Seriously, don't over-torque your spark plugs! Somewhere in the history of this car someone over-torqued the spark plugs. Then, someone else (could have been the same PO) decided that the spark plugs were too tight and changed 4 of 6! Luckily some PB Blaster and my smooth hand were able to remove the plugs without taking the threads with them and all is well in the world again (and all the plugs are the same type and age).
Avert your eyes (yes that's broken insulator!):
1992 525iT, Manual Swap, Bilstien Sport struts, H&R springs, Style 32 17" wheels (17x8 fronts, 17x9 rears), ACS exhaust, Euro cluster, Wilwood SL6R BBK on E38 rotors
Yeah, I'd say those were due.
Definitely. And it looks like I have a valve cover gasket job to do soon.
Well, that could have been a LOT worse!
My Current Cars:
E70 2010 X5 4.8i Xdrive Spacegrau
E90 2008 M3 6MT Silverstone II
E34 1992 M5 3.6 J-spec Calypso
E34 1990 535/5 turbo Bronzit
E32 1990 750iL Highline Delphin
E30 1988 325i M54 swapped Schwartz Convertible
No longer with me:
E46 2001 330Ci Titanium Silver
E32 1993 740iL Lazurblau
E34 1992 525iT Kashmirbeige
E34 1990 535/5 Cirrusblau - Former Miller Performance Stage 2 Test Mule Car
E34 1989 525i Cirrusblau - the Slug
E21 1981 320i w/ M20 swap Arktisblau
E21 1979 320i Turmalingrun
You were lucky! Unfortunately I was not when I recently worked on a VW Jetta 2.0. While attempting to remove the sparkplug from cylinder #4, the plug broke off at the base leaving the threaded portion behind. Fortunately I was able to remove the threaded portion using a four-cornered easy-out.
Per VW instructions, the threads on the new sparkplugs were coated with copper-based anti-seize before being installed. Steel threads in an aluminum head is a bad combination unless the copper-based anti-seize is used.
The funny thing is that it was a non-issue until platinum plugs came out. Before that a set of plugs would last 25-30k, and you'd replace them. Now you have plugs that will do well over 100k and still function. Most manufacturers have service procedures now to remove the plugs before 50k, lube the threads, and reinsert the plugs, to keep them from permanently corroding into the head.
I broke the plug off at the base of a brand new NGK plug when intalling it in her old E30. NGK were quick to confirm what size of reverse tap I needed. I did wonder how they knew so quickly - a fault with the materials they now use? Not that it is right, but I have never used a torque wrench on a plug in 40+ years.
(For those in the UK, you may now whistle the Hovis theme)
