There has been a lot of discussion recently about turbo cams and I thought it would be good to kind of compile the information in one spot. I am hoping this will be a good reference thread...so please don't gum it up with typical BF.c arguing.
I scanned a few pages from the book Forced Induction Performance Tuning A Practical Guide to Supercharging and Turbocharging by A. Graham Bell and posted it below. I think its a good starting place, but as usual all engines are not created equal and do not respond the same to the same modifications. The amount of back pressure you have in your system is key to choosing a cam which works well!
Hopefully we can draw in some of the more knowledgeable people to give their insights as the information posted above is a bit dated (although I think still relevant).
Here is a website with some decent info:
http://www.hamotorsports.com/cam-gear-tuning.html
- To increase overlap, you have to retard the exhaust, and/or advance the intake.
- To reduce overlap, you have to advance the exhaust, and/or retard the intake.
Simple cam tuning rules for boosted engines:
- Advance intake and exhaust => more low-RPM power, less high-RPM power
- Retard intake and exhaust => more high-RPM power, less low-RPM power
- Less overlap => lower EGTs, faster turbo spool, less fuel
- More overlap => higher EGTs, slower turbo spool, more fuel
Boosted engines don’t like overlap. The incoming cold air and fuel cools down the outgoing exhaust charge, condensing the exhaust gasses. This is VERY counter-productive in a turbo application since the engine needs no help from scavenging to fill the cylinder. I've heard this being called "turbo chill".
Cool, condensed gasses in the same space push less hard on the turbo, causing lag. HOT gasses are better at spooling the turbo, thus the advanced exhaust timing to open the valve sooner in the power stroke. This steals some of those hot, expanding exhaust gasses to help spin the turbo a little faster. When the piston is near the bottom of the bore, hardly any energy is going into rotating the crank anyway, so stealing expanding gasses won’t hurt anything. The retarded intake just helps cut down the overlap further.
Past threads with some good discussion:
Schirck cams versus stock S52 (Turbo application)
Originally Posted by shaeffOriginally Posted by DefOriginally Posted by TedBOriginally Posted by dcvee
| 3 Turbos | All Else Being Equal | Testing Thread | DYNO SHEET COMPARISON |
Originally Posted by Paul BurkeOriginally Posted by Paul BurkeOriginally Posted by Paul BurkeOriginally Posted by Paul BurkeOriginally Posted by wazzu70
Are you looking for manufacturers and cam specs or discussions on how camshafts work?
More looking for info on what works best and why for informed selection, but Its also helpful to know where to buy said cams. I have no association with any vendor or manufacturer.
Manufacturers (from billet or blanks):
Catcams
VAC Motorsports
Paul Burke (through Miller)
Bavarian Solutions
EVOSPORT
Manufacturers (reground or unsure):
ICS
Elgin
Colt Cams I think these are billet...someone please confirm.
Metric Mechanic
Web Camshafts
If anyone knows of other vendors/specs PM me and I will add them in this post to keep things clean.
Colt Cams, Hopefully to soon be supported by a certain tuner on here.
2002 325i Silver Metallic Sedan/Manual - Modding Every Day
- Street Stars Motorsports -
- Bimmerworld Dealer
- UUC Dealer
I like the idea of this thread. It may be a good idea to drag all the info that people have into this thread so that a simple search can find it here.
I am in the market for some turbo cams right now . I will be installing my head soon and want to install them at the same time.
I would think that Colt Cams would be buddies with Miller since they are practically neighbors.
Sent from my GTX3582R
I've never heard of catcams.
This is my signature....
Neither have I.
Should add Metric Mechanics to your list.
http://www.metricmechanic.com/produc...ft-head-parts/
I have a feeling ICS uses colt since they are the only ones here doing regrinds and it was eluded they come from "Vancouver"
We don't use colt because they only do regrinds and do not have any masters for BMW anyway. There is a difference between a regrinder and someone who makes/programs masters for production use.
sent from my iCrack, forgive the auto correct
Years ago I had talked to Colt Cams about grinding some cams for me and the guy spoke very highly of himself. I didn't end up using them.
And do you have any turbo cams in stock yet?
im using paul burke cams .
i got these parts for sale
front corner light for a 4 door E36 $20plus shipping
headlight eyebrows $20 plud shpping
M3 OEM radiator $100 plus shipping
M52 cams with trays high miles $150 shipped
M3 front calipers $150 plus shipping
18x8 offsed 35, front 18x10 offset 40 rear bsa motorsports wheels $400 plus shipping
obd2 valve covers $50 plus shipping
intake manifolds $50 plus shipping
estoril blue doors of a 96 M3 2door $200 plus shipping each
rear glass $50 plus shipping
rear trunk lid $150 plus shipping
new 1/4 is 800 ft away ))
Does brody or anyone want to provide info on regrind cams? Seems you should stay away from them or no?
Follow my builds on youtube and IG.
www.youtube.com/thenameskam
@thenameskam on IG
Regrinds are not necessarily bad, they are just more limited in what can be done with them. The outside of the cam lobe is hardened to resist wear, and if this is ground through to create the new lobe profile the cam must be re-hardened. Sometimes there are issues with the re-hardening and cam lobes can go "flat" or lose their profile due to being too soft. Also to create the new profile material is welded onto the cam lobe and then ground to the proper shape before hardening. There can be issues with this process too.
Billet cams just have less chance of issues and more options with regards to grinding them. They are the ideal but regrinds can be cheaper so thats why people choose regrinds over billet most of the time.
Just because you have a regrind cam does not mean you will have issues. I have a set of regrind cams in my car, and I am the third owner of them so they have seen plenty of use. I didn't have the budget for billets so I took the poor mans route
Regrinding cams has been going on forever and with everything there are successes and failures to be seen. I have used many regrinds over the years without issues and have been using a set of 'supercharger cams' that are a set of S52 cams reground by Elgin Cams. The regrinds look as new with no issues at all. If a cam is going to give you an issue it will usually happen fairly soon after the regrind or billet cam has been installed. The failures are from spalling where the hardened surface breaks away from the softer metal underneath.
What are the usual price ranges for regrind cams? It was mentioned that it was fairly cheap.
@thenameskam on IG
To regrind a cam can cost $250 to $300 per cam.
Should we post up good durations and setups for turbo cams for our cars?
@thenameskam on IG
Thats the point of the thread. The point is theory, not just who sells them. Google answers who sells them, theory answers which ones make sense and will be beneficial.
I would love to play here but these threads get trashed to early in the game for me.
I understand but am not into the politics of " YOUR NOT A PAYING VENDOR SO YOU CAN'T ", which prompts me to say the following.
If I start a real engine builder type website for BMWs along the lines of Yellow Bullet or Speed Talk would any of you be interested?
This would be a site dedicated to crafting BMW performance engines, no advertising, no Bull crap, NO TROLLING!
Paul
+1
Under the knife: EMS pro standalone, wasted spark, twinscroll manifold with hybrid HX35/40 turbo, GC coilovers, E34 m5 brake conversion.
