Results 1 to 25 of 38
Thread: LS1 Swappers - Check your fuel system.
    Mar 2006
    Memphis, TN
    95 M3, 01 330ci
    A good friend of mine had just finished his S13 240sx LS1 swap and was driving home from work when the adapter fitting from the GM fuel rail to the -6AN line decided it didn't want to hold on any more.
    Picture of the type of adapter.
    Mine in the lower right of the shot.
    Needless to say one of the best builds in the Memphis area went up in flames. Everything on that car was done by him, nothing except for machine work was farmed out... It was immaculate.
    We've been working non stop in our free time to help teardown the car and move what can be saved (rear suspension, engine, transmission, headers, and 3 wheels) to a new shell.
    Needless to say I went and checked my adapter fitting, while it seemed tight there was still wiggle room. I've ordered a billet fuel rail to eliminate this hazard.
    Be careful with your swaps... It's hard enough seeing a good friend's car go up in flames, I can't imagine what it would be like to watch my own.
    Some pictures of the car:
    Before:
    DSC_3521 by CaenAbel, on Flickr
    DSC_3574 by CaenAbel, on Flickr
    DSC_3539 by CaenAbel, on Flickr
    DSC_3596 by CaenAbel, on Flickr
    DSC_3605 by CaenAbel, on Flickr
    DSC_3641 by CaenAbel, on Flickr
    DSC_3524 by CaenAbel
    , on Flickr
    http://www.youtube.com/watch?feature...&v=7EK3gIeSkKo
    After...
    DSC_4070 by CaenAbel, on Flickr
    DSC_4098 by CaenAbel, on Flickr
    DSC_4104 by CaenAbel, on Flickr
    DSC_4122 by CaenAbel, on Flickr
    DSC_4125 by CaenAbel, on Flickr
    DSC_4127 by CaenAbel, on Flickr
    DSC_4129 by CaenAbel, on Flickr
    DSC_4133 by CaenAbel, on Flickr
    Then we setup a fundraiser because he's always helped us so now we want to pay it back.
    Be safe and have fun.
    May 2010
    Salem, OR
    2000 BMW 528
    What type/brand was it? Russel just came out with one that has a screw on cap that locks the line in for this very reason.
    Mar 2006
    Memphis, TN
    95 M3, 01 330ci
    Mar 2011
    Dallas, TX
    2008 535i
    There is a big post on LS1 tech about those fittings, several people have them fail.
    Russell knows about it, but won't recall them. Instead they redesigned the new ones to have a screw on retainer, but they still sell the old version as well, which is bullshit.
    Here is the new one.
    Mar 2006
    Memphis, TN
    95 M3, 01 330ci
    Here is the fitting, that is really a new one, didn't see it on their site a few weeks ago.
    Part Numbers:
    -6 AN Male to 3/8" SAE Quick-Disconnect Female with threaded retaining cap 644120 644123
    Edit: Kaane beat me to it... That is some BS for sure...
    Edelbrock has one as well...
    http://www.speedwaymotors.com/Push-O...Cap,59475.html
    May 2010
    Salem, OR
    2000 BMW 528
    Quote Originally Posted by Pzary3233 View Post
    This was a Russel, but not the new style.
    Scary. I'd donate $50 to help get his car back together, I'd be devastated if this happened to my car, so anyway I can help.
    ^^ that's what I'm talking about.... Should order me up a set.
    Mar 2006
    Memphis, TN
    95 M3, 01 330ci
    If you want to donate, Grip Royal has their Paypal setup to take funds as well as through their site:
    http://griproyal.bigcartel.com/category/fundraiser
    I'm ordering a few of those connectors as we type to get me through the weekend.
    Sep 2010
    Poland,ME,USA
    1998 m3 3/4/5 LS1/t56
    I have one on my car as well, Do they usually leak, or blow off all together? The other spot that scares me is where the single bmw plastic barb exits the pump, I know you used an lines for that, but my self along with many others have just slipped rubber hose over it clamped it. Every other spot i was able to use a single clamp but not there. The fuel pressure dosent increase much with the gm reg. over stock but anything can happen.
    Mar 2006
    Memphis, TN
    95 M3, 01 330ci
    Some leak, others like his blew.
    Mine I noticed a minute leak, so I have "grounded" my car till the new bits come in... which also means possibly missing a track day this weekend.
    Sep 2010
    Poland,ME,USA
    http://vorshlag.smugmug.com/Projects...gYmNB&lb=1&s=A
    I would really like to know what fuel line he used here, i asked him and he couldnt remember. Seems like the connection between hardlines and rubber are done very well.
    Mar 2006
    Memphis, TN
    95 M3, 01 330ci
    That looks like the crimped fittings, and the hose could be any of the good non braded push to fit style hoes.
    May 2010
    Salem, OR
    2000 BMW 528
    Looks like the filter has an on it and the 45* is an to socketless hose. The stuff is sweet, my dad did socketless for his entire fuel system in his camaro.
    Mar 2006
    Memphis, TN
    95 M3, 01 330ci
    Minneapolis,MN
    2003 M5, 2014 535i
    Those fitting have been failing people ever since they were introduced into market. There are several reports on LS1tech where these fittings came off and sprayed fuel all over the engine bay.
    Your friend however, is the first time I have seen the failure lead to a fire.
