Results 1 to 10 of 10
Thread: Found a 1973 Bavaria .. questions
    Feb 2004
    San Francisco, CA
    1997 Z3 1.9l
    Asking for 3100, agreed in 2200
    car is 300 miles away
    2 weber 40
    auto
    interior is 7
    headliner is 10
    body solid .. no rust
    msd ignition .. push button
    now bad
    no door keys
    only rpm gauge don't work
    ac don't work
    car is burning oil, but no smoke
    owner commute 100 miles a day, 5 day a week, and he need to add a quart of oil
    questions:
    can this baby drive 300 miles until I take to a mechanic?
    cost to change and replace:
    ac, rings and valve seals, valve stem seals, valve cover gaskets, oil pan gasket etc ...
    1997 1.9l auto
    for all the info .......... George.....
    Silver Spring, Md.
    2003 530i 5sp,71 Bavaria
    Yes but
    The fact that it burns oil will not keep it from driving 300 miles. When you stop for gas check the oil and top it off. But check the other fluids like trans and antifreeze to make sure they are where they should be. Also check the brake fluid, The fact that the speedometer does not work is not a problem you will have to guess your speed based on cars around you. As far as the head job a machine shop can do this for maybe 800.00 Don't know about prices in your area. Hope this helps.
    Bainbridge,Pa
    1998Ti 1974 3.0csa
    From the looks of the rear bumper I'd say it's a '74 not a'73.
    Feb 2004
    San Francisco, CA
    1997 Z3 1.9l
    thanks for the info, fyi .. the speedometer works is the rpm one is not
    Quote Originally Posted by rustycoupe View Post
    ...... my bad is 74
    1997 1.9l auto
    Billings, MT
    2013 328i xDrive
    1 quart every 500 miles seems like a pretty significant amount to burn with no smoke at all. I'd venture to say it's doesn't necessarily burn oil, but rather leaks oil.
    I had an e38 that burned less oil than that, and it smoked pretty bad on startup, and went through a set of plugs about once a week.
    -Chris
    My e30 build thread/color change here
    Oct 2005
    Terre Haute, IN.
    '87 325is, '02 A4 3.0 Quattro, '95 Jetta City
    That car is def not going to make it that trip, don't buy it.
    What's his contact number?
    Just kidding, looks like a pretty good deal IMO even with excessive oil consumption. You do seem a little paranoid about the car though, it's 40 years old, it's gonna have issues. Doesn't necessarily mean it needs babied, just a simple oil check every time you get gas assuming you fill up.
    Nov 2010
    Palo Alto CA
    00 528i, 02 M3, 69 2800c
    Here's a decent bav in redwood city for you
    http://sfbay.craigslist.org/pen/ctd/2942163615.html
    awesome deal if you're into it.
    S
    Mercer Island, WA
    88 325iC,'11ML350,'84RX7
    That looks like a great deal! Now if there was an E9 for $2000 in that kind of shape...haha
    Tim
    Sep 2004
    Renton Highlands, WA
    E30x2 E34x2 E46
    That's looks like a nice E3. Hope it goes to an enthusiast.
    Boston, Ma
    86 635,72 E3, 88M6,73 E9
    Can you drive without a front bumper and not get pulled over? Apparently so in Ca but in Ma they would tow it out from under you.
    Rob E3
