Hi,
I'm trying to install some component speakers on my friend's 99 E39 540i, no DSP. I'm running into some confusion with the wiring. I've done plenty of searches but nothing comes up that will confirm what I'm trying to do. The confusion lies within diagram I'm using which shows that I use the same color wire for the negative wires for the tweeters and woofers.
The stock audio has 3-way but I'm going 2-way. I'm also installing two amps (1 for speakers, 1 for sub) and a double din Pioneer dvd deck.
I found this wiring diagram but I'm not sure how I can wire my tweeter and woofer using the same negative wires from the amp 26 pin connector.
I also found this, which has the pin numbering, but it doesn't tell me the color of the wires.
Also, which negative wires should I be taping into for the front of the car where the speakers are? I see like 3 negative wires on each side that all look the same (for 3 speakers in the front).The pinouts for the 26 pin connector are:
PIN - CONNECTION
1- LH front woofer +
2- LH front woofer -
3- Not used
4- RH front mid-range -
5- LH front mid-range +
6- Not used
7- Not used
8- Not used
9- RH front mid-range +
10-LH front mid-range -
11-Right rear mid-range speaker/tweeter +
12-RH front tweeter +
13-RH front woofer +
14-LH front tweeter +
15 LH front tweeter -
16-Left rear mid-range speaker/tweeter -
17-Not used
18-Not used
19-Left rear mid-range speaker/tweeter +
20-Not used
21-Not used
22-Not used
23-Not used
24-Right rear mid-range speaker/tweeter -
25-RH front tweeter -
26 RH front woofer -
Thanks in advance.
So are you gonna sacrifice midranges?
Nope, why would I be sacrificing mid ranges. I'm using a double din Pioneer deck too btw.
Ok so the high range are going then...
Why don't you just upgrade all the speakers with something better, since you are using a Pioneer HU, with this alone, the sound quality will be dramatically improved already.
Also I am confused, correct me if I am wrong but you have the OEM amp already in the boot since your car is a US model, so it should be a matter of just swapping, with a few slices eventually.
Also speakers should be a direct swap too, I am not sure why you would need to get to other wires, since they are here already. If you need to install more speakers in the front as you seem to be saying, just extend the existing wires.
Maybe I misunderstood you somewhere along the way ...
I have All my speaker working on my double din Kenwood. I cut all the speaker wire from the factory amp in the back run all wire to the head unit. Then I added a bass blocker to all my speaker in the car and everything sound smooth...
I just replaced my speakers and amp (non-DSP) and found every reference to wiring was wrong.
I made this by tracing every wire to all the speakers.
You really don't need the front mid ranges as the replacement woofer and tweeter will cover the full range. (I used Boston Acoustics SC50's front and rear).
^WOW that's exactly what I was looking for and everything makes so much more sense now! Something that shows me both the color of the wires and the pins. Thank you so much!
Since there's not really a perfect DIY for something like this on here. I'll try to take some pictures of the completed wiring process once I'm done with the project.
Yes, I think you misunderstood my post almost completely. hehe. It's ok, the last poster gave me the info I needed. It's not my choice regarding the speakers. It's more of my friend's choice to buy a 2-way. I'm not sacrificing ANY high, mid or low by installing aftermarket speakers. The speakers will have full range since I'm putting in brand new 2-way speakers and taking out the old stock 3-way.
You're probably not the best person to post in this thread. If you can't offer help, the least you can do is shut it? TY!
Yeah, that's how I would've done it if I were to use the HU for POWER, but I'm actually using separates amps.
Because Running new wires is a b#tch to do.
I don't think I did, I know you were after diagrams and all, I just found the thing over complicated and was confused at the wires since mines were plug and play but again, our e39 in Europe are a bit different, those with the standard audio system do not have amps, ours are in the head units.
I did upgrade all my speakers with Alpine ones, and I find the quality being so much better with this upgrade alone. Now of course with an nice external amp it would be even sweeter..
Glad you are sorted out anyway.
Ahhh...did not catch that in the first post.
I am using two separate amps in my setup, but I bypassed the factory wiring and installed all new 14 ga. wiring. throughout the whole car. However, I still have a three way setup in the front and two way in the rear.
The factory wiring is pretty weak if one is to use quality amps that put out good, clean power. The only problem I have is the crappy sound quality from my Dynavin head unit.
I won't argue with you about the wires could be better and a heavier gauge for a more powerful amp. However I didn't bother changing mine (looks like a 2 day job), mine sounds very good. I'm using a JL Audio XD400/4 for all the speakers in the car and a powered sub in the trunk.
Great thread! Very informative!
Great info by JimLev !!
This would be so helpful to me if all 3 of my e39s were nonDSP! (all 3 have DSP) Great work nonetheless
Are SC55s the updated SC50s? If so, do they work well with the factory DSP crossover points?
2001 Aspen Silver 540i6 - 180k mi - 3" DUDMD Tune, aFe Intake, M60 Intake Manifold, Eibach Anti-Sway Bars (F&R), e60 SSK
