Hi
I was trying to "get started with WinKFP 5,1" and i used the attached how to guide. When i did this i got lot of fail errors in the winKFP when i start it up. when i hit OK button the winkfp closes.. i was not smart enough to backup the files in the winkfp.. so what to do here ? how to get the SP-DATEN files to work ?
325i Cab 91 e30 *sold*
316i 95 e36 *stolen*
320D 04 E46 M-Tech *New*
Why choose a BMW ? Because you deserve it =)
OT, but i need the daten files.
all my Dis files are images of VMware.
Does anyone know where i can download the daten files? or can someone upload them please and thank you.
They are located in the SSS Progman DVD. Mount the Progman disk in virtual drive (or insert in usual DVD-drive), extract all files
SP-daten-Exx.rar from directory (Drive letter):\CIP-Installer\bin,
Just have to figure out how to get them working with the WinKFP
I dont know where you can hget the latest. But i got the SSS from 4 shared site.
http://www.4shared.com/dir/LfFoCBq2/...s_Machine.html
pass bimmerforums
you have to download all the rar files to get an ISO file. then you have to explore the cd. then you will get the files.
But can somebody tell me how to use this files ????
I had the same problem getting WinKFp working. I followed the instructions given to import the data and ecu files and I copied the files from the gdaten folder over but still my WinKFP did not want to start without the error box. I checked my Sgidc.as2 file for long line entries but all was good and still the error box.
I then got advise from somebody much more clever than me.. His advise:
You have 3 problem files. history.bsu npv.dat prgifsel.dat
open them with wordpadMFC and they look okay.
To fix just open these the files with wordpadMFC and click save.
After I opened this three files with Wordpad and saved them my WinKFP worked without problems.
Hope this will help you as well, or else you must give a bit more information as to the errors you get?
Thanks i will try do that. But i have to import the files again. Just copy the daten files to the right folder. Then i will try to get started WinKFP again. But i'm not sure how to get imported the files into WinKFP when i cant even start it :/
I was tired of searching through countless threads and posts with the same Daten files, so I downloaded & uploaded the data files (V41) SEPARATELY for each chasis onto my Rapidshare Account. Links should be good forever as I always renew my contract every 2-3 years. If anyone has any other important files that they would like uploaded and hosted, I will do so, just message me what you need.
STS 2100 Setup = https://rapidshare.com/files/9772030...2100_Setup.zip
V41:
E36 V41 Daten Files = https://rapidshare.com/files/1728124...aten_Files.rar
E38 V41 Daten Files = https://rapidshare.com/files/3083436...aten_Files.rar
E39 V41 Daten Files = https://rapidshare.com/files/1672164...aten_Files.rar
E46 V41 Daten Files = https://rapidshare.com/files/4196534...aten_Files.rar
E52 V41 Daten Files = https://rapidshare.com/files/3193868...aten_Files.rar
E53 V41 Daten Files = https://rapidshare.com/files/4104321...aten_Files.rar
E60 V41 Daten Files = https://rapidshare.com/files/1075756...aten_Files.rar
E65 V41 Daten Files = https://rapidshare.com/files/2644713...aten_Files.rar
E70 V41 Daten Files = https://rapidshare.com/files/2006344...aten_Files.rar
E89 V41 Daten Files = https://rapidshare.com/files/1813178...aten_Files.rar
F001 V41 Daten Files = https://rapidshare.com/files/2655435...aten_Files.rar
F010 V41 Daten Files = https://rapidshare.com/files/1063657...aten_Files.rar
F025 V41 Daten Files = https://rapidshare.com/files/9389030...aten_Files.rar
K001 V41 Daten Files = https://rapidshare.com/files/8644125...aten_Files.rar
K1X V41 Daten Files = https://rapidshare.com/files/2941985...aten_Files.rar
K24 V41 Daten Files = https://rapidshare.com/files/1109300...aten_Files.rar
R50 V41 Daten Files = https://rapidshare.com/files/2927685...aten_Files.rar
R56 V41 Daten Files = https://rapidshare.com/files/3617203...aten_Files.rar
RR1 V41 Daten Files = https://rapidshare.com/files/4073048...aten_Files.rar
V42:
E89 V42 Daten Files = https://rapidshare.com/files/4983306...aten_Files.rar
V43:
E89 V43 Daten Files = https://rapidshare.com/files/1350555...aten_Files.rar
Feel free to post these onto other forums you are members of; just give me some recognition :thumbsup:
I did this, but still having the same problem, when I trying to ope the WinFKP...
"Error 1:
CoapiKflnit: Initialization error!
