Page 4 of 8 FirstFirst 12345678 LastLast
Results 76 to 100 of 181
Thread: E36 Front PDC
  1. #76
    dancerst's Avatar
    dancerst is offline life is a dance... BMW CCA Member
    Virginia Beach, VA
    E36 SC,E31 840ci,740iL
    Quote Originally Posted by M3C View Post
    Yes.
    Great mod! Any photos of the process?
  2. #77
    The Netherlands
    DE-spec E36 328i/M3 cab
    haha good stuff!
    IG:
  3. #78
    Jan 2003
    USA
    BMW M3
    Re
    Quote Originally Posted by dancerst View Post
    Unfortunately not.
  4. #79
    Mar 2006
    Colorado
    E36 M3
    I envy you guys. Great work
  5. #80
    Feb 2013
    kazahstan
    1997 BMW 316
    Good time) tell me to connect to PDC E38, I want to install on E36, now confused can you throw information how to connect everything to work in front of and behind. and how do you cut out the hole for the sensor. Please do not anybody to turn (with respect from Kazakhstan
    sorry for the broken English
    M3C,
    you yourself do you do? tell me how to connect the entire system to work? whether dobovlyat additional wires to the unit from the E38?
    up
  6. #81
    Nov 2008
    Maryland
    not enough
    So if you want to put E38 front & rear module you need to add 1 more ground wire, othewise you wont be able to turn on yuor PDC from the reverse light signal.Cause on E38 it uses i-bus to switch rear sensors.
    The all 8 sensors are activate by the switch or reverse light signal.
    If you interested I’ll send you email with the diagram.
    dancerst (or anyone who can provide input), I know it's a long shot but if you can send me the diagram you speak of I would greatly appreciate it. I was trying to retrofit the e38 system on my e31 but essentially I was told it would most likely not work because of the ibus input needed on e38's. See post below:
    http://forums.bimmerforums.com/forum...ntrol)-systems
    You mention to make it work you had to add one more ground wire....can you specify where? Do you just ground that ibus terminal on the control unit? Can you post the PN for the control unit you used? I guess if you were able to make it work the entire system is dependent on the switch, correct? I guess you only lose the functions dependent on iBus (speed cut out, etc).
    I would be infinitely grateful for your input on this.
    CB42366 - 1991 850i 6-speed. Brilliantrot & Black Nappa Leather
    CD00144 - 1994 850CSi. Hellrot & Black Nappa Leather
    My other projects:
    Supercharged Tbirds, V8 Tbirds, V8 Mustang Convertible, Audi V8 Quattro & Audi S8
  7. #82
    Oct 2008
    PDX & Hermiston, Oregon
    98/M3/4, 05 M3 Vert
    Also interested in this.
  8. #83
    Richmond, Canada
    MCab
    I would also like to try this, so any info on wiring would be greatly appreciated.
  9. #84
    Dec 2009
    CA,
    95 M3
    Hey guys I have a full front and rear E38 PDC kit fore sale if anyone is looking for one to retrofit it in here E36.
    http://forums.bimmerforums.com/forum...ntrol-Full-Kit
  10. #85
    Nov 2008
    Maryland
    not enough
    bump just in case anyone has any input.
    Also, does anyone have the pin out schematic for the e32 PDC switch?
    My other projects:
  11. #86
    Deutschland
    E36 328i LeMansBlue, E30
    the schematic is attached somewhere in this thread: http://e36-talk.com/showthread.php?6...-Mittelkonsole
  12. #87
    Sep 2012
    Germany
    330i E46
    Maybe he post here the wiring Diagram if someone send him a PM!?
  13. #88
    Europe
    95 318is
    I’m not sure 100% (because I fogot) but I think E36 PDC Module can be wired with PDC switch.
    You can try it by putting momentary ground to pin 19.
    FYI, I can confirm this works on an E36 yellow plug PDC module. Momentary ground to pin 19 can deactivate/activate the pdc while reversing. I used an SMG switch from an M3 Evo which has 3 pins and when pressed closes one of the wires to ground (other 2 wires are of course ground and illumination).
    Currently:
    95 318is, 71k original km...
    Sold:
    96 316i Compact
    95 M3 :'(
    87 190E 2.6
    95 C280
    82 240D
    89 735iL
    85 318i
    95 Opel Astra 1.4
    93 Lada Niva 1.6
  14. #89
    Deutschland
    Why ain΄t you guys using the OEM E36 PDC switch?
