Page 1 of 7 1234567 LastLast
Results 1 to 25 of 171
Thread: An Example of Truly Impressive Turbo Engineering
    Birmingham, AL - New Orleans
    E30 M3/Mitsu EVO 8
    Every now and then I come across something truly impressive. This represents some of the work of Extreme Tuners in Athens, Greece, and the name is no joke. Pushing limits requires funds and skill, and these guys have both. All they do is build and tune engines. The entire lengthy discussion can be found here (http://forums.evolutionm.net/evo-dyn...ne-2007-a.html), but unless you feel like reading quite a few pages of posts, I'll post the highlights here.
    FWIW, this is some of what they've done:
    2006 - N/A ford cosworth 4cylinder 16v engine 119cui: 416hp -11,900rpms
    2007 - Ford cosworth 4cylinder 16v Turbo engine 120cui: 1280hp 47psi (custom triple ball bearing 80mm turbo 119lbs/min)
    2007 Mitsubishi Evo 8 4g63 4cylinder 16v Turbo engine: 1416hp 57psi (custom quad ball bearing 82mm turbo 132lbs/min)
    So, getting 700whp/L from 2.0L @ 8500rpm is no small feat, but what do you need if you get bored and want to shoot for 2000whp?
    Cast Garrett compressor wheels (right) tend to come apart above 50 psi. CNC billet aluminum wheels (middle) are stronger, but why not be different and use your own CNC billet titanium (left) compressor?
    You'll need a turbo big enough for the job, which in this case is a 108mm twinscroll T4 turbo, with custom quad ball bearing CHRA and 100psi capability.
    To get enough airflow at 12,000rpm(!) to get the job done, you'll need a skillfully ported head, complete with titanium valves and copper-beryllium valve seats:
    And you're going to need a set of camshafts to handle the rpm and withstand tremendous ramp pressures, so why not a set of hollow titanium billets with DLC at only 234 grams each?
    And since there is no aftermarket rod up to the task, just ask for a set of billet mmcs-titanium connecting rods at 286g each. Rod/Stroke ratio is 2.07:
    For pistons, a set of custom beryllium pistons with DLC fits the bill, and since methanol is the fuel, 13:1 SCR is fine:
    A strong piston pin is needed as well:
    Toss in a custom titanium billet crank:
    A set of 9000cc/min injectors:
    And since a factory 4G63 block probably wouldn't hold up, just CNC machine your own from billet aluminum:
    No head gasket is used:
    And to put all that power to the gearbox, one needs a suitable multiplate clutch:
    Yes, it is smaller than a cam gear:
    An example of very efficient turbo manifold design from one of their recent projects:
    And last but not least, a dynosheet from this car, running 'only' 48psi and hydraulic cams:
    2003 Mitsu EVO VIII - 2.0L / 600+whp
    1988 BMW M3 turbo - Work in progress. . .
    1986 SVO Mustang - Work in progress. . .
    Dec 2002
    Sydney, Australia
    1999 BMW M Coupe
    Serious engineering!
    .-=[ Kenny ]=-. See the BFc Drag Racing Standings List for BMW street cars. Watch my drag racing movies on YouTube. Some info on
    BMW turbo street car Drag Racing 101
    NY
    skateboard
    Quote Originally Posted by MrBlonde View Post
    Plus 1. Now lets see what that s14 can do.
    Aug 2008
    Ellicott City, MD
    2005 STi
    Holy....
    That is incredible
    Louisville, KY
    turbo m3
    Damn! Im amazed!
    This is my signature....
    Apr 2008
    Orlando, FL
    02 330ci, 95 ///M3
    sick!!!!!!!!!!!!!!!!
    Vancouver, B.C., Canada
    '97 M3
    I think the story should continue...... as in what was done to the drive line to handle 1500 whp. I'd like to go for a ride to see what it feels like when it finally starts to spool up between 5000 rpm and 6000 rpm!
    '97 M3, Estoril blue, 2 dr, euro 6-spd, GTX3582R T4 .82, RK tuning, CP 8.5:1 pistons, Eagle rods, Schrick cams, L19 11 mm ARP studs, O-ringed block, Supertech stainless/inconel valves, Supertech springs & Ti retainers, ported head, S54 oil pump/pan, 80 lb. injectors, OBD1 intake manifold, Steedspeed T4, 3.5" SS exhaust, AMS-500 EBC, HFS-4 W/M injection, AEM Failsafe, Zeitronix data logger, Racelogic TC, OpenOBC, Ireland Eng. engine mounts, UUC black tranny mounts w. enforcers, UUC twin disc feramic, ARC-8's, MCS 2-ways, Z3 rack, Rallyroad strut bar, X brace, Eibach sway bars, Ground Control LCAB bushings, Bimmerworld RTAB's, Powerflex subframe bushings, CES 750iL diff conversion, Stoptech BBK, titainium shims, steel braided lines, brake cooling ducts.
    Abbotsford, BC
    Unicycle
    That is sick.
    Jul 2006
    USA
    4 m52s,m50,m20,s52
    My mind = Blown! Thats very impressive work.
    Cheif Senior Hitman Engineer 1st Class
    BfcOT Mafia
    Dec 2002
    Sydney, Australia
    1999 BMW M Coupe
    Quote Originally Posted by GG///M3 View Post
    Yes, and show me how you get a 2.0 litre to idle with 9 litre injectors!
    Dec 2009
    Albuquerque, NM
    E30 M3 turbo
    Drool.
    OKC
    '98 Turbo M3
    Salt Lake City, UT
    1999 M3
    Thanks for sharing.