COAPI errors entries:
Code: 4202
Level: Error
Text: Format syntrax error
Code: 4211
Level: Error
Text: String syntrax error in file to be converted
Code: 4206
Level: Error
Text: Error on readind in file .. \DATA\gdaten\SgldC.as2, line 95
Code: 1040
Level: Error
Text: Error in file processing (general) .. \DATA\gdaten\SgldC.as2
Code: 1040
Level: Error
Code: 1040
Level: Error
Text: Error in file processing (general) SgldC.as2
Code: 3017
Level: Error
Text: coapiKflnit() failed"
please help...
thanks,
E39, 523i, 1999, M52TUB30, 5 SPEED MANUAL, UUC SHORT SHIFTER, EURO SPECS, KONI YELLOWS, OEM SPORTS SPRINGS, OEM SPORTS SEATS, ALCANTARA HEADLINER AND /A/B/C PILLARS, OEM M-TECHNIC AERODYNAMIC, OEM M5 FRONT GRILLS, OEM M5 REAR FOLDING MIRRORS, OEM M5 REAR SWAYBAR, OEM M-TECHNIC II FRONT SWAYBAR, REMUS DUAL TIP MUFFLER, TITANSILVER, BIXENON, M PARALLEL SPOKE 66 STAGGERED, OEM M-AUDIO SYSTEM, NAV SCREEN 16:9, INTRAVEE II iPOD INTERFACE, OEM TCM WITH BLUETOOTH, Y RESONATOR DELETE, INTAKE HORN DELETE, CDV DELETE, CHARCOAL TITANIUM BRUSHED TRIM, FAN CLUTCH DELETE, ELECTRIC FAN, 3.15LSD DIFFERENTIAL, ESS TS2+ SUPERCHARGER, AQUAMIST METHANOL + WATER INJECTION
PANAMA, CIUDAD DE PANAMA
Get WinKFP 5.1.6 or later - fixes a lot of the parsing bugs.
Also that getting started guide is pretty useless. Don't load the E70 chassis unless you actually have an E70. Instead just load whichever chassis you actually own.
terra, can ou please told me how to disable the reflashing counting in my DME?
I responded to your e-mail, but just so everyone knows:
Rapidshare has changed their policies recently. They limit the amount of downloads a user has on their uploads to prevent piracy.
However, you may login with my username and a temporary password that I will give you if you PM or e-mail me directly through the forum.
Thank you
Thankīs for the fast reply Kris, If itīs only about the policies from rapidshare, than I think I can re download in a few hours.
If it will not work. I will send you an eMail. Itīs just 2 files that are missing.
Thank you.
Hello,
I was hoping I could get some help here. I performed the update to the transmission as discribed below:
1. Download and install BMW standard tools. It contains INPA, NCS, winKFP, and tool32.
This will only install the programs, you need the sp-daten files for e65.
2. Use the attached guide to setup winKFP.(I used the attached guide. I cannot upload because I am new to the site)
3. Open INPA>>choose chassis>>Transmission>>Gearbox Control module>>Identification (F2). now press arrow down on your keyboard and take note of your Assembly number. Close INPA
4. Open winKFP>>Comfort mode>>Enter ZUSB and Enter the assembly number.>> Take note of your ECU family.
5. Now press F3 (Update ZUSB) and choose your ECU family.>>Ok
6. F4 (Enter VIN) and enter your full VIN number. >> Ok >>F8 (DONE).
7. F3 (Prog. ZB-Update). Here a pop up shows you your current and updated assembly number. If they are the same you already have the updated software but if not press okay.
Another pop up asking permission to program ecu....press okay and your done.
It took about 5 mins. so if your car's battery can hold up for 5 minutes you'll be alright.
At the end it should tell you that the programming was okay.
I downloaded The daten files: E65 V41 Daten Files
Performed the flash with Winkfp 5.1.6
Update was successful according to Winkfp, however while performing the flash I received a transmission fault along with a dsc malfunction and parking brake malfunction.
When I check the UIF via inpa, the DSC and SINE ECU's show SUB-FUNCTION NOT RECOGNIZED INVALID FORMAT
Should i copy and paste the format folder from the daten files? Will this fix my issue?
Any help is greatly appreciated!!!!
where to find e65 daten files for SINE and DSC ?? I have that same problem when I check the UIF via INPA
U S E R I N F O R M A T I O N F I E L D
Date: 14.09.2013 14:54:40
Model: E65
Scope: all control module
JobStatus: OKAY
Quantity: 50
ADR Gen. name JobStatus
29 DSC ERROR_ECU_SUBFUNCTION_NOT_SUPPORTED__INVALID_FORMA T
50 SINE ERROR_ECU_SUBFUNCTION_NOT_SUPPORTED__INVALID_FORMA T
Hey pal, mind if I asked the source of your download of the spdaten files. I have an e39 and I am getting the "xxkconf.da2" code 3000 error message. Would appreciate the help.
Sorry had I just look overleaf I would have found it before asking
Hey
Can you help with getting original sp daten for 2007 e90? Id like this for ecu jbbf. Or even the full version actually. Unfortunately, i dont know the version of daten this would be in but would take any versions prior to v41. The original assembly number is 4116461 dated 4/12/2003. Thank you.
