Page 1 of 37 123456789101126 ... LastLast
Results 1 to 25 of 912
Thread: Diagnostic program with realtime graph view
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Diagnostic program with realtime graph view. updated: 12th Sep 2016
    .. based on EDIABAS API with Qt GUI components. Project started as a sort of proof of concept with text-only output. Then I thought it would be nice to see something graphical too.
    To use TestO you will need to install Ediabas or just use the standalone version. Standalone version works without Ediabas.
    INPA shows multiple values in one screen but you can't for example see how's your lambda doing because refreshing that many values in one screen is slow. With this program when requesting only for one value at a time the situation is different as lambda voltage value is refreshed more frequently.
    You can download the zip from: http://phenoboy.kapsi.fi/testo. Unzip to any folder and just run testo.exe
    Standalone version is here: http://phenoboy.kapsi.fi/testo/testo...standalone.zip. Before running check EdiabasLib.config file and change your COM port.
    If MSVCP100.dll is missing you can get it by installing Visual Studio C++ redistributable package: http://www.microsoft.com/en-us/downl...s.aspx?id=5555
    It supports many engines: M5x,M60,M62,N54,S54, etc.
    This program has also file logger that creates a CSV file from selected values.
    'Faster live data' is supported for:
    MS41,
    MS42,
    MS43,
    ME7.2
    MS S50
    MS S52
    MS S54
    DME 3.3.8 (M60) -95 ->
    DME 5.21 (M73)
    DME 5.28
    DME 5.24
    It reads '(serial)' at the end of the ecu name which has support for enhanced live data stream.
    Program can detect your correct ecu which is suggested.
    Detect your ecu from file menu: File->Detect ecu->detect. After successful operation the right ecu will be selected automatically from the list box.
    Datalog taken with TestO with E34 540i/6 and shown by Megalogviewer. Acceleration on 3rd gear.
    data logging bmw testo
    DDE's live data logging is also supported. For example dde5 dde4 and dde6 have basic sets to show live data with gauges support.
    E34 540i/6:
    http://www.youtube.com/watch?v=OIKuDcqIVr0
    AEM demo:
    http://www.youtube.com/watch?v=3TYVD18ku74
    http://www.youtube.com/watch?v=YDwEU9v00oU
    PLX demo:
    http://www.youtube.com/watch?v=XNmrMtxSvDg
    Innovate demo: ( 2005 E46 M3 with a VFE Stage 1 Supercharger upgraded with CSL ECU software )
    https://youtu.be/_Ae2G_fIBZw
    My email is: phenotesto AT gmail.com
    Donations are appreciated. You can donate by clicking this button. Thanks. I appreciate it.
    E61 520d LCI
    Check out TestO - free datalogger for BMW. Includes support for: AEM, PLX, 14point7, Innovate (through SDK)
    Sep 2003
    Birmingham, UK
    M3 3.2 in bits and a 540
    I don't want to sound overdramatic, but unless you cure cancer next year, you might have just made yourself very famous for years to come as people have been wanting a data-output logger for years that would work with "obd1" type ECUs, plus it'll also record a lot of calculated data outputs.
    Giftschrank Projekt
    Mar 2011
    Redmond, WA
    02 330xi i || 01 X5
    Wow, this looks awesome and has amazing potential! Are you looking for testers?
    Yoy.
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Quote Originally Posted by enda320 View Post
    Quote Originally Posted by e36fiend View Post
    Thanks. Yes, testers will be needed. I'll try to come up with more usable GUI and then send a link to you. All that you can see in INPA or in tool32 can be shown in this program.
    Any hackers around ? It would be so nice to be able to read directly those .PRG files for getting all the names of the jobs but unfortunately they seem to be crypted somehow.
    What kind of features would you like to see in this program? Tell me what would be your typical use case ?
    E61 520d LCI
    Sep 2010
    england
    1998 bmw m3 coupe smg
    im willing to test on my euro m3 evo if that helps at all?
