Originally Posted by
Placey
This is due to a blown fuse in the JBBF caused by either:
An excessive amperage draw by one of the door lock actuators, which is commonly attributed to silicone contamination; or
An intermittent, but acceptable, amperage spike slightly above 15A, due to normal variation in the locking system.
Inspect fuse 57 (up to 9/07 production) or 73 (from 9/07 production)
Replace the blown 15A fuse with a 20A fuse.
Perform a function test by activating the door locks 10 times in succession via the central locking switch.
NOTE: The thermal protection will be activated after about 15 successive activations and does not indicate any damage to the system.
Carefully observe the operation of each lock actuator while it is being cycled. Lock actuators with some degree of damage will exhibit noticeable symptoms of this, such as slow operation, abnormal noises, etc.
If either one of the front door lock actuators is determined to be the source of the blown fuse, both front door latches (which contain the lock actuators) should be replaced
If either one of the rear door lock actuators is determined to be the source of the blown fuse, only that single faulty latch should be replaced
If no faulty lock actuators can be identified, wait 2 minutes and then repeat
After the second functional test, if no faulty lock actuators can be identified, none of the latches should be replaced
Part Number
Description
51 21 7 263 086
FRONT Door latch kit (contains both left and right latches)
51 22 7 060 295
Door latch – left rear
51 22 7 060 296
Door latch – right rear
61 13 6 942 071
20 Amp mini fuse
