Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 123
Thread: 1972-1981 (E12) knowledge base
  1. #76
    Dec 2010
    Portland, ME
    1978 530i, 2005 X3 3.0
    Hey BmBoy91,
    I'm a 2002 boy with access to a sweet 78 530i. 84k one owner miles, always maintained and in excellent cosmetic condition. No rust anywhere. Besides the thermal reactor / cracked head issue, anything else i should be consered about? I really wasn't planning on an E12 for my next project but this seems like a cherry?
    thanks
  2. #77
    Nov 2014
    seacliff ny
    79 BMW 528i
    Hello guys i've currently ran into a rut with my 79 528i. Ive been having the problem where my car starts but doesn't want to stay on for more then 5 seconds. i thought this was the result of a battery and alternator so i replaced both along with a starter but the car still doesn't want to stay on longer than 5 seconds. i sprayed starter fluid in the throttle body to get it to stay on a little longer which led to the asumtion its a fuel problem. I pressure tested the fuel pump and that seems to be running in spec aswell. yet the car still wont stay on. the car is only getting enough gas to run off one cylinder which is causing it to put and misfire, the only thing else i could think of would be the multi purpose relay.. someone please help
  3. #78
    Nov 2011
    United States
    85 735i
    so i just bought a 1980 528i last week and i was driving it home the heat was on and it was hot so i turned the left dial from warm to i think past 0 ( it was dark) car started to blow cold air so i turned the dial back to about the 9o'clock spot and the air was still cold. so i moved it all the way back to warm and still no heat. crap loads of heat to no heat. did a gear or something in the climate control strip? also when i turn the dial to cold lots of air come out of the ducts but on warm air only comes from the defrost and floor. ideas?
  4. #79
    Dec 2014
    Japan
    1998 BMW M3 Coupe
    Cool!
  5. #80
    Nov 2009
    Newark, NJ, USA
    1974 Bavaria, 1978 530i
    cbruce, were you able to get this fixed. I am having kind of the same issue here but mine misfires randomly and just seems to starves for gas out of no were and run on 3 cylinders. If you did solve the issue or if anyone has any ideas.
  6. #81
    Nov 2009
    Newark, NJ, USA
    Guys just to give you an update on the Misfiring issue. I replaced all spark plugs, points, cap rotor, Cold start valve, and finally the Mass air flow sensor. Every time a part was changed the car would give better performance and the misfiring would be less now I am down to the car only misfiring when is cold it would take about 15min after start to stop Misfiring. Any ideas on what should I check?
  7. #82
    In the Darkness, where fear and knowing are one
    1987 Fiero GT
    Coolant temp sensor?
  8. #83
    Nov 2009
    Newark, NJ, USA
    DarkSideofWill, thank you so much for the suggestion, it ended up that the coolant temp sensor wire connector was broken and it was not making a good contact as you can see in the picture. I replaced the part and saw the improvement right away but I am still getting a rough start and in occasions mostly when it is cold out it would misfire until it warms up.
    Again replacing this part did make an improvement I am not getting the constant misfiring anymore.
    Again thank you so much DarkSideofWill, but do you have any ideas on where I should go next to find this stupid misfiring, by now it feels like I have replaced every single part.
    Thank you in advance.
    Also did a smoke test, a boot was cracked and it was replaced. Gas pump was also replaced.
  9. #84
    SF Bay Area
    '78 320i M42
    I'm having a really hard time finding anybody who owns an E12! I have some early E21 intake runners that are a great bolt-on upgrade for the M30. Selling a total of 8 runners (parted out two '78 M10s) for 80 bucks.
  10. #85
    Nov 2009
    Newark, NJ, USA
    Guys what fixed my misfiring was replacing the multipurpose relay. I also replaced the cold start relay and she is now acting as it should : )
  11. #86
    1987 Fiero GT
    I don't know much about early Bosch systems, other than their coolant temp sensors tend not to last, and time is hard on wiring.
  12. #87
    Golden, Colorado
    DD: 1986 535i; 1972 2002
    Lighting help offered
    Quote Originally Posted by jtk86 View Post
    Just picked up a 1980 M535 looking for a good vendor for parts any suggestions???
    Hey all,
    I am not an E12 owner, but have worked with several of these fine old fivers - largely to exterior lighting. Headlights, side markers, rear lights - the later style (shown) that's like the early E23 seven series.
    I am happy to help with lighting - safely, of course. I have been working with an Euro 1980 M535i, up in MN. It's got working rear fogs. and I have been improving it to add second tail and brake lights each side, plus keeping the working rear fog lights. Very much better than stock -- bigger, brighter, and more reliable, plus the nice rear fog light feature is preserved.
    Headlights too, naturally you want to see where you're going. I can suggest some nice options up there too, uning US sealed beam replacements that make fantasstic amounts of light, no threat to wiring or fuses or relays or switches, just make a better use of the power with new reflectrors, new lamps, and BOY do they light up the night!
    Anyway, get in touch with me by PM or email, I'll be glad to send pictures, talk about things I've done, see if any of this is something you'd like to discuss at greater length.
    I firmly believe you should "Be Seen, and Not Hurt" - and in seeing where you're going. Let's keep these cars on the road, and out of collisions. I salute my elders, and love the 'first five.'
    Hey, Sherman! Glad to be among your company here.
    "Be Seen, and Not Hurt"!
    Lighting Upgrades for 2002, E3, E9, E12, E21, E23, E24, E28, E30, E32, E36, E39
    Tail Light restoration and upgrades keep them off your tail
    Headlight protection film keeps lights intact and forward view clear
  13. #88
    Nov 2009
    Newark, NJ, USA
    Guys another issue that just came up.
