Page 1 of 9 123456789 LastLast
Results 1 to 25 of 219
Thread: The M5 cluster retrofit
    Jul 2012
    Dublin/Ireland
    With wheels
    UPDATE: FEBRUARY 2014
    Since upgrading my OEM wheels from 17" to 18" my dsc light no longer comes up
    Must have to do with wheel's revolution/distance
    Settings related to this might be stored in the cluster or DSC module
    UPDATE: NOVEMBER 2013
    After a few more work on with other peoples e39, I noticed the following:
    The DSC light does not appear and works as expected if the IKE module (Cluster) is coded with NCSExpert only.
    What I did recently on a 1998 535i are the 2 steps below only.
    - Wrote the car's VIN number in the cluster (IKE module) using BMW Scanner 1.4 (Could be done with Tools32 most likely too but I have not tried on this cluster yet)
    - Ran NCSExpert in ExpertMode, select the IKE module, then selected the job to be : SG_CODIEREN then ran the job. This fixed the temp gauge/RPM. The car was manual so I do not know if this is enough to show the gear numbers if your car is manual.
    That's it. Those 2 steps only and everything works, except the oil temperature. No tamper dot. Coolant temperature/gauge working fine.
    I tried to recode my IKE module with NCSExpert, no luck, my DSC light still comes on after 2-3 miles and stays on until I turn off the engine. If anyone has a solution, please let us know.
    What car will that work:
    Any e38, e39 and e53 but it seems only TU engines with DME 7.x from 09/1998 are capable of sending the oil temperature over the CAN bus.
    Seriously?
    Well you can fit the M5 cluster on an older model, but you won't get the oil temp and nice red lights to light up on the RPM gauge.
    What do I need then?
    - M5 cluster.
    - A computer with XP/Vista/7
    - BMW Scanner 1.4 from PA Soft and the compatible interface/plug.
    - NCS Expert/Dummy and the usual BMW tools (Precise software and steps to be determined)
    - Screwdrivers to remove your cluster.
    - Access to a local specialist in mileage correction that has the right tools. The chip that contains the stored mileage, called M35080, can be recoded, with the right tool, not need to replace it.
    Most likely the cluster you are going to pick will have a different mileage than your own cars.
    The easy way: Autologic
    The hard way
    1. CLUSTER REMOVAL
    Remove your current cluster.
    [pictures]
    2. M5 CLUSTER INSTALLATION
    Install the new cluster. Once installed, turn your key in position 1.
    Voila, 1st look at your new M5 cluster. This is what you will see after you take the car for a spin. The DSC light will stay up, the coolant temp's needle will go up ton 3/4 (Don't panic this is normal, well for now), and the tamper dot will be on too. The fact the tamper dot is on is because the VIN coded in the cluster is different from the one in the LCM. The tamper has nothing to do with the mileage difference between the modules.
    1st observations:
    Is working fine:
    - Gas gauge
    - Speedo gauge
    - RPM gauge
    Is NOT working fine:
    - Oil temperature and red/orange lights around the RPM gauge: Not working. You only see the last 2 lights, which normally indicate the car can be driven at full speed.
    - Coolant temperature: Not reporting correctly. Goes up to 3/4. The reason why is that the M5 uses a double sensor to monitor the coolant temperature.
    - DSC light: Goes on as you as you drive a few hundred yards. Can not be disabled manually (By pressing the button)
    3. CODING
    Turn you key to position 2 and plug in your PC to the OBD port (I or II) and start your BMW Scanner.
    [pictures to be added]
    When you start BMW Scanner, you will be presented with the car identification screen.
    As you can see, the IKE information on the left contains this poor M5 data (I wrote over as I forgot to take a screenshot)
    The data will be highlighted in red too by BMW Scanner to highlight the difference from your IKE (Your instrument cluster) and EWS module (Alarm basically).
    As you can see, on the left you see the IKE data. It is showing your car is a M5 with S62 engine etc. Obviously it is not. So we need to change that.
    3.1 Go to the top menu: Units > IKE (Instrument cluster instrumentation in english).
    You will be presented with the following menu.
    Have your VIN number handy, the last 7 digits.
    Now click on Reprogramming on the left, the Used Module Reprogramming will then popup. Click on Write FGSTNR (No idea what that means). You will be asked to enter your VIN. Make sure you enter it correctly, then press ok. At this stage, the new VIN has replaced the previously recorded one from this poor dead M5.