    Nov 2007
    Finland, Europe
    E61 520d LCI
    If someone's willing to test and report back findings with new feature requests just drop me a PM. It's still quite "clumsy" and not yet ready for public use. For examplle you will have to manually enter your DME prg and job/jobresult information. you will need to know how to use tool32 program which comes with EDIABAS/INPA. Luckily they can be found quite easily if you're into this kind of stuff.
    Info:
    It's still in early stages and you will have to manually insert the 'jobs' you want to view into the text file called 'jobs.txt'
    You will need to know what is the correct .prg file for your DME. For my M60 engine it's M60_338D.prg. PRG files can be found in c:\ediabas\ecu.
    jobs.txt contains info about "jobs". With the Zip file comes a jobs.txt version for M60. Copy and modify to suite your needs. First row tells the actual prg file (without .prg extension).
    M60_338D,M60 DME 3.3
    After comma comes free text (which is not used atm). Actual info about jobs should be written in CAPS.
    STATUS_INT,STATUS_INT_WERT,REAL,Lambdaintegrator #1
    STATUS_INT = job name
    STATUS_INT = jobresult name
    REAL = type (not used at the moment)
    Lambdaintegrator #1 = free description that is shown in the UI
    Double-click to open another window. A realtime plotting should start. You can pause it by pressing some key.
    E61 520d LCI
    May 2012
    England
    2001 M5
    Very interesting stuff. How did you find details of the API?
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Quote Originally Posted by Julian64 View Post
    You can find many pdf's under ediabas folder. It's all there.
    E61 520d LCI
    Jun 2008
    EU
    bmw
    Hi pheno
    What you think about "Ediabas Live Data" by /kokosafe/ logging program ?
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Quote Originally Posted by kanon View Post
    Hi pheno
    Hi,
    Never seen that before. It looks like it's using the same api than mine.
    E61 520d LCI
    Sep 2010
    england
    i can confirm it works on a 98 evo,what i can do or what it can do is my next question.
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Quote Originally Posted by jamie123 View Post
    Good to hear it's working. Thanks a lot for your help. Could you please post the contents of your jobs.txt in this thread or to my PM ?
    For now you can watch real-time data graph for jobs that you've entered in the file in their own window. That's basically it. Check the first post how I found a small vac leak with this program.
    E61 520d LCI
    Sep 2010
    england
    ok mate,thanks for taking the time to make this available for us,im going up the garage later to use it,will try and post some pics!
    Phoenix, AZ
    Which day of the week?
    Oh wow... I had no idea there was *actual interest* for this type of software.
    Jun 2008
    EU
    bmw
    pheno ! Very interesting work.
    Phoenix, AZ
    now we know that you have "no idea"
    Now that I do have an idea I'm thinking I should make my own thread.
    Sep 2010
    england
    well ive tried for 3 days on and off and i still cant get my head around how you edit the job file,gonna have to give in know till somone can explain how to in easy speak.
    Nov 2007
    Finland, Europe
    E61 520d LCI
    Quote Originally Posted by smooth11981 View Post
    I'd be very interested to hear more. :
    E61 520d LCI
    Phoenix, AZ
    I'm putting a quick video together, then I'll post.
    Edit: I posted the thread, but it has not shown up on the forum. Maybe the mods need to approve?
    Sep 2010
    england
    put it on you tube then post a link maybe?
    Phoenix, AZ
    It is on youtube, the post outlined everything... I posted it on e46fanatics as well, so take a look there I guess.
    http://forum.e46fanatics.com/showthread.php?t=925533
    Sep 2010
    england
    now that looks tasty! will it work on the e36 with ads interface? and the 64,0000 dollar question is... how do we get it?.
    great work mate.
    Orange County, CA
    E39it, 03 M5, E24
    Very interested in this. Keep us posted! Excellent work.
    E39 M5, E39 SC Touring, G30
    "Beating My Wallet" but loving it!
    Dec 2011
    Reading, PA
    2001 740i Sport
    That's pretty awesome. Nice work. definitely interested also.
    May 2010
    Sydney,NSW,Australia
    316 Compact
    Also interested in the logging system including adaption to the bikes
    Would be a fine addition to the tools and great if it was open source but would not wish to tread on your toes in any way, you have clearly put in considerable effort