  15. #90
    Jan 2003
    USA
    BMW M3
    Pdc
    Are you sure this is OEM PDC switch, with 0 1 buttons.
  16. #91
    Deutschland
    Yes. 100% sure. OEM e36 pdc Switch Part # 61 31 2 137 728
  17. #92
    Europe
    95 318is
    Quote Originally Posted by Falk View Post
    not seen this type of PDC switch before. How does it work? turns PDC on/off while in reverse gear?
    Currently:
    Sold:
    96 316i Compact
    95 M3 :'(
    87 190E 2.6
    95 C280
    82 240D
    89 735iL
    85 318i
    95 Opel Astra 1.4
    93 Lada Niva 1.6
  18. #93
    Deutschland
    Yes. I' m using it to turn off the pdc when I have to drive backwards with a trailer.
  19. #94
    Jan 2003
    USA
    BMW M3
    Thanks Falk, interesting to know this existed, it shows for all E36 Euro Touring models.
  20. #95
    Deutschland
    Not all Euro tourings. Only BMW Service mobil were using that part. Got my Switch from ebay.
    still available at the dealership
  21. #96
    Nov 2008
    EU
    320i E36, 318i E30
    To keep the topic going
    - as from what I heard the 0/1 switch 61312137728 was used to deactivate the PDC if using a trailer. All the others E32, E38... had the illuminated one and was for activating the front/rear PDC
    - by diagnostic (NCSexpert with NCSdummy) the front/rear E38 PDC module (mask PDC.C01) can be set to:
    * 4 or 8 sensors
    * tone generator rear loudspeaker/gong
    * tone generator front loudspeaker/gong
    * only one tone generator yes/no
    * PDC button yes/no
    * switch on delay yes/no
    * PDC only with ignition yes/no
    * activation with speed yes/no
    * switch on notification first time yes/no
    * switch on notification each time yes/no
    * push botton notification yes/no
    * failure...
    * sensor spacing...
    * measuring range...
    * sound volume...
    * switch ON speed...
    * switch OFF speed...
    * switch OFF distance...
    The bolded options if set make the PDC almost automatical without touching the PDC button. When you put in reverse or at low speed it starts the PDC, bulb in switch ON, when you go over some set speed (~20km/h) it deactivates.
    The only problem is as the E38 PDC diagnostic is throw Ibus - but the E36 ZKE doesn't have Ibus decodification from OBD2. The E36 is old system ADS. The second problem is that the E36 PDC is visible in INPA, but not present in NCSexpert. Under E38 the PDC is visible as PDC.C01 (old passive sensors), but this works only with Ibus diagnostic. I have 3 module (E36 violet, E38 violet, E38 front/rear yellow) and I already found some differences in the diagnostic input. The circuit is premade for ADS and Ibus but then with some resistors and diodes the factory set the diagnostic protocol. I will try to set the E38 reaf/front module in the same way as on E36 so I can acess it throw diagnostic (INPA), but I will need to solve the problem with changing code as the NCSexpert doesn't has the PDC mask. As for the E38 PDC NCS mask (Ibus) I will have to try to copy/paste it to the E36 folder and try coding the car with ADS. I hope the PDC will recognise the direct diagnostic orders, with the GM4 changing them to Ibus
    I was always worried how about reverse input as on E38 it's made throw Ibus. But now I know it works as tested in this topic with a additional ground
    pin #18?
    In addition any module violet or yellow plus has the circuit premade for PDC 8 sensors. Only then the factory choose to be cheap and fit 4 or 8 output transistors, regardles the module could be programed to 8 and has 8 outputs. Both violet or yellow were used with 8 sensors and I will try to make a list for a upgarde of the el.circuit to full rear/front (some resistors, transistors, capacitors and diodes)
    update1: even if E38 diagnostic input logical converter is set as on E36 (ADS) from the E38 (Ibus) the diagnostic doesn't connect. I gues it is not only some resistors wired differentky, but a different programed processor . Any diagnostic must be done on a E38/E39 throw IBUS and then the modul connected to the E36.
