Hi guys. I have a 2003 325i. My ABS light came on and my Speedometer doesnt work. Im pretty sure they are related. Any ideas???
it is a wheel speed sensor. each wheel has one. you will need to pull the abs codes with something like a snapon modis scan tool.
04 325i e46 - 77k miles 5MT Black on Black Leather
I have the same issue however my brake light is on as well. I was told by a few people that this is caused by a faulty abs module or some module, not too sure. Sorry to invade on the post but I never got a direct answer to my problem.
Any idea where they are on the car? Do i have to replace or can I clean them? Also any ideas of a DIY
the sensors are found at each wheel hub on the inside, you'll see it bolted to the hub pointed towards what looks like a gear. Each notch on the gear causes the sensor to pulse to give a reading of it's speed. Each gear has the same number of teeth so that it can read each wheels individual speed. It's part of how it determines which wheel is loosing grip, locked up in panic braking, ect....
Red part is the sensor as it's located on the driver's rear of an e46, it'll be similarly located on the other wheels
I changed both back sensors and yet still the speedometer doesn't work. I did a cluster test by holding down the reset button. All the gauges went up and functioning 100% but the speedometer, abs, odometer and mpg is not registering for some reason, do you know what else could it be. I even checked the back cables for the cluster...
I dont get it.
I finally got to jacking the car up this morning. After getting the wheel off i looked where the Wheel speed sensor was located and noticed something off. By off i mean 2 wires cut and tucked away. it looked like the wires broke a while back and the person who fixed it did a crappy job. I used Butt splices and repaired the wires. And Voila it worked.