    Now the cluster will "reboot" and the tamper dot has just vanished.
    The tamper dot is now gone. It was underneath the "miles" text in the middle of the cluster.
    3.2 Copy the ZCS info from your car to the new cluster. The ZCS is a unique identification code that matches the level of options your car had from the factory.
    Same idea as the step 3.1, click regrogramming then copy ZCS/FA. You will be prompted to copy from the car to the IKE and from the IKE to the car.
    Make sure you select "From the car to the IKE". Click ok. Again the cluster will reboot.
    3.3 Go back to the main screen of BMW Scanner. On the left column, click the Car identification. As you can see now, the IKE shows your actual car. Now the IKE is synced up with the EWS. In other words, the cluster now knows it is installed on a 540i
    4. MILEAGE CORRECTION
    Now, mileage correction. I don't have details on this, I don't have the tools. But I found a guy locally that has the tools. He had to take out the cluster in order to access the board of the cluster. The operation in total took about 30mn.
    Again, the chip(EEPROM) was overwritten. This is often thought to be impossible. Oh well, obviously it is.
    There you go, my cluster with the correct mileage of my car now (105k miles). The M5 cluster when installed had 141.700 miles recorded in it.
    4.1 ADJUST THE IKE CHECKSUM AND LCM MILEAGE
    Now you have 2 problems. The checksum of the mileage stored in the IKE is throwing an error because the mileage was changed (It seems to be checking with the LCM module too).
    The LCM module at this stage will have the mileage of this original M5 cluster before it was corrected. The sync up took place when you did sync the cluster to your car in point 3.2
    Here are the errors.
    In order to fix the second error "Data filling difference to central light module..." you need to enter the mileage you have now on your cluster.
    Go to Units > LCM > Reprogramming > Write odometer
    Now that the mileage has been corrected in the LCM module and after you cleared the codes, you will see this error will come up again.
    Go to "Reprogramming" > ... TO BE COMPLETED
    5. SHOW THE GEARS ON THE CLUSTER
    Let's show the gear indicator on the cluster (Steptronic for sure, not sure if manual car do show here normally?).
    In order to do that we need to do some IKE coding.
    Pretty easy.
    Go back to BMW Scanner > Units > IKE as shown below
    The click Coding data > Write coding data as show below
    You will then be presented with the following interface
    Tick the box on the top left called "Gear indicator via CAN"
    Take this opportunity to select the appropriate gearbox you have. For instance here "Steptronic" means "Steptronic 5 speed". But for some reasons it shows as 4 speeds in INPA. Am I wrong here?
    Select also the proper engine you have, 4, 6, 8 cylinders...
    Once you are done (DO NOT TICK BOXES YOU HAVE NO IDEA ABOUT), hit the Write button, it will take a good few seconds then your cluster will reboot (Yes really like a PC)
    Ok so now the cluster will show your gears with the Steptronic/Auto gearboxes (Do they show on manuals?)
    See the difference?
    WORK IN PROGRESS I WILL UPDATE THIS THREAD AS I PROGRESS...THANKS
    Feb 2010
    East Coast, USA
    540i 6spd (11/98)
    Fantastic, thanks for this.
    AquilaBMW's Avatar
    AquilaBMW is offline Mad Bimmerist BMW CCA Member
    San Francisco, CA
    BMWs / Chevy
    BMWPlanetdude - I could kiss you lad. I really could. This is the most information I have ever seen posted about the M5 Cluster Upgrade. Brilliant! Thank you very much.
    I have some questions:
    1/. Does the Oil Temperature Sensor / Dial work now?
    2/. Do you know if this same process will work on an E38 (740i). They have the same M62TU engine as the E39.
    Thanks again mate!
    Costa Rica
    Blown 528i, KE30, Pathy
    Just a quick correction: It's TAMPER dot, not 'temper'.
    Other than that, great deal of information pal! Usually this mod is done by guys that for some reason keep the secret to themselves. Bunch of a-holes.
    Resident Third World Country Advisor
    Oct 2008
    Bay Area
    1999 740IL
    '99 740iL "illest 7" | 16:9 NAV w/ MKIV | Bluetooth | Maintronic CP600BMW MP3 | Porn Lights | LEDs in & out | BMW Style 101 | Stanced - Hellaflush offset & slammed | AirREX Stage 3 air suspension | NEX BBK 6 pot 355mm front, 4 pot 350mm rear | custom intake & exhaust | steptronic conversion | AC Schnizter front lip & roof spoiler
    Jul 2012
    Dublin/Ireland
    With wheels
    Thanks guys, yes it is long overdue and people in the know never published a DIY. Money is involved, but coding a M5 cluster is NOT something you will make a living on...anyways.