    If you must use quick connect type fittings, (which is inevitable if using the stock LS fuel rails and Corvette FPR), the Dorman ones are the only ones I'm aware of that are as safe as their OEM counterparts. I'm yet to hear a report of them failing. They are not pretty but they work well.
    I would not trust the Russell fittings even with the new design.
    Quote Originally Posted by birdman2447 View Post
    http://vorshlag.smugmug.com/Projects/BMW-E36-LS1-Beta-Project/2343546_tDJQQC#!i=259903323&k=gYmNB&lb=1&s=A
    They are made by Russell and they call them "Twist-lok" hose ends. They must also be used with the specific Twist lok hose
    2003 M5 LSx l 6 Spd Manual l 4.10 LSD
    Build Thread
    The chassis must always be regarded as a means to an end and never as an end itself
    357is (e30 w/LS1)
    We were going to use the Russell fittings; we bought one & test-fitted it to the GM fuel rail. It would not stay on if given a gentle tug -- just popped right off. We threw it away & got the Dorman fittings.
    E30-LS1 Swap Guide and Kits, email us at e30ls1@gmail.com !!! or check our website e30ls1.wordpress.com
    Oct 2007
    jacksonville, fl
    e36 m3 Ls2, 318I, 325is
    wow that sucks. thanks god he is ok.
    Upper Saddle River NJ
    MZ3, YUK DEN, FORESTERXT
    I was just about to put my fuel lines together.....I have the dorman fittings for the filter and russell quick connects for the fuel rail. Not sure I want to use this stuff now.
    Steve G. I sent you a PM regarding your CD..can you get back to me please
    00 MZ3 with LS2 /T56 swap (425rwhp/404Torq corrected to SAE), with oil cooler and 3 qt accusump, TCK DA, , 1.75 in Vorshlag Headers, RD Sways, Dinan Upper Strut, Turner Brake Cooling with Stainless Lines, DTC90 Pads, Fidanza LTW Fly Wheel and LS7 clutch and pressure plate, Hurst Shifter Hamann Kit, Digi tec Wing, Full grand am style cage from Deman MotorSports, New Age radiator, Lower temp alum thermostat, center 75d FCAB, Rear Camber and Toe plates, AKG 75d bushings throughout , SLR Roll Center / Bump Steer Correction kit, Turn one power steering pump and cooler, Rogue Rear Strut mounts, TCK Camber Plates, 18x10.5 wheels with Hoosier R6, Rogue Dual-Ear diff, Randy Forbe Reinforced Diff Mounts, adjustable sway bar end links, 500/700 springs, Custom Advanced Motorsports carbon fiber hood, carbon fiber roof, bumper cover, splitter and Dive Planes, Pole Position, lexan Windows, PBR C6 z 6 piston calipers with C6z rotors,custom dual master cylinder pedal box...
    Sep 2010
    Poland,ME,USA
    How easy is it to weld an AN fitting to the gm fuel rail?
    http://www.summitracing.com/parts/AR...8206/?rtype=10
    I wonder if the ID of this fitting fit up to the rail OD, if so i might try welding one on my rail, i am decent with the tig now
    May 2010
    Salem, OR
    2000 BMW 528
    Does dorman make quick connects to AN fittings?
    Mar 2004
    USA
    96 328is 6.0L
    Wow that really blows! Did he not have comprehansive insurance coverage for his car?
    I'm glad that I am using Dorman quick connects on FPR and GM OEM on fuel rail...
    Sep 2010
    Poland,ME,USA
    Quote Originally Posted by Jesus Freak View Post
    Nope, all there stuff is oem replacement orientated. I am thinking about upgrading my post FPR setup to all dorman. Piece of steel dorman line out of the FPR. The Dorman disconnect to there nylon line, to the fuel rail with another dorman disconnect.
    I am playing with the idea of buying one of the dorman nylon line tools and making up a post FPR fuel line to sell on the forum. It wold cost about $14 in materials. They give the buyer an option of wrapping it in one of these high temp heat wraps so when it sits near the header it wont melt.
    http://www.mcmaster.com/#standard-ca...eeving/=go9q7e
    May 2010
    Salem, OR
    2000 BMW 528
    That would be cool. I wanted to do AN from the tank forward, but didn't have time, I will eventually.
    Jul 2005
    Temecula Ca.
    99 M Coupe LS Swap
    That is heart breaking to see. Let’s hope the owner is able to overcome and rebuild one even better. As far as twist lock or push lock line fittings not using a lock nut, I can also report failure. I had an AN10 oil line blow apart at the block connection. I oiled down turn 8 at Willow Springs losing rear traction and exiting the track over 130mph. I was able to stop before hitting anything but the Porsche behind me did not fare as well. Summit Racing was stand up about the product and sent me all new lines and fittings of the standard braided line style. No issues since and 45 track hours on the parts.
    Dan "PbFut" Rose
    Feb 2010
    Bermuda
    Imola Euro Swap
    wow this, sucks....
    Apr 2009
    Sandy OR
    '97 M3 sdn, '00 528 sprt
    Tongboys LS1 E36 M3, Russel AN fittings, same failure. Post 122 in this link;
    http://forums.bimmerforums.com/forum...Samberg&page=5
    '97 Sedan, Cosmos Meconium, Click ME for the build thread.
