Page 89 of 280 FirstFirst ... 3964798081828384858687888990919293949596979899114139189 ... LastLast
Results 2,201 to 2,225 of 6981
Thread: Butters project GO-FAST (LOUNGE STYLE)
  1. #2201
    Apr 2009
    norcal
    a few e30s
    So I got the right belts, new vcg and mechanical fan. Stewart wp is on. Progress is being made.
    Also got a fan shroud.
  2. #2202
    NY
    skateboard
    ― George Orwell
  3. #2203
    Manchester, N.H.
    96 332IS 6466 turbo
    Well, car is officially going
    na-nights till April/May
    Time to get to werks
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  4. #2204
    Upstate
    E28
    NA? As in sadness?
    Shipping guy dropped off this cumbersome paperweight on my desk today.
  5. #2205
    Apr 2009
    norcal
    a few e30s
    It lives!
  6. #2206
    Manchester, N.H.
    96 332IS 6466 turbo
    MilkT , your box is full.
    1996 332IS
    Built 3.2
  7. #2207
    South Carolina
    2004 330 vert 2004 X5
    Anyone looking for an m3 shell? This one runs and drives. Ugly seats but a decent price.
    https://westernmass.craigslist.org/cto/4777566534.html
  8. #2208
    Apr 2014
    Manchester, NH
    1994 325is, 1993 K2500
    Quote Originally Posted by flyfishvt View Post
    Hell of a dye job on those seats.
  9. #2209
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Quote Originally Posted by Butters Stoch View Post
    Cleared,
    cleaned
    and prept to sift thru the 8-10 nut hugglers' def-mechs
    and the 8-10 folks who KNOW what he is.
    I'm surprised it took THIS long for eyes to open.
    Grandma's made a list of things she's thankful for...
    and
    Grandpa made a list of things that piss him off.
  10. #2210
    Apr 2009
    norcal
    a few e30s
    Pressure washed the top of the engine bay and then put the car in the air and got underneath. It's amazing how much grime and stuff collects from driving. It's all nice and clean now.
    How much of a pita is doing the motor/trans mounts? They look pretty inaccessible without removing a bunch of stuff.
  11. #2211
    South Carolina
    Motor mounts are cake. Trans mounts should be easier than an oil change
  12. #2212
    Apr 2009
    norcal
    a few e30s
    Are you sure? Compared to the e30 they seem like a pita. The oil change on the m was cake. Maybe I've been spoiled by e30s. Hmmm
  13. #2213
    NY
    skateboard
    Quote Originally Posted by milKt View Post
    Cleared, cleaned and prept to sift thru the 8-10 nut hugglers' def-mechs and the 8-10 folks who KNOW what he is. I'm surprised it took THIS long for eyes to open. - - - Updated - - - Grandma's made a list of things she's thankful for... and Grandpa made a list of things that piss him off.
    How are grandma , and grandpa's cats doing ? Still stiff as a board?
    ― George Orwell
  14. #2214
    Northern ca
    97 M3, 85 318i
    Tunes are apleanty and the car runs better than ever, yet I still am only seeing 6psi. I had to bridge the grounds for the 803 maf and boom! Magic maf-ness and smooth idle and part throttle. Wot is also fun, but gets rich past 6psi as motor is looking for moar boosts. Dohc will know dammit.
    Custom Stage 3-ish RMS supercharged E36 M3/4/5
    Frankenstein e30 318i commuter
  15. #2215
    South Carolina
    Quote Originally Posted by dohcdoh View Post
    I recommend draining the radiator and disconnecting the rad hoses from the tstat housing. It allows you to jack up the engine easily without stretching the hell out of those hoses. Spray penetrating oil on all 4 motor mount nuts the day before. I've done motor mounts on a few e36s. It really is simple. Working on an e36 is usually a lesson in extreme patience. Motor mounts aren't like that. I use a swivel joint and a 16" extension on one side. Just a 16" extension (no swivel) on the other. That'll get the top nuts off. Go up through the big hole in the control arm to get to the bottom nuts. Couple hours max and you're done. Inspect your passenger mount and make sure the heat shield is in good shape before you start. Order a new one if it looks nasty.
    Ever done a front wheel bearing on an e36? Yeah it's that simple.
  16. #2216
    Apr 2009
    norcal
    a few e30s
    Quote Originally Posted by Tristo View Post
    I want a ride, dude.
    I recommend draining the radiator and disconnecting the rad hoses from the tstat housing. It allows you to jack up the engine easily without stretching the hell out of those hoses. Spray penetrating oil on all 4 motor mount nuts the day before. I've done motor mounts on a few e36s. It really is simple. Working on an e36 is usually a lesson in extreme patience. Motor mounts aren't like that. I use a swivel joint and a 16" extension on one side. Just a 16" extension (no swivel) on the other. That'll get the top nuts off. Go up through the big hole in the control arm to get to the bottom nuts. Couple hours max and you're done. Inspect your passenger mount and make sure the heat shield is in good shape before you start. Order a new one if it looks nasty. Ever done a front wheel bearing on an e36? Yeah it's that simple.
    Nope this is my first e36. I've worked on e30's and e34/32, one x3. That's my BMW experience. Damnit I just replaced the radiator and hoses, filled with fresh coolant. Hahaha oh well.
  17. #2217
    NY
    skateboard
    Pre-mixed coolant?
    ― George Orwell
  18. #2218
    South Carolina
    I drain it into a clean container then I use a cone filter from my auto paint supplies when I pour it back in. If that filter is good enough for auto paint it's good enough for coolant
  19. #2219
    Apr 2009
    norcal
    a few e30s
    Quote Originally Posted by GG///M3 View Post
    Pre-mixed coolant?
    No I'm not a sucker.
  20. #2220
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I would not drain radiator to change motor mounts. No need.
  21. #2221
    NY
    skateboard
    Why not all of the kool kids are doing it? It's like installing Pistons from the rear...
    ― George Orwell
  22. #2222
    Jul 2011
    Dell Rapids, SD
    2-97 M3 sedan, 2015 STI
    I just picked up my instrument cluster jumper cable from the dealership. Any one in the lounge ever used it before?
    THE TIME DRAWS NEAR!
  23. #2223
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by spenka View Post
    Huh ? Jumper cable for what ?
    1996 332IS
    Built 3.2
  24. #2224
    Apr 2009
    norcal
    a few e30s
    The instrument cluster.
  25. #2225
    NY
    skateboard
    What did that cost?
    Gotta be cheaper then this.
    ― George Orwell