    I will publish other info and pictures in the next few hours once I am back home.
    Berkley MI
    2009 C350
    You can actually adjust your miles for that menu on the IKE you have shown. If you see where it says "Write Odometer" click on that and enter your milleage in KM then save. No need for soldering and doing anything with other modules.
    As far as the oil temp gauge, I really don't know of anyone that's gotten that to work.
    Apr 2003
    Seal Beach, Ca.
    2003 540s, 2000 740s
    BMWPlanetDude, I'm not even thinking of doing this mod, but a big CONGRATS to you on sharing some info that quite a few people were/are really curious about.
    Excellent post, and I'm looking forwards to reading and learning even more!
    <== Steptronic Sealbeach740
    2000 740i sport: 74k Green/Tan chrome MPars, clear corners, quad brake lights, AIC hi-beams, Hoen fogs, 16x9 screen, MKIV, TFT LCD screen in back, license plate backup camera with "on demand" switch, iPod audio/video (CDC/iPod audio switching, iPod video on 16x9 screen), Basslink, gauge rings, ///M pedals, switched steptronic +/- shifting mode, E46 paddle shifter steering wheel, Dinan engine & tranny software upgrade, DDEs controlled via Euro fog light switch, painted calipers with "BMW" lettering, windows up/sunroof close via remote.
    2003 540i sport: 81k, Sterling grey/grey, MKIV Nav, PDC & CWP - Added license plate backup camera with "on demand" switch, paddle shift steering wheel, windows up/sunroof close via remote, Akebono's, painted calipers with "BMW" lettering, quad brake lights, iPod audio via AUX mode/video via 16x9 screen, BMW TV tuner, ///M pedals & gauge rings.
    Jul 2012
    Dublin/Ireland
    With wheels
    Quote Originally Posted by Vipsa View Post
    No you cant if the cluster has a 35080 chip, I would have saved myself 70 euro otherwise.
    BMW Scanner is unable to write over mileage when a 35080 chip is on the way.
    You can on older models though.
    Yes the oil gauge can work, it has been proven already.
    Stay tuned.
    Jul 2010
    Boston, MA
    2000 540/6, 2000 Z3M
    This is awesome!
    Own:
    2000 540/6 Speed Sport//
    '10 C350 AMG Benz Hong Kong
    History:
    '95 525I BMW Green USA SOLD
    '94 911T Gifted to Brother
    '94 530/5 Black Sold
    Los Angeles, CA
    Formerly 03' 540i
    THANK YOU
    Thank god someone finally made a DIY!...Now the price of used M5 clusters just skyrocketed XD.
    2003 BMW 540i [Sterling Gray / Gray]
    [Msport] [Mods from A-Z] [Two-Tone Interior]
    Stuff For Sale :
    All types of E39 OEM Used HVAC Buttons
    Other E39 Parts, see my ebay! [Click]
    Jul 2012
    Dublin/Ireland
    With wheels
    First post updated
    Mar 2011
    Litchfield, NH
    2001 BMW 540i, '94 325is
    I have the EEPROM programmer. It is pretty easy to use from what I remember
    2001 540i6 Sport
    Engine Mods: Dinan Throttle Body, Dinan MAF, M60 Intake Manifold, Dinan SC Bracketing, Dinan Crank Pulley, Vortech V2 SQ SC, water/air intercooled @ 9.5 psi, 2 heat exchangers, Intercooler piping by Wicked CAS, Vortech BOV, 42lb injectors, high flow fuel pump, Custom Tuned by ACE performance, Evosport power pullies Exhaust Mods: A1 Headers, Random Technology 100 Cell cats, Dynomax Race Bullet, Eisennman Quad Race, 3" Stainless Piping, AEM wideband Suspension Mods: Eibach springs/sway bars, Koni Sports, Powerflex, BMP strut reinforcements, Dinan Strut Bars Brake Mods: M5 Brakes, Stoptech stainless brake lines, Axxis Ultimates, Bav Auto Drilled/Slotted Rotors Transmission Mods: 3.15 with Quaife LSD , Z4M shifter, UUC Transmission Mounts, Clutchmasters FX300 Aesthetics: M5 bumpers, M5 Mirrors, M5 Trunk Lip, M5 Instrument Cluster, M-tech door sills, M-tech side molding, Style 65s with Michelin PS2s, 35% tint all around
    Jul 2012
    Dublin/Ireland
    With wheels
    Quote Originally Posted by Bricas45 View Post
    Keep it safe you might get it back to good use for local M5 cluster retrofit
    1st post updated again
    Last edited by BMWPlanetDude; 09-13-2012 at 06:47 PM. Reason: Automerged Doublepost
    Los Angeles, CA
    Formerly 03' 540i
    I have a slight uneasy feeling about showing reprogramming of the IKE & LCM.
