I completely understand how a tune can be proprietary and it is appropriate to respect their work but I don't understand how you can encrypt the data/change it's location or otherwise jigger with the data without including the decryption/reader in the binary that you are providing the end user as well.
Hand the end user the binary and the data to run on their pre-existing hardware to drive a pre-existing system pretty much precludes meaningful encryption unless you add some kind of hardware dongle and smear it with resin so it can't be buggered with.
97 BMW M3 (s52b32) - VF-Supercharger kit ( Vortech V2-SQ supercharger, 32 pound injectors, VF tuning ), VDO/LeatherZ Gauge Kit (Oil Temp, Oil Pressure, and Boost), UUC Motorwerks RSC36 Exhaust, Stainless Steel 6-2 Exhaust Headers, Bilstein Sports, Rear Adjustable Camber bushings, Wheel Spacers 10mm in front 25mm in back, Uprated Clutch, UUC Shift Knob, Short Shifter and Clutch Stop, Cross Brace, Mason Engineering front strut bar, Contour Wheels, Euro Ellipsoid (Angel Eyes) HID Headlights, braided steel brake lines, aluminum thermostat housing, mishimoto aluminum radiator and silicone hoses and a partridge in a pear tree
When are the rest of the BMW guys who have used the TUNER Pro forum to learn how to chip tune our DME's gonna come out and start "vending" tunes to the community.
Competition will bring the prices down,
motivate more DIYers to self tune &
and offer more fascinating carnage.
UPDATE:
The Plan in Chronological Order:
1) Figured out my dual Walbro 255 fuel pumps were failing.
2) Due to the AFRs dipping into the 13s for a second at WOT on the dyno (because my Walbros were beginning to fail NOT due to tune) decided to do a compression/leakdown test just to be absolutely certain there was no issue in order to move forward with testing. ES MUY BUENO! No change at all from after original break-in procedure years ago.
3) Upgrading to Walbro 450 single pump with brand new stock fuel pump hanger.
4) Back to 3" MAF piping and matching Roadkill 80lb injector tune (already all installed) to get a base dyno at 18psi to compare to previous t4 open .58 a/r 6262 18psi TRM Dyno on Dynojet.
5) Cranking up the 3" MAF piping and matching Roadkill 80lb injector tune with t4 open .58 a/r 6262 about as far as that MAF can handle on Dynojet.
6) Switching to 3.5" MAF piping and matching Roadkill 80lb injector tune in order to get a baseline dyno at 18psi swapping in to test the t4 open .68 a/r housing on the 6262. Then cranking up the boost until she stops making power.
7) Swapping in to test t4 open ATP .82 a/r housing on the 6262 in order to get a baseline dyno at 18psi. Then cranking up the boost to the max to test said turbine housing.
8) Thinking about installing meth injection HFS-3 system (already have components sitting and waiting).
Race gas?
How much boost was Luke (gt35rm3) running with pump and meth? I think it was like 23psi...Originally Posted by highboostingm3
Just thinking, I remember when you were dreaming/thinking about 80lber stock dme tunes. Now, they are a reality.
Sent from my iPhone 5 using BF.com
This is my signature....
I ran 26 psi with pump and meth.
-Luke (aka gt35rm3)
See, that's plenty...Originally Posted by maximumpsi
Are you seeing this Cam?
Btw, what are you doing up in the NE part of the country?
Yes sir! 80lb on stock DME was a dream and is now a reality.
Almost makes me want to try a bigger turbo but no...must...control...urge...!
Thank you. That works. How big of a nozzle or nozzles?
So no care that I am going to be testing two more turbine housings for the good of BFCFI? Might as well save my money then jeesh.
Cameron, you are awesome. I can't wait to see how the ATP .82 is.
HahaOriginally Posted by highboostingm3
Well I have to thank a BFCFI friend who is letting me borrow it simply for this test for the good of all. He might not get it back though.