    Truly beautiful what can happen when money is no object and great designers/fabricators/engineers are unleashed.
    Jimmy
    Technique Tuning Stage 2 on 9:1 built motor(SOLD)
    Boost Addiction Support Group Member
    Official "My Wife is Awesome" Club Member
    Just an idiot with a wrench...
    DUDMD's Avatar
    DUDMD is offline BMW Maniac Supporting Vendor
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    That is an art that only few master. Almost anyone can build a fast car, but building the best or breaking records you have to be original and think miles away from outside of the box.I bet the only stock/oem parts left are the valve cover and the original head casting which is now ported to the limits.
    M60B40/B30 Manual/Auto Performance Chips
    M62 (E38/E39) and M62TU (E38/E39/X5) OBD2 Performance Tunes Available
    M73 V12 Tunes are available/released. 7/97 - 2001 750iL are currently supported. E-kat delete is now possible.
    EWS Delete for E39 M5 DME and E46 M3, and MS41
    Can disable any fault code on E39 M5 and E46 M3 DME, as well as CSL DME software mod for quicker shifting and rev matching downshifts.
    Virgnize DME service available for EWS3 vehicles 98+. M5.2.1, M7.2, MS42, MS43 and others, feel free to ask.
    DTC delete for cats/secondary air pump for most BMW ECU, including the common N62 issue.
    Don't be afraid to ask, worst I can say is no.
    Easiest way to contact me is to send me a message on my facebook page "DUDMD Tuning"
    540i/6 E34 Turbo Build
    750iL Work Log
    Sep 2008
    NJ
    96 M3, 97 M3
    I can only dream of stuff like this, these guys are truly the tip of the sword.
    mcoupemindy's Avatar
    mcoupemindy is offline Senior Member BMW CCA Member
    Supporting Vendor
    Jan 2005
    Haymarket, VA
    '99 M Coupe
    Why are you guys posing pictures of my new project car - jeez, atleast wait until the front bumper fits right.
    Jonathan Thayer - Thayer Motorsports, Inc.
    www.thayermotorsports.com - support@thayermotorsports.com
    Tarrytown, NY
    e36 m3, e46 325, e36
    +1
    Norristown PA
    330tti/e46m3t
    Made in China?
    www.prussianmotors.com 95 PT6262 Forged 330ti / e46 Maximum PSI M3 on ethanol
    Jun 2005
    south
    85 318i
    Engineering + $$$$ = Dreams come true
    Guaranteed that the runners on the manifold are equal length within a hair.
    My manifolds powering 8sec and over 1000rwp cars
    Home of the highest HP stock M30 in the world 550rwhp/622rwtq
    1/4 mile---> 10.006 @138.12 C4 Auto
    10.08 in car vid --->https://youtu.be/OiinFhUomjg
    Dyno vid... http://www.youtube.com/watch?v=C7aM7..._order&list=UL
    air, dirt, fire, water
    95M3 92525iT 78810 95525
    I am hoping that all that engineering will pay off;
    hence, WIN RACES FOR MONEY
    as the tooling, extravagant expeditures and TIME invested is a bit much for a hobby car.
    Beyond impressive, nonetheless.
    __________________________///milKt.org
    NY
    skateboard
    Maybe it idles at 2k rpm.
    Jan 2006
    Ellicott City, MD
    '99 M3 TT stg II
    holy fawk....thats nuts
    E30 M3/Mitsu EVO 8
    If you look at the dyno chart, it crosses the 200whp mark around 4650rpm, which is actually pretty quick spooling for what it is. It makes so much power that the lines look vertical, but they wanted to make it 'quick spooling', so they did a good job.
    Straight methanol stoichiometry is 6.4:1 as opposed to 14.7:1 for gasoline, so a very high volume, high pressure fuel system is needed. And since 130 octane methanol doesn't 'knock', tuning in those netherworld regions is tricky.
    Since some of you are wondering what this costs, I know the Ti rods are around $3250 each, and the Ti crank is around $31,000. They are now working on a CNC billet cylinder head and carbon fiber turbine housings. These guys have good connections with F1 parts fabricators.
    If you want a turbo, they'll build whatever you want, and their quad BB center sections are damn strong. GM's 1400whp Ecotec project used one of their 80mm turbos:
    If you can dream up a turbo, they can build it:
    They also use straight metal matrix composite (mmc) rods, which are lighter than Ti. The problem is cost and life (120 hours). These use no rod bearing.
    Not often that one sees 13:1 compression ratio beryllium pistons, much less in a turbo engine:
    Ti valves and CuBe seats sure are pretty:
    Some other cars laying around the shop:
    1360whp 2.0L Escort Cosworth
    1070whp Subaru on its way to 1500+whp:
    Anyway, it just takes desire, skill, money, and maybe a kidney.
    Saskatoon, SK, Canada
    r32 gtr, M3
    an engineer's dream project
    Charlotte
    '97 Estoril M3 Turbo
    This is strait bonkers. Seriously, You dont see ANYONE doing these things to motors. THis is damn ground breaking. Imagine if a supra shop with some cash and this knowhow/equipment did this to a 2j. We would likely see 3000rwhp... maybe more.
    Just excellent post, thanks so much for this Ted!
    | 1997 Estoril M3 - TURBO - |
    | GT35R | 8.5:1 forged internals | ARP stuffs | SS Oring Block w/ elring | Fully balanced & blueprinted 3.3L S52 | Nick G Tuning |
    | 46mm Precision gate| 62# injectors | Dual Walbro's |
    Goal: 600+ whp pump gas reliable 10 second car.
    -2007 335i Sport Package