    (Hint: Mileage)
    Stuff For Sale :
    Costa Rica
    Quote Originally Posted by Dking078 View Post
    (Hint: Mileage)
    Pretty much all the people that want to mess with mileage with "evil" purposes already know how to do it. I understand your point, but in reality anyone with the slightest knowledge of how go Google can find instructions. This is part of a very good DIY that can't be omitted.
    Aug 2008
    Panama
    E39 m52tuB30
    So what about the coolant gauge, the oil temp gauge and the yellow/red leds in the cluster?, how do you do to make it work properly?
    E39, 523i, 1999, M52TUB30, 5 SPEED MANUAL, UUC SHORT SHIFTER, EURO SPECS, KONI YELLOWS, OEM SPORTS SPRINGS, OEM SPORTS SEATS, ALCANTARA HEADLINER AND /A/B/C PILLARS, OEM M-TECHNIC AERODYNAMIC, OEM M5 FRONT GRILLS, OEM M5 REAR FOLDING MIRRORS, OEM M5 REAR SWAYBAR, OEM M-TECHNIC II FRONT SWAYBAR, REMUS DUAL TIP MUFFLER, TITANSILVER, BIXENON, M PARALLEL SPOKE 66 STAGGERED, OEM M-AUDIO SYSTEM, NAV SCREEN 16:9, INTRAVEE II iPOD INTERFACE, OEM TCM WITH BLUETOOTH, Y RESONATOR DELETE, INTAKE HORN DELETE, CDV DELETE, CHARCOAL TITANIUM BRUSHED TRIM, FAN CLUTCH DELETE, ELECTRIC FAN, 3.15LSD DIFFERENTIAL, ESS TS2+ SUPERCHARGER, AQUAMIST METHANOL + WATER INJECTION
    PANAMA, CIUDAD DE PANAMA
    Jul 2012
    Dublin/Ireland
    With wheels
    Quote Originally Posted by jdjg View Post
    Work in progress my friend, it takes time to figure those things out. There is no DIY out there remember?
    Stay tuned.
    Aug 2008
    Panama
    E39 m52tuB30
    Quote Originally Posted by BMWPlanetDude
    Stay tuned.
    Ok!!! Cool....
    Morgan Hill
    88' M3, 91' M5
    very interested. best of luck to you and thanks for the diy!
    Jul 2011
    Atlanta, GA
    1997 BMW 528i
    Does the speed read correctly? From what Ive read before, it may read incorrectly.
    United Kingdom, Hampshire
    BMW 530d SE
    brilliant.
    Mar 2011
    Litchfield, NH
    Quote Originally Posted by awhebel
    If it is coded correctly it should read fine
    2001 540i6 Sport
    Jun 2005
    Temecula, CA
    1997 540i6, 2009 135i
    Excellent write up and pictorial - thanks for sharing! I would make this change in a heartbeat if I knew it would work 100%.
    o 1997 540i6 o Dinan supercharger system o Dinan stage 3 suspension system o Dinan wheels o UUC EVO3 SSK/DSSR o SS Headers o M-Tech illuminated shifter o M5 3.62 LSD o Cubic trim o Gauge rings o OEM In-dash CD o Ultimate pedals o Hella AE's o M-Sport Steering Wheel o 400 RWHP o A/W intercooler o Killer Chiller
    England
    1999 E39
    Interesting thread mate. I long knew this was possible despite all the doubters that pop up on here whenever its mentioned! I've retrofitted high OBC in my E39 using a used cluster in much the same way, the only thing I wasn't sure about was the rev counter lights and the oil temp. There is a temp and pressure sensor next to each other on my 528, so its must be possible.......
    I love a good retrofit thread.....
