Is there an easy way to replace the door locks on a 1997 E36 328i sedan,
or does one have to take the interior door panel apart,
and/or remove the window?
Is a good DIY available?
Thanks!
If you mean the door outside door handle....there is no easy way. Its a major pain. The door latch on the side of the door is a bit easier. Both require you to take the door panel off. The outside door handle requires you to take the glass out. The door latch can usually be fished out without removing the glass.
Bentley has a section on it but the pics aren't the greatest.
Thanks for your response,
though it is not cheery news.
However, a non-functioning door lock
is even a less pleasant prospect.
Best regards,
Door lock do not fail normally. (unless you have damage to the key set) Check to see if the levers are disconnected. You will save yourself 4 hours of work, but you still have to remove the door panel.
Do I understand correctly that
if one just wants to replace the door lock cylinders,
there still no easy way...without taking out the window, etc?
I thought most owners use the remote to lock/ unlock and activate the alarm. The new cars don't even have a key lock on the passenger side anymore.
The DIY section has a good write up on replacing door handle and the key. http://forums.bimmerforums.com/forum...d.php?t=709257
Thanks for your guidance on this!
Questions well answered.
Why are your door locks non-functioning? Is it a bad key or are the tumblers not turning in the cylinder?
I'm in the middle of a door handle swap on my 97 328is. I got a replacement handle here in the 'for sales' but it didn't come w/ a key. To get the tumbler out of the handle you have to insert the key so the waffers line up. I ended up using a small screw driver on the replacement handle to gently position each of the waffers so I could pull it out. Worked like a charm and saved a few bucks from a locksmith.
I lubed up the original tumbler from my old handle and slid it in the replacement handle. Now the key rotates like new. Nice and smooth.
If your existing key works but the tumblers are difficult to turn, maybe a nice cleaning and lube would fix you up. To get the tumblers out while the handle is in the door could be a bit of a challange but, I don't think it's impossible. I would even bet the window could stay in the door and attached. I'd still suggest pulling out the rear window guide to give you some room to work. It's pretty tight in there.
Existing key works but the tumblers are difficult to turn,
so I will try some graphite powder initially,
as the other options are more difficult and costly.
Thanks!
same situation but i missed the part about gently removing the tumbler, my technique was a flathead and a ballpin hammer. thinkin it was just stuck in the handle, i f'd up bigtime i guess maybe just got get another handle for $20? unless anyone else has a better idea. my bentley manual didnt even shine 1/2 page on this. tryin to finish this while the suns still out.... help?
Cryptic DIY above is really good. I made a DIY on this as well - maybe it will help:
http://forums.bimmerforums.com/forum....php?t=1587136
Check out my M Roadster projects and DIYs:
Cooling system part 1: https://youtu.be/ERqztIL1DPw
Cooling system part 2: https://youtu.be/-DnclDkn2hI
Power convertible top: https://youtu.be/KLYNqkCBh_M
Head unit removal: https://youtu.be/LKe9fPKrAqE
i checked out most of the DIY's on here for removing/replacing the tunbler, but none said how to without the old key, except for a wizard who can use a small screwdriver, but im not that guy, i should just take this to a locksmith then?
I removed it without the old key. The thing that actually holds the old tumbler in place is the large waffer in the front. Just insert a key from your car into it. It should go in at least 1/4 of the way, but this will be enough to lower the first waffer and will allow you to remove the tumbler. I have a broken door handle with a tumbler laying around, so I will do this tomorrow and post pics. You should be able to figure it out though. Just make sure that the pin in the back of the tumbler is out
got the roll pin out, the tumbler wont accept a key, not even 1/4 turn, im thinkin about getting a 1" bit and drilling the whole effing thing out cus theres nothing moving inside the tumbler because like an ass i just went at it like it SHOULD just fall out, but why is it not..... im SOL rite now
i just tried to slide them to the left & right with a small screwdriver. i could get a few, but i think i might've bent the first two with my bad idea of just putting it in a vice and turn the tumbler it as hard as you can with a big screwdriver. FAIL
Ok, I found a pic from my old thread that may help you.
Take a look at the front of the tumbler (right part of the pic). You can clearly see the "wafer" that I was talking about. Most likely, this is the piece that's preventing you from sliding the thing out of the handle. You need to push it down somehow.
ooooOOOOooooOOOOoooHHHHHH will try right now....
yeah, no i cant even reach that wafer, shit thats a hefty piece of metal holding it in there i figured id be able to just bend it by turning it. o well looks like i need to buy another door handle....
My tab pushes in easy with the key rotated to the up or down position. My key also has cut in the key that's not part of the tumbler. It lines up with the large tab you were shown by Andryuha and allows the tab to recess into the cylinder. PS I also tried a different key set, it will also allow the cylinder to slide out. just as long as the pin wafers are not extend out to the maximum and the tab can move in so I would think any key that can slide in all the way will allow the cylinder to be removed.
