Page 1 of 62 12345678910112651 ... LastLast
Results 1 to 25 of 1550
Thread: MOFO: What did you do to your BMW today???
    Tulsa, OK
    1988 327i E30
    Lets start a local thread to showoff our MOFO weekend projects.
    --->>> Build Thread
    1988 325e | SETA | 2 .7i Stroker | 5-spd | Lachssilber
    Coming Soon..... Turbo
    May 2010
    Jacksonville,Florida
    2000 BMW 323 CI Conv
    Yesterday I installed new Clear corners and a new Roundel on the back,today I installed Angel Eyes. All were from Khoalty and perfect I must add!
    [/IMG]
    Tulsa, OK
    1988 327i E30
    Quote Originally Posted by BlueDropT View Post
    Sweet! You should post some pics
    --->>> Build Thread
    Jan 2005
    Oklahoma City
    s52 e30, e36Ms, e46M
    i put gas in both of em.
    Check out my details and paint corrections!
    www.theautospallc.com
    Nov 2010
    OKC,OK,USA
    98 E36 M3
    Quote Originally Posted by speedster View Post
    Lol
    Sep 2008
    Norman OK
    89 535i 04 Sport Tra
    Since Tischer BMW still has not sent me my upper spring plates for the 5 and its up in the air, I pressure washed the wheel wells and the bottom of the car.
    Feb 2010
    Dripping Springs, TX
    '73 Scout II
    Waxed & Detailed my ride while the missus was out of town!
    Tulsa, Ok
    1998 BMW M3/4/5, 06 C55
    Put in my afe intake wednesday. Pretty sure that's it for mods for a while. Gonna just try to keep it clean and maintained.
    -R
    Feb 2008
    tulsa
    m42 e30
    changed my tires without the help of MY DAD CURT and vacuumed dash mat. that was all for today. just got a new muffler off of ebay and some new license plate led lights gonna tackle those later this week. also bid on some underglow neons
    POWERED BY STARBUCKS
    Nov 2002
    Fort Wort, TX
    '96 318ti, '15 Focus ST
    no pics but on Friday evening i worked on Josh's (Xmahatma) M3. installed fan delete kit (new thermostat, aluminum thermostat housing, lower temp radiator switch, waterwetter, etc), put in a new water pump, and installed a new Mishimoto aluminum radiator (plus coolant reservoir and upper/lower radiator hoses) on the car. Josh and Speedster helped with some of the work as well.
    BMWMOFO C6MPACT
    Mar 2011
    OK
    e30, e61
    Quote Originally Posted by kevindee View Post
    ... also bid on some underglow neons
    Feb 2008
    tulsa
    m42 e30
    Quote Originally Posted by DRVN2WN View Post
    why's that????
    Glenpool, OK
    01 M5, 97 M3 track whore
    Ordered some spacers and bolts to compliment the new coil overs
    I'll post pics when it's on the ground again.
    Mar 2011
    OK
    e30, e61
    Warning: paragraphs coming due to sorting out BS that one of the previous owners of my car installed.
    I started looking into a couple things that were bugging me.
    1)The Angel Eyes that came on my car are CFFL's and only one worked on each side and I'm not a huge fan of the AE's to begin with so I got the AE's disabled and also pulled the electrical tape that was on the parking lamp bulbs off so that they work again. Much cleaner looking now.
    2) Started looking into why the foglights are always on when the headlamps are on regardless of the switch position. Found that the fuse box has a jumper wire from the fog lamp fuse to the headlight fuse, pulled the jumper out and the foglights stopped running when the headlamps were on, but the switch would not turn them on. This will require a more in depth diagnosis soon to come.
    3) Pulled the lower dash off on the drivers side to look at the wiring that goes to the fog light switch and found the relay for the kill switch (I'll either rewire this at some point or remove it) that a previous owner installed - Picture 1. I also found a loose electrical component hanging down, hopefully one of you will be able to identify what it is for me - Pictures 2/3.
    Pic 1: Kill switch relay -
    Pic 2: View one of loose electrical component -
    Pic 3: View two of loose electrical component -
    Mar 2011
    OK
    e30, e61
    Hrm..
    All three pictures are upside down for some reason.. Probably because I was laying upside down when I took them :/
    Mar 2011
    Oklahoma City, OK
    '90 335i, '91 318 cabrio
    Does the trim just have clips behind it?
    Apr 2008
    Tulsa, Ok
    2001 325i
    Replaced AC tensioner pulley and upper idoler pulley and installed trunk lip spoiler on saturday
    BMW MOFO
    WTB: KOSEI K1's 17x8.5 http://caffeineandgasolineu.ipage.com/index.html
    Tulsa, OK
    1988 327i E30
    Quote Originally Posted by CoryDoubleU View Post
    The trim on a 4 door is a bit different than on a 2 door, but...
    On the 2 lower pieces there are metal tabbed clips
    On the rear window corner section there are 4 plastic push clips
    On the top section you have to pull it from the frame of the car (no clips)
    So there are 3 different mounting types...
    --->>> Build Thread
    Tulsa, OK
    1988 327i E30
    Quote Originally Posted by pete318is View Post
    Let's see pics of that spoiler?!
    --->>> Build Thread
    Dec 2009
    PDX, OR
    e30.
    Swore at it.
    Mar 2011
    okc
    1989 325i e46 M3
    i fucked up my front bumper yesterday lol
    -E30 For Life-
    Sep 2003
    out there
    stacked something else on top of it in the garage. Wished it was my finished 914...
    Apr 2008
    Tulsa, Ok
    2001 325i
    Finally got my passenger side window regulator to work!!!!! After several attempts and fails. Ended up having to leave the rear bolts sorta loose so it could move in the slots and not bind up. Now for the rear regulator...
    BMW MOFO
    Glenpool, OK
    As for your WTB sig, you did know that you can't use most spacers with the Kosei wheels didn't you? They don't have the same bevel as bimmer wheels according to what I've read. (No personal experience and I didn't stay in a Holiday Inn Express last night.)
    Sep 2008
    Evergreen, CO
    1994 540iA-->6??
    As much as I love my wife I HATE(!!!!) sharing my E34 with her. I came completely unstacked yesterday when I had to pick up some fu3kin6 Cheetos off the rear seats.
    Dammit! I have to get another car for her so she can leave mine alone!
    2003 996.2 C4S
    2004 986.2 S
    2011 958 Turbo
    E39 540i6 to new home.
    E34 540iA also to new home. Currently Bimmerless and sad.
