Im trying to figure out what caused my Z to lose the console and cluster lights simultaenously.
The ff. checked out (after reading a couple threads):
-all my console and cluster bulbs are functional / not busted.
-my headlight switch, dimmer rheostat is functional.
-all fuses are OK.
Im quite certain that the cause is a shorted wire somewhere. I checked out the cluster section and all the wires are clean.
Im suspecting the short is somewhere below the Radio (aftermarket), or the shifter console (non-illuminated knob).
Any advice on how to systematically track the shorted wire is appreciated.
I know we share some technology with the e30's, and on those cars these symptoms appear when the dimming switch fails. The one you pull to turn on headlights, and twist to dim interion gauges.
I have the same issue.... Could possibly be the shifter shorts out the dash... But I'm still unsure on how to fix it. I have tried toremove the shifter but contrary to all instructions, it doesn't pull right off.
I'm keeping an eye on this one
Most common cause is the wire for lighted shift knob breaking and shorting out.
PRICE CUT on ALL FABRICS
Spine911. Don't get mad, but please answer my Dumb Question. If there is a short in the dash illumination wiring, then it usually takes out the Rheostat. Mine went, after my Shifter illumination wire shorted out.
How have you tested the rheostat. ie. How do you know it is working and passing power to the lights.
If it is the Rheostat, then all cluster and console lights that dim run through the rheostat.
I'd start at the most obvious...The last work done....the Radio.
Remove the plug from the radio, and see if the short still exists, it could be the Radio illumination system. Did it dim with the rest of the gauge lamps?
If the short still exists then check for pinched wires around the radio.
Other than that... It's a real PITA to find a short in an OEM harness, other than pinch points.
Good Luck with the search, and BTW let us know when you do find the problem.
If it was the aftermarket radio, or it's install or something we should all be aware of.
