky I might swap my slave cylinder out too. I have one sitting on the shelf waiting to go in.
On your DBO, was your console in beige as well? I like it in black, I might do mine like that.
-Abel
Yea, it was all beige, and the paint was all scuffed and was missing in some parts showing its age. These black panels look great except for a few small pry marks around the radio, but look 4893140 times better than the beige ones did. I'll have full pictures when the interior is 100% back in.
Interior currently is 100% in (but theres a catch) as of last night.
Got fed up with the wreck of a mess I had made of the garage over the last few months and decided to throw the wheels on and roll it out since it was "drivable" again.
Pulled it out to find that my brake pedal does not travel freely... it gets stuck about halfway through the travel. Dunno whats going on but I thought the Delrin bushing was SUPER tight. I had to pull it back up with my toe! I dunno if this is because I need to bleed the system better to get better master cylinder pressure or of the pedal bushings are just too tight, I'm pretty sure the spring was back on right.
Silver lining? I got to check out my LED 3rd tail light conversion on the car for the first time by myself with no extra tools required!
Not looking forward to pulling that thing back out, that is for sure. Going to do a proper bleed tonight and see if that helps before pulling the panels again
Rehanging the exhuast tonight.
Car gets towed to the shop tomorrow to get an alignment, with no headlights currently. (not sure what I'm going to do about this since its raining all day today and painting in the rain isnt good, and I'm stuck at work till 3)
EDIT: Ohhh and Fedex home deliever guy is a dick, left a note on the 1st attempt to deliever a box (11:15am) with a very awesome goodie in it, saying I can't be home before 4:30 to sign. 2nd attempt note left at 11, where he would have read note. 3rd attempt (10:45am), surprise! no one is still home. Now I have to drive across town to go pick it up... awesome.
Bleeding the brakes is not the answer. The pedal has to return fully by itself. No residue pressure on the master, no brake lights stuck on.
/.randy
Thats what I was afraid of... PM'ing you since I'm stuck at work
Got the brake pedal sorted. I'm going to contacting Ireland engineering about it. I think the issue comes from the OD of the bushing into the ID of the pedal. I ended up having to sanding some of the OD of the pivot mount to get it to rotate freely.
A few shots from the last few weeks progress:
Before
After
Old worn pedal bushing versus their new counter parts
The day it was in the 80s the dog was pooped
Re wired and hid the alarm siren
Start of the console swap
End product of the swap
Reinstalling the alarm. Now has remote window up and down and hatch pop.
Mounted my harness and ballasts fornthe HIDs to the motion motorsports under panel supports.
Getting my ride height set, and tucking like a school bus til it get aligned and measured for spacers till the ACS's get rebuilt.
And just before the tow truck arrived to take it to the shop for a proper alignment tomorrow
Awesome progress! Looks like you're there. How low do you have the GC's set?
///M
Fronts are 3-4 threads from the bottom. Rears are on 5mm spring pad and the collar with no adjustor (threaded part)
I got them off 2000mkoop he told me 450/600 but I haven't verified the part numbers yet. Aggressive street driving and maybe some autocross to start. Its a weekend toy.
P.S. your shift caps are in the mailbox for tomorrow.
I DROVE IT YESTERDAY!!!
I was grinning alot, unfortunately I had to drive it straight home. Why you ask? My ballast wires werent long enough to plug into my headlights I will have to remount them closer. I picked the car up at 5:30PM and had to race the sun home. I didnt want to get caught out with non-functioning headlights. However, with them in the car, I had a bit of change of heart on how I want to do v2.0 of my retrofit, after seeing them mounted.
So if you have a set of broken tabbed, hazy any year headlights that you're saving for parts and want to sell them to me at a good price, let me know.
Will be remounting the ballasts tonight and trying to aim them after getting them wired up.
Ended up I could make the ballasts work where I had them mounted, just had to rerun the leads and cut a bit more of the driver side air scoopy thing casing. I have headlights parts showing up all next week for v2.0 with some ideas of how to make them better.
Turns out one of my ballasts was bad out of the box but TRS is covering it under warranty no questions asked, I'm praying it shows up before Wednesday night so I can have them aimed before the drive to DSS. I'll be tearing apart the old ballast just out of curiosity when I have some free time.
Had a local car show, Springfest 5, here yesteday. Here are a few shots I have of the coupe from the day.
Robb,
If
is the last minute throw together... I need to come hang out with you on headlight builds. I really dig this set. The city lamps would look great I am betting.
And of course, I love the cig lighter plug.... Youd be amazed how many people have asked about my coupe text one. Im sure the ///M one will get the same attention. Just be sure you tell them where they can get their own!! ;-)
