Page 9 of 9 FirstFirst 123456789
Results 201 to 219 of 219
Thread: The M5 cluster retrofit
  1. #201
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Yeah check into the new thread with updates - this has all been nicely sorted out in the last few months by blacknight530i and Terra...
    The new thread really supercedes this one...
    http://www.bimmerforums.com/forum/sh...e-old-threads)
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  2. #202
    Dec 2010
    New York
    2001 740i sport
    Thanks geargrinder.
  3. #203
    Nov 2010
    Charlotte, NC
    03 M5/05 RR/06 Cayman S
    Quote Originally Posted by 6speedE38 View Post
    Does anyone know if a black faced M5 cluster with the "93s66 sw13" can be either recoded or replaced with a new chip. I know it is possible with the m35080 chips. I have googled to the end of google without any good results. I can't even right the VIN using PA Soft so I also have a tamper dot.
    I don't look at this thread much, but I wrote an entire DIY on how to do exactly this.
    http://www.bimmerforums.com/forum/sh...VIN-and-coding
    If you need help doing it, please PM and I can give you more information on it.
    Quote Originally Posted by Templeglantine View Post
    Thanks geargrinder.
    BTW, how's that cluster doing for you in your e38? I hope the pixels are holding up ok. Not getting any errors or anything, right? Let me know if you need any other help.
    -Paul
    2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers,
    Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread
    2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
    2006 Porsche Cayman S - Soul Performance Competition Headers and Exhaust, H&R Coilovers, 718 Boxster Spyder wheels, Rennline 35mm rear spacers
  4. #204
    Sep 2001
    Coral Springs, FL
    E21,E38,E39,F10 M5
    Just for anyone who stopped following this thread but worked with me years ago trying to get this done.. thanks to TerraPhantm, it has been done.
    A few shots of the cluster warming up:
    Stancing is for drivers trapped in an abusive relationship of their own lives.
  5. #205
    Feb 2015
    Puerto Rico
    1995 e36 325is coupe
    Quote Originally Posted by Manny G. View Post
    I have basically given up on this. I've gone in circles looking for the source that is feeding the current oil temp reading and what is causing it to read so high without an answer. The only things I've deducted is:
    1.) being able to read german when reading the coding of the cluster is a major benefit and could help understand the 'offset' that is calcluated when reading the oil temp signal.. where ever that signal may be in the IKE coding
    2.) the DME software needs to be modified to send the correct signal reading for the cluster to read accurate <- seems to be the taboo subject from what i've read here and other threads
    3.) buying an M5 is easier.
    Well there should also be a 4th option: getting the M5 DME.
  6. #206
    Mar 2010
    Quote Originally Posted by Mr Roman View Post
    Huge fail. First of all have you noted that you are replying to a 1yr old post, and that Terraphantm has sorted the issue and Manny is a happy camper?
    Second: M5 DME is completely different and won't run an M62TU ever. I mean you could theoretically make it work but it would be a task of stupendous proportions, starting with a custom one-off wiring harness, then continuing into months of coding and tuning basically using the M5 DME as a custom one-off SEM system. And there's no need/point to that.
    2003 M3CicM6 TiAg
    Former:
  7. #207
    Philadelphia, PA
    2005 M3 & 2004 330i
    Yeah, as geargrinder posted, that's not a real option. If you want to go through the work of getting the M5 DME working with a 540i, you might as well just swap the engine too. Or just buy an M5. Getting that DME to work on a 540i would take a considerable amount of time and effort, especially for those of us who don't have the backing of a large multinational car manufacturer and a team of talented engineers.
    But yeah, we've figured this out. All M62TUs can get the lights working without new hardware (besides the cluster itself)
  8. #208
    Sep 2001
    Coral Springs, FL
    E21,E38,E39,F10 M5
    Been working for me for over a month now, I love it.
  9. #209
    Aug 2009
    england
    e36 316i coupe
    How did you get it to work then?
  10. #210
    Aug 2008
    Panama
    E39 m52tuB30
    same here +1
    E39, 523i, 1999, M52TUB30, 5 SPEED MANUAL, UUC SHORT SHIFTER, EURO SPECS, KONI YELLOWS, OEM SPORTS SPRINGS, OEM SPORTS SEATS, ALCANTARA HEADLINER AND /A/B/C PILLARS, OEM M-TECHNIC AERODYNAMIC, OEM M5 FRONT GRILLS, OEM M5 REAR FOLDING MIRRORS, OEM M5 REAR SWAYBAR, OEM M-TECHNIC II FRONT SWAYBAR, REMUS DUAL TIP MUFFLER, TITANSILVER, BIXENON, M PARALLEL SPOKE 66 STAGGERED, OEM M-AUDIO SYSTEM, NAV SCREEN 16:9, INTRAVEE II iPOD INTERFACE, OEM TCM WITH BLUETOOTH, Y RESONATOR DELETE, INTAKE HORN DELETE, CDV DELETE, CHARCOAL TITANIUM BRUSHED TRIM, FAN CLUTCH DELETE, ELECTRIC FAN, 3.15LSD DIFFERENTIAL, ESS TS2+ SUPERCHARGER, AQUAMIST METHANOL + WATER INJECTION
    PANAMA, CIUDAD DE PANAMA
  11. #211
    Mar 2010
    Quote Originally Posted by jon316i View Post
    Really?!?!? You are that lazy / lame? Look up to post #203.
    Jebuz how people can waft into a thread and not bother to even read the last 5-6 posts before posting is amazing.
    2003 M3CicM6 TiAg
    Former:
  12. #212
    Nov 2010
    Charlotte, NC
    Really?!?!? You guys are that lazy / lame? Look up to post #203.
    Jdjg already has one working. He was saying +1 to that.
    -Paul
  13. #213
    Mar 2010
    Quote Originally Posted by blackknight530i View Post
    Ooops sorry looked like a +1 to the "duh did not read post". Fixing/editing.
    2003 M3CicM6 TiAg
    Former:
  14. #214
    Nov 2010
    Charlotte, NC
    Lol
    -Paul
  15. #215
    Aug 2008
    Panama
    E39 m52tuB30
    again, thanks bro..... what a great upgrade!! thanks!!!!
    everything work, just plug n play and thats it....
  16. #216
    Nov 2010
    Charlotte, NC
    Quote Originally Posted by jdjg View Post
    -Paul
  17. #217
    Raleigh, NC
    SR-71 Blackbird
    Pix or it never happened!
  18. #218
    May 2014
    Isa town
    2002 bmw 520i
    Can I do this I have low cluster on e39 2002 and retrofitted high instrument cluster
    so can I follow theses steps on first page and it'll work everything is work except abs light , wear pads sensor, airbag , oil sensor red pot
    so I think in your steps I'll change vin but I took this cluster from e38
    but hope that you reupload the pictures on the first page
  19. #219
    Sep 2018
    ARGENTINA
    BMW 540I6
    HI,
    My name is Federico and I'm new in this forum. I'm writing from Argentina so my english is very poor. I'm sory.
    I want to know if my instrument cluster of M5 can show me the lights red/orange and the oil temperature.
    My car is a 540i6 of 05/1997
    I bought the car with this instrument cluster but doesn't work complete.
    I have a BMWscanner, could be used to repair it?
    what would be the steps to repair it?
    Thanks!!