    Now I have to find if there exists a OBD to Ibus interface. Navcoder can't be used as it only allows PDC reading but not coding
    in addition - the output transistor is a MPSA93 with on each channel resistors 47k, 7.5k, 2x 22k; 2x capacitors (still have to measure) and 2x Switching diodes model BAS21LT1, case SOT-23. The modules with only rear PDC have the pads empty, but all the other connections betwenn the uP and the outputs are the same. The only problem, that even connected to diagnostic with INPA and NCSexpert on ADS E36 the modul can't be coded as the library of the NCS doesn't has the PDC module mask. If someone has the PDC module program diagnostic mask (under NCS/DATEN/E36 or 34 or 31 or 32) please post it on the forum.
    E36 320i conv 1/97':
    fog lights; power steering; M body; M steering wheel with MFL; M3 vader light gray leather seats w/heating; phone; cruise control; harmankardon; PDC; CD43 business radio+dension adapter USB+Ipod with ID3tags; hardtop+lift+stand; wind deflector; 17" stly22 Motorsport wheels; EWS; DWA alarm; remote central locking; 4x el.windows; CD changer; cup holder+CD box in glovebox; coin box in door; roll-bar; full auto.el.softtop; luggage straps; ASC; ABS; engine compartment light; glovebox light; automatic A/C with AUC; OBC; light cleaning; intensive wash; heated wash nozzles; fire extinguisher; westfalia towing hitch
    E30 318i sedan 9/87': everything expcept Mbody and sunroof
  22. #97
    Nov 2008
    Maryland
    not enough
    Quote Originally Posted by vlakci View Post
    Great info!
    I had never seen that PDC switch either. I'm assuming that's to deactivate the REAR PDC when using a trailer, correct?
    Sorry I can't be of much help but I'm keeping close tabs on this thread. If I'm not mistaking you're trying to use the e38 PDC module to make the front/rear PDC work in your e36 using ONE single e38 module, correct? Since my tech saviness is not great, once I found out that the e38 module needs ibus to work I dropped the idea of having one module control both front and rear PDC.
    The e36 & e31 share the same OEM rear PDC system so hopefully you can get front/rear-in-1 to work so I can mimic on my e31's.
    My other projects:
  23. #98
    dancerst's Avatar
    Virginia Beach, VA
    EVERY ONE! HUGE UPDATE ON E38 PDC MODULE!
    Will post pictures soon!
    Quote Originally Posted by CaifanSC View Post
    Great info!
    I just installed Front/rear PDC on my new E36... And as the last time I've used ONE PDC modules for front and rear. NO IBUS NEEDED!!!
    FOR EVERYONE WHO HAS INSTALLED E38 PDC MODULE.
    If after installing on E36, your PDC still doesn't respond for reverse lights, you have to modify the module from inside.
    This is what the E38 PDC (front + rear) looks like:
    STEP 1:
    you need to focus on this area:
    STEP 2:
    STEP 3:
  24. #99
    UK
    1998 328 convertible
  25. #100
    Nov 2008
    Maryland
    not enough
    You are da man! This project just bumped its self up my list of stuff todo on my 8's! Couple quick questions....so you are still using OEM sensors right?
    Also, just to recap....the switch will activate/deactivate the FRONT PDC sensors and the rear are automatically activated when the car is put in reverse gear, correct?
    Kudos to you my friend! Heck, next time I'm in VA beach I'd like to buy you a beer
    ooo...last thing, what are the specifics of that 10k ohm resistor? I'm knowledgeable with electronics, but I'm no expert. I've never actually used that type of resistor before...if you have some sort of part number it would be even better so I can just purchase
    This is exciting
    My other projects:
  1. E36 e36 Front and rear seats in tan
    By AndrewH in forum Exterior Lighting & Body Parts
    Last Post: 10-20-2010, 03:49 PM
  2. E36 FS: E36 Front Knuckles/ Spindles/ Hubs/ Wheel speed sensors- CHEAP $55 shipped
    By sweet e36 pimp in forum Suspensions, Springs & Shocks
    Last Post: 07-27-2010, 06:56 PM
  3. E36 wntd e36 front crontrol arms
    By 3lm3rom3ro in forum BMW Parts Wanted
    Last Post: 03-15-2010, 01:29 AM
  4. E36 NJ: 1992-1994 e36 front bumper
    By amancuso in forum Exterior Lighting & Body Parts
    Last Post: 01-04-2010, 02:28 PM
  5. E36 E36 Front Caliper New
    By Momikey in forum Brake Kits, Rotors & Pads
    Last Post: 12-06-2009, 10:29 PM
