I have ordered recomended brake pads, sensors, and fluid from a recomended vendor here.
I would like to replace my brake lines with stainless braided. It looks like there are 2 hoses in the front and 4 hoses for the rear. Can someone reccomend a vendor that has a kit for the whole car?
Also I will be replacing the bleeder nipples. Are there any parts I need to order incase something does not go as planned? I am thinking that it might be nice to have a supply of clips.
The 6 line kit from UUC is still in the works....months and months later, so don't hold your breath. Check out Bavauto's kit that's on sale for $108 part # BHK 6-Z3
"Dezmar, your hood has an airfoil. The scoop is raised and it forms an airplanes airfoil. This knocks out the top atoms and allows the bottom atoms to Lift!! You will loose your hood on the highway and hit another car, causing it to crash and someone will Die! (I took it off)"
These appear reasonable; @135 for the set:
http://www.zeckhausen.com/BMW/Z3.htm
The OP is looking for a 6 line kit, how does anything on that page apply to his needs??? I'm also clueless as to where you came up with a $135 price tag???
Edit: My apologies, it's a bad product link. Turns out Stoptech has 6 lines available through them.
http://store.zeckhausen.com/catalog/...roducts_id=252
http://store.zeckhausen.com/catalog/...roducts_id=657
http://store.zeckhausen.com/catalog/...00_108_342_346
Here is the price at $80 for the rears and $55 for the fronts, for a total of $135 (98, 2.8). Go down until you see the brake lines. Price may or may not be different for different models.
