Originally Posted by
MozMan08
Well they haven't been working since I bought the car in March.. Headlights and signal lights do work.. I checked the wires on the LCM that's on the driver side correct?? The fog light button lights up too when I press to turn them on..
Sounds like the relay for the fog lights is bad. Easy fix and I'm 99% sure that's the problem. But, just in case I'm wrong, here's an easy way to test it out first:
You're going to need to check pins 2, 4, 6, and 8 on the relay. The relay should be behind the glovebox, top row, second from the right, and is usually green colored. The pin numbers should be printed on the relay or the socket. Start with Pin 2.
Pin 2 - With your foglight bulbs plugged in, check the resistance between Pin 2 and Ground. You should get a reading of about 1 ohm, but no higher than 5 ohms.
Pin 4 - Check the resistance between Pin 4 and Ground. You should get a reading of 0 Ohms.
Pin 6 - Check the voltage of Pin 6 with your key in the "ON" position. You should see 12V.
Pin 8 - Now turn your foglight switch to "ON" and have your key in the "ON" position and check the voltage. It should show 12V.
If you get different readings than this, specifically very high resistance, or no voltage on pins 6 and 8, your relay is likely bad. Honestly, the easiest thing to do would be to swap out another relay and test the fogs but this is the "technical way" to do it.
*** Former BMW master technician and custom tuner. Still maintain garage space at my house to work on customers' cars and can run full dealer-level diagnostics and programming for all model years through 2012 if you're in the Dallas/Fort Worth area. PM me.
* Looking for a clean 2005-2006 M3, 6-speed manual, in Imola Red. PM me if you know of one for sale.
