The 5HP-30 (A5S 560Z) and the 5HP-24 (A5S 440Z) were used in the E38's production run.
The 5HP-30 is used in the 740's until 12/96 and the 750 until the end of the production.
The 5HP-24, which is slightly smaller, is used in the 740's from 1/97 until the end of production.
A little information on 5HP-24 vs. 5HP-30:
http://www.digest.net/bmw/archive/v9/msg05876.html
Your E38 has the green plate. Do NOT use the black plate fluid.
The "black tag" 5HP30 transmission is used in the M60B40 E32, M60B40 E34, and M60B40 840Ci. The green tag version is used in every E38 application of this transmission, as well as the M62 and M73-powered 8-Series. A technical engineer at ZF in Germany told me that the difference is due to the way the controlled converter clutch was used in the later (green tag) version. It would be safe to say that every E38 left the factory with ESSO LT71141, whether it has the 5HP24 or the 5HP30. As a side note, the "black tag" one uses Shell LA2634 fluid, which is an extraordinarily expensive semi-synthetic fluid created in a lab from petroleum-based molecules.
How to check the fluid:
http://www.bimmerboard.com/forums/posts/68013
A video on how to change the fluid by ECS Tuning.
http://www.ecstuning.com/BMW-E38-740...3/Video110-HD/
For the 5HP-30 (fluid change):
http://www.e38.org/zf-5hp30-service.html
Fill Plugs
The plugs are hex (allen) sockets. For the 5HP30, the fill plug is 17mm and the drain plug is 14mm.
More information can be found in the PDFs at the bottom.
The transmission fluid in these transmissions needs to be Esso LT71141 or an equivalent fluid.
More:
http://www.bimmerboard.com/forums/posts/800695
I would add some more specifics on current fluids that meet the LT71141 spec.
Royal Purple Max ATF DOES meet the LT71141 spec so it can be used too.
http://royalpurpleconsumer.com/produ...smission-fluid
Liqui Moly Top Tec ATF 1200
http://www.liqui-moly.de/liquimoly/p...oiladb=web.nsf
Kendall VersaTrans ATF is LT 71141 compatible as well.
http://www.phillips66lubricants.com/...dall+Motor+Oil
Link to ZF's Lifeguard5 fluid:
http://www.thectsc.com/index.php?p=p...d=14&parent=57
BG Universal Synthetic ATF
Valvoline MaxLife ATF is approved. PM me for a data sheet.
Mobil 1 doesn't list as LT71141 spec anymore.
**NOTE: Double check the fluid compatibility. Fluids may change.**
It's okay as long as it meets the LT71141 spec
It's recommended that you use the ZF Lifeguard5 fluid as it was made for these transmissions.
If you drain the fluid, about 6L will come out. It's always good to buy extra just in case. You can flush the transmission using the transmission oil cooler located on the driver side by the radiator (left hand drive vehicles). Due to the length of this thread, I'll provide a link to a thread that discusses this.In modern transmissions, the oil is a "component" that needs to match the different transmission functions and materials as perfectly as possible. ZF transmission oils are developed especially for the individual transmissions and adapted to their specific requirements. Off-the-shelf products usually have to meet the specifications for different units and therefore have to make compromises, preventing your ZF transmission from reaching its full potential.
http://forums.bimmerforums.com/forum...t=transmission
It's fine if you don't flush it. Here's a another video by Edwin at a ZF shop in Germany getting his transmission serviced.
Here's an excellent DIY thread on the flush.
http://forums.bimmerforums.com/forum....php?t=1945093
The filter should only be from either Filtran or ZF.
It can be purchased from the dealer.
For the 5HP-24:
http://genuinezfparts.com/index.php?...d=81&parent=35
For the 5HP-30:
http://genuinezfparts.com/index.php?...d=55&parent=30
(http://genuinezfparts.com/)
http://www.pelicanparts.com/euro/cat...Transm_pg1.htm
https://www.google.com/search?q=esso...&ved=0CMcBELMY
Rebuild threads:
http://forums.bimmerforums.com/forum....php?t=1845306
http://www.rangerovers.net/forum/6-r...-teardown.html
http://www.bimmerboard.com/forums/posts/490896
http://forums.bimmerforums.com/forum....php?t=1894113
http://forum.roadfly.com/threads/131...aul-DIY-Part-1
X5 threads (same transmission)
Very extensive Discussion about pressure Testing on freshly rebuild transmission, and lot of various pics on the clutch packs and transmission inert.
http://www.xoutpost.com/bmw-sav-foru...lt-issues.html
Rebuilding a 5hp24 high content and pics post
http://www.xoutpost.com/bmw-sav-foru...ng-post-2.html
Another 5hp24 complete tear down and rebuild post, TONS OF LARGE PICTURES individual clutch pack disassamble and reassamble including the oil pump and valve body no text on the pictures though and explaining on the selective shim and end float
http://www.xoutpost.com/bmw-sav-foru...st-time-5.html
A good discussion on the 5hp24 issues, and pics of a torn down 5hp24 torque converter
http://www.xoutpost.com/bmw-sav-foru...summary-4.html
5hp24 F clutch issues
http://www.xoutpost.com/bmw-sav-foru...roblems-3.html
5hp24 Fluid change
http://www.xoutpost.com/bmw-sav-foru...y-02-4-4i.html
Unrelated but a rare teardown of a 6hp26, (The 5hpXX successor)
http://www.xoutpost.com/bmw-sav-foru...eardown-2.html
Want to add a dipstick?
http://meurosport.com/5HP24_Dip_Stick.php
Information on disassembly, diagrams, how-to's (including how to refill/top off), etc., can be found on the PDFs attached. I would like to thank fellow member Mike in CT for the last three.
As for the shifters and the TCM
The step-tronic shifter does not allow accidental downshifts and upshifts to prevent over-revving and low rpm possibly stalling the car.
The ADAPTIVE programming (ATC) has it's own "winter" program that will automatically be selected when wheel slip is detected. *Winter mode is one of the NINE adaptive tranny programs that occur automatically based on driver or environmental inputs:
- extreme economy
- economy
- sport (adaptive)
- winter
- stop-n-go
- up-hill
- down-hill
- curve program
- cruise control program
When in "M" mode...the transmission starts & stays in the gear you have selected (which is only 2,3, or 4)...it does not jump to a gear that is not indicated (no 1st gear as you had supposed). *When in "D"...the tranny starts & stays in 4th gear
When in "S" mode (S2, S3, S4) the transmission will START in 1st gear and shift up to and down from which ever gear you have selected on the gear shift.
(Last six pictures courtesy of Qsilver7)
For US spec models, the step-tronic shifter is only available for the 1999+ 740i w/ the sport package, and 750iL. The 740i without sport package and the 740iL did not get it. Some Canadian spec non sports got the step-tronic shifter. Euro models had the step-tronic shifter from at least the 1996 model year.
PDF Index
-5HP24
-All transmission parts, part numbers, and how to assemble
-5HP24 Fluid Level
-How to change fluid.
-ATF Capacity
-How to change fluid + torque specs
-ZF5HP30LevelChecking
-Fluid change on the 5HP30/24/19/18
- Sean
RIP Blitzkrieg
