I have found the string of the headliner no longer attached to the roof frame and am looking for instructions on how to rethread it and secure it.
I have seen there is a TSB number 540399 that was issued about the string coming loose but have been unable to locate and electronic copy to see if it addresses how to reconnect and tension it.
Anybody have instructions or guidance?
Black shoe lace...
http://forums.bimmerforums.com/forum...ight=shoe+lace
Thanks, but I must be a little slow on the uptake. The string is in place in the headliner, but not attached to the frame in the front on the drivers side. Passenger side is up tight and hides how it is attached.
If the line is connected to a spring, which makes sense, how do I thread the line into the front point on the frame and how do I set the tension on the spring. Do I do this with the top down or up, my guess down so things are not loaded.
Again, appreciate any further information. I'd rather not break something by charging ahead incorrectly.
Is there an instruction manual for the installation of one of these headliners that would provide the information?
This is all I could find.
Buy new ones. They are fairly inexpensive, and easy to install.
Thanks again, I do not need to buy them, just figure out how to re-tie them at the front connection point.
I have previously seen the instruction provided, however, it does not address the line.
Wait, I was referring to the cable that is part of the convertible top. Ignore my comments.
Thanks to everyone. I have it figured out now and have ordered the correct part to fix this problem.
Shiphty, if you are still around, can you post your findings? I have the same problem and can't get it threaded through the little hole.
Does anyone know if this headliner will fit the early 1999 Z3 model. I guess the new retrofit number is 54318410992
flyhal@yahoo.com
Just lower the top and refer to the opposite side to see how it is threaded. It should be reattached while the top is down and the string has some slack. Easy.
