Currently trying to reset it but didn't work after 5 mins?
I have a 98 528i.......
I "hear from others" to disconnect the negative battery cable for at least 30 minutes. I did reset mine, but I left the cable off for 2 hours. Just my $.02 cents worth.
larrym3711
2001 540iA Sport
Two months, maybe three. OR ten seconds with the proper equipment. And if you don't have that equipment, how do you know it needs a reset?
/.randy
In my experience with my car -Whenever its off long enough to reset your clock. If i leave the cable off overnight because im working on it, it runs like crap for the next few miles until it readjusts.
~2001 540i/6speed~
Schmiedman M5 headers, SPEC stage2+ kevlar clutch, JBR 11lb lightweight flywheel, ESS Tuning m60 manifold software tune, 3" SS freeflow OBX catback, afe cold air intake, m60 intake manifold, Cdv delete, powerflex urethane sway bar bushings, M5 rear sway bar ,Autozone replacement driver side blinker light bulb, 545 short shifter zhp weighted, "dsc off" sticker, m5 3.15 lsd differential, m5 chassis rods, akebono ceramic pads, G2 caliper epoxy, ecs braided lines, BC-Racing br-plus series w/swift springs 8/6~On the night that I go back in time, you will be shot by terrorists. Please take whatever precautions are necessary to prevent this terrible disaster.
it varies, but its always longer than if you used the proper tool.
2001 330Cic/A in the same color combo is "Her" ride.
Interesting. I've disconnected the battery several times, most recently overnight when replacing the slip ring in the steering column. I did not notice that the car ran any differently after the job was done.
I store my RV for a month at a time with the battery disconnected - never noticed any difference with that, either.
It seems to only happen if i need to reset my radio clock.
~2001 540i/6speed~
If, after resetting the adaptives back to the default settings, the car runs like crap, there is something wrong. It is a testament to the OBDii standards that the system can cover for some problems like that.
/.randy
I will say that the time I changed all the chain rails, I had the battery disconnected for over a week, and things seemed to have been reset. It took me a long time to reprogram the NAV, MID, radio, a/c, seats, etc and set the coding for three drivers. We're talking hours to recode all that. I don't call that "free".... and it took the same equipment to do.
/.randy
my stereo went out on my 2001 740i. after 30 minute disconnect of negative cable everything works fine now.
Disconnect both positive and negative cables from the battery, then touch positive and negative connectors for 30 seconds, that will do it.