Just messin' he will. I might have to purchase one though if it ends up being too much awesome.
Lmao!Originally Posted by highboostingm3
I should ride all the way out to California, so I can fill up my depends.
Noice
Turn up the boost on that 3794!!! 30psi and you will see what that thing can do...it's not even half awake at 18psi.
Then:
Arctic Silver E36 M3 Turbo - Built S52 + T76
Cosmos Black E36 M3 Turbo - Built S52 6766 Torque Monster
03 Evo 8 973whp/653wtq 9.9@147mph (@818whp)
94 Toyota Supra Single Turbo 1000hp+++
Now:
2013 F30 335i M Sport - 6 Speed Manual - stock!
Already sold that turbo. Too expensive to be running around on 30+psi without e85 all over at the pump.It's not 2004 anymore.
The testing is pump only which is 91 octane in my location and in most of the nation. Hence 18psi max.
Exactly. However the 3.5" wasn't an issue. My failing fuel pumps were. I will be back to a 3.5" testing soon enough yet not in this thread.
So why did you even buy a turbo that is designed to run over 30-40ps??i, test it at 18psi and sell it? What was the point?
There are plenty of ways to extract more power through a 3" MAF, you can clamp the aiflow signal and run strictly off of VE. Or you can even integrate a MAP sensor which uses a switchover point, which then continues airflow readings off of the MAP after a certain frequency. But what do I know? I just tune cars all day. Just saying.
Then:
Now:
Though your pumps may have been failing,
we still know NOTHING of a BMW PMAX blow thru tune working (or showing significant GAINS) on anything larger than 3" MAF tubes.
The mystery is unsolved and speculative. Looking forward though. You can guinea pig for Gjon, Ryan and others to be able to join the 700whp Klub, in addition to the Evangelist Elite club
According to Forced Performance on the phone, the HTA turbos aren't just for high psi. Also, 30-40psi is pushed on the EVOs as they are 4-cylinder with less displacement. Bought the turbo, hoped it would be better, it wasn't, changed to different turbo, end of story. Thanks for being appreciative of the 18psi pump testing with different turbo configurations.
Yes, there are other ways to make a 3" MAF work using those techniques. Maybe I would rather just try to go 3.5". My own personal choice. Doesn't matter for 18psi tests. That is for another thread if/when I decide to try higher psi.
True, we still do not know if there was any gain on the 3.5" MAF in higher psi or not with comparable dynos on Dynojet. Time will come, step-by-step. First the swap to the larger single Walbro, then after testing more turbine housings, change to 3.5" MAF then test. That is for another thread though.
I don't care about the 700whp Club myself. A number is not a goal for me. I would rather see what this turbo can max out at one day and see how wide and flat the torque curve can be. Again, just my personal choice.
From I am told by George the FP turbos move a lot of air on lower boost levels over most turbos, such as the standard garret, the GTX and precision turbos.
They begin to light up around 20 psi and move quiet a bit if air from their on.
Jordan has 2 cars to tune very soon currently being built on 3.5 inch maf"s, time will tell along with results.
Happy Thanksgiving everyone gooble gooble !
ICS Performance Stage 1 soon. (He will not know what hit him when he drops the the hammer) FREE GGM3...
Thanks for your input. The turbos which seem to be fantastic pump gas/low psi turbos with the proper manifold like a Steedspeed are the GT4088R and GT4094R. Would be nice if I could borrow one of those suckers for testing. Older turbos still kicking ass over the newer technology.
Glad to hear Jordan has two more 3.5" MAF cars. Jordan is a great person, a very hard worker and does what he does very well. He calls me later than anyone and he is 3,000 miles away and two time zones away.
Especially if they are built at ICS, the results will be great because we will know that all other components will be set up correctly for that testing. I don't need to be a guinea pig. In fact, I prefer not to be. I just want to be able to run 30psi now and then. I don't care if it is an already perfected stock DME tune or a guinea pig tune, as long as it gets me where I want to be.
