Page 1 of 28 123456789101126 ... LastLast
Results 1 to 25 of 689
Thread: Who's E39 has more than 120,000 miles on the clock
    Jun 2010
    Gold Coast, Australia
    4 x Assorted BMWs
    Hi guys
    After reading a story here where a guy has over 400,000 km on his 540i it has me thinking just how many of us members have 120,000 plus miles or 200,000 plus km on there E39.
    Please post up a picture of your car with its model engine and a brief history of problems and make sure you let us know if it's auto or manual.
    Cheers
    Addam
    BMW I Own
    E24 1983 635csi Race Car Build (Schnitzer Replica) http://bigcoupe.com/phpBB2/viewtopic.php?t=21792
    E24 633csi 4 Speed Manual
    E24 635csi /// 1986 4 Speed Auto
    E24 635csi /// 1986 Getrag Manual
    E23 735i 1986 *** 4 Speed Auto
    My Business
    https://www.facebook.com/pages/BMWre...68407960016698
    DIY E24 Dash Removal
    http://bigcoupe.com/phpBB2/viewtopic.php?t=20630&start=0&postdays=0&postorder =asc&highlight=
    Elizabethtown, PA
    99 540i6
    232,000 M62 everything started failing, required LS swap.
    '99 BMW 540i6 L33 5.3, PRC Heads, E-force supercharged
    http://forums.bimmerforums.com/forum....php?t=1674320
    Dec 2011
    NJ
    02 540i
    Many of us are breaking the 120,000 mark easily considering these cars are 10+ years old.
    2002 540i w/ 132,000 miles
    Manual 6 speed
    Valve cover gaskets
    Water pump
    Power steering pump (the common broken mount issue)
    Auxiliary water pump (internal magnet wore out)
    Cuse, NY
    07/85-535i5 01/99-540i6
    Hit 120k yesterday
    (oOO\(|||)(|||)/OOo) /00=[][]=00\
    Dec 2009
    Manchester, NH USA
    2003 530i/5 2008 Hemi WK
    Just turned 120k on a trip down to Beantown this month.
    Running like a champ.
    Virginia
    1999 540i sport
    170,000
    Nothing changed in engine mechanically since 130,000
    1999 BMW 540i Sport
    Alexandria, VA
    E34M, E36M, E38
    Both of mine
    2000 BMW 740iL | 225,XXX miles | VW MAF | Bavarian Auto Coils | Timing Chain and Guides DIY Complete | M60 Manifold | BDC Polished Throttle Body| Custom Tuned | Performance Gearing 3.46 LSD| Magnaflow mufflers |
    |1997 ///M3/2/5 | 104,XXX miles | Boston Green Metallic|2006 X3 3.0 SAV|121,XXX miles| Silver|
    Los Angeles, CA
    Formerly 03' 540i
    1997 540iA -7/96- build @ 138K
    Mechanically sound..for now. Except the repainted side of the car is fading.
    The tranny is still good after all these years... cooling system is sound.
    Last repair: Front Bushings + rotors / pads
    It's been a good car, excluding the cooling system failures. I just know stuff is gona start failing in time.
    When these cars are working flawlessly, they're planning something..
    2003 BMW 540i [Sterling Gray / Gray]
    [Msport] [Mods from A-Z] [Two-Tone Interior]
    Stuff For Sale :
    All types of E39 OEM Used HVAC Buttons
    Other E39 Parts, see my ebay! [Click]
    West Michigan
    98 540iA (Prd 11/97)
    1998 540iA 4.4l M62 @ 130k miles.
    To see what problems she's had, search my threads.
    Nov 2009
    Pembroke, Mass
    2000 740i Sport
    2000 540i/6
    160,200
    Replaced - Alternator, oil pump, passenger side vanos/solenoid, Valve cover/timing cover & solonoid gaskets, power steering pump, final stage resistor.
    New Jersey
    E36 318is Boston Green
    2000 540i/6
    143,xxx
    Complete cooling system overhaul (all hoses,thermostat,etc)
    valve cover gaskets
    Oil pan gasket
    1 failed coil pack around 140k
    Currently waiting on ordered replacement water cooled alternator
    Aug 2009
    Chicago, IL
    2000 BMW 540i 6 Speed
    M62tu with 186k miles
    Vacuum leak, runs like a champ after it warms up fully
    Ellicott City, MD
    98' 528, 80' 911, 04' A6
    197,000 give or take... No issues.
    pittsfield mass
    1997 528I
    have 152,000 on mine tie rods rear ball joints
    alternator a/c compressor o2's
    Chicago South IL
    2003 530i Sport
    Quote Originally Posted by ozibimmer View Post
    Hi guys
    Cheers
    Addam
    wrong question
    who DON"T have 120k miles
    Nov 2009
    Livermore, CA
    00 540i6
    Sorry - no pics
    153K miles
    2000 540/6
    1 CPS at 130K
    Cooling system at 153K (split heater hose and a couple of weeks later a radiator hose sheared off at the inlet - better do the whole thing, right?)
    Needs valve cover gaskets (this weekend?)
    Needs valley pan (coolant loss and rough cold idle)
    Needs ABS/DSC
    Just ordered a new ribbon to do the instrument pixels
    Dec 2011
    NJ
    02 540i
    Quote Originally Posted by saakey View Post
    What wheels do you have on the car? Any more shots?
    Santa Cruz Mountains
    '03 M-Sport 540iA
    2000 540iA with 155k on the clock...flushed the trans fluid three times at around 110k after some rough shifting and it totally solved the problem, even though many advised against it.
    Thrust arm bushings (X5)
    Inspection II
    Refinished Rims (courtesy Firestone Insurance claim)
    Drain & refill Trans 3x with AMSOIL (shifting issues solved)
    ABS/DSC Module rebuild
    CCV Replacement (2x)
    HFM5/MAF Replacement (2x)
    O2 Sensors
    Passenger front window regulator (2x)
    Fan clutch
    It's quickly approaching time for a new suspension but this is the original. I think that's all but not so bad considering the nature of these beasts. Oh yeah, I don't baby her either...my middle name should be "lead foot flashing DSC dude". :-P
    Sent from my Transformer TF101 using BF.com
    EDIT: ***Fixed my "butt"...
    EDIT2: Recently replaced front struts, front lower control arms and rear front upper control arms. Also received INPA error 115, failed MAF/HFM5, which turned the SES off and ended my stall when stopping issue as well as the very hard starts when warm. The 5'er is operating as it should, flawlessly (well, almost). I still have to tackle the braking system...
    '00 540iA Sport w/235k+ Original TCG's, Vanos and transmission.​*Trans failure at 244k+...FS Now
    Buffalo, NY
    2003.5 M3 Convertible
    2001 530 - 150k
    2001 540 - 125k
    West Michigan
    Quote Originally Posted by 12CoolDude View Post
    That's because your daily drive is all mountain twisties (Lucky Bastard!).
    Dec 2009
    Manchester, NH USA
    It's quickly approaching time for a new suspension butt
    I'd love to see the part number for that one.
    Lancaster, CA
    1989 325i convertible
    145k
    No current issues
    174k on the touring
    Minor leak from oil filter housing. Flawless other than that
    I still own an e30, but life has picked up speed and I no longer frequent this forum or own my e39. Thanks for 7 years of help everyone!
    West Michigan
    Quote Originally Posted by AnotherGeezer View Post
    Mar 2008
    Tacoma Wa
    06 550i
    276,599 as of Christmas...Long block replacement in process. Loss of compression on cyl 7.
    Quote Originally Posted by Maximos View Post
    I notice a loss of power when my foot is taken off the gas.
    Mar 2010
    N.Bellmore,NewYork
    '03 540it m '03 540ia m
    Just turned 144K and runs flawless. Still in love with the ride.