    She was not starting after driving it for about 10min then I would let it cool down and it would start so I thought is was the starter so I replaced it but after I installed the new starter it is running really bad and making a loud noise. Check out the video I took on how is acting now. https://www.youtube.com/watch?v=ms3P...ature=youtu.be
    Any idea on what I mess up?
    By the way the issue with starting was not the starter I think it is the switch, I can jump the car by bypassing all the internal switches going direct to starter solenoid. That is something else I am trying to figure out how to take out the ignition switch. : (
    Help please..
  14. #89
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Here is a German language repair manual for the E12, for the older models the publisher now put them online free of charge, printed they are still available too
    Reparaturhandbuch von Etzold, So wird's gemacht Band 68,
    Reparaturanleitung für BMW 5er | So wird´s gemacht
    SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES
    http://twrite.org/shogunnew/topmenu.html
  15. #90
    Nov 2015
    chattanooga
    I've got a question for you. I've recently inherited a e3 74 Autotrans and was curious about using a 5 speed and M30 engine with fuel injection from a 5 series .My engine is pretty fresh. Which prompted me to consider swapping over the carbs for a "modern" fuel injection from an 86model 535i as well as the trans. Any suggestions?
  16. #91
    Nov 2015
    Washington
    1980 BMW 528
    I've got a question. So I just got a 1980 528, super clean, 114K total miles. It runs and drives, but it's got a horrible throttle jolt. You start in first and accelerate, jolts a bunch until you let off the throttle, same thing in 2nd. It's also got a lot of feedback and what feels like lack of power when driving too. No dummy lights, etc.
    Any ideas as to what could be causing this?
    I recently bought a super clean E12 528. It runs fine, temps are fine, has no dummy lights, has 114K on the clock, etc.
    There's a pretty brutal throttle jolt however. For example, if you put the car in first and start driving, the throttle starts jolting and the car itself starts jolting back and fourth, back and fourth until you ease off the throttle. Typically does the same thing if you go into 2nd gear at lower speeds.
    Any ideas what could be causing this? It's not the typical jerkiness you see with manuals, it's like the opposite, it gets less jerky when you let off the throttle.
    The car also has a lot of vibration and feedback when you start to hit speeds 35+.
  17. #92
    WA
    1975 530i 4 speed
    M90 powered e12, nice pics
    MSM 528 3.5
  18. #93
    Oct 2014
    clovis, NM
    2011 E90 335i
    How's it going everyone. I recently picked up a 1978 530i that wasn't running. after some spark plugs, new battery and new gas she has been running great. as of now I am working on overhauling all the rusted brake lines and getting the coolant system overhauled as its been sitting for 2+ years. the issue I'm having now is I believe I have an exhaust leak somewhere. I am looking to replace the entire exhaust system from exhaust manifold back. I would like to go with an aftermarket setup but cant really find much. anyone have any suggestions? the car will be on bags within the next 2 to 3 months so I imagine the exhaust will have to have some custom work done to it anyway. should I just take it to an exhaust shop and let them run some new pipes and find a muffler I like? my biggest issue right now is figuring out what to do about the OEM exhaust manifold. thanks for any and all help in advance!
  19. #94
    WA
    1975 530i 4 speed
    Quote Originally Posted by mybmer View Post
    This person here had a thread on the 1975 530i he was restoring. He put a tubular exhaust manifold and dumped the thermal reactors / pollution controls, shown on page 2, so a custom system done by an exhaust shop seems a good idea. I don't think the aftermarket has a compete kit for e12 530i.
    e12 restoration thread
  20. #95
    Jul 2016
    Secunda, ZA
    '99 Z3 2.8 Roadster
    New member here.
    I bought an E12/8 518i in January, and a while ago stumbled upon pictures of that very car on this thread (it used to be FoRmAtEEr's car). I don't have any new pictures that I can post right now, but basically it's the same as before but without the plastic around the rear number plate, the cover on the rear window (I keep forgetting what it's called), and injection (it's now a 32/34 Weber with a Simota cone filter). The radio was also gone, but I replaced it with a scrapyard Pioneer KEH-4020.
    I do have a question though, in case someone here can help. I noticed that after driving on an open road for about 30 minutes the car loses a significant part of its power, and so far I couldn't find the cause. The car still runs very well, it just loses power (think 3rd gear and floored on a slight hill at 100km/h before I swapped the small pancake filter for a cone). It does burn a bit of oil as shown in the attached video, but that doesn't seem too bad for such an old car.
  21. #96
    Sep 2016
    Redding California
    e30,e12,e9
    1980 528i
    So I recently picked up a e12 and I was getting ready to pull the valve cover to adjust the valves and I need up needing to move the car before I did the job so I put the afm and air box back on and now I'm at a no start situation I just sits and cranks ... SOS I need help I've gone though everything I've known to check
  22. #97
    Jul 2016
    Secunda, ZA
    '99 Z3 2.8 Roadster
    Welcome. It's good to see some activity here.
    I assume it's K-Jet? I'm not familiar with injection, but I know someone in a local club with a '82 323i Baur, so he might be able to give his opinion if I see him the weekend.
    On another note, I recently took my car for a dyno tune. It's now just under factory power if they adjusted for altitude, or significanlty above if they didn't. I'll have to wait and see if the car still loses power after driving for a while.
    EDIT: Also, be sure to post in the 5-series registry.
  23. #98
    Jul 2016
    Secunda, ZA
    '99 Z3 2.8 Roadster
    Quote Originally Posted by Colbyycate View Post
    Did you manage to get the car running again? I was at the club event I mentioned, but the person I would've asked wasn't there.
  24. #99
    Sep 2016
    Redding California
    e30,e12,e9
    Quote Originally Posted by JKuhn View Post
    Nope I think I'm just gonna take it to my mechanic here in Redding the reason I haven't taken it yet is because it's to low to get on our car trailer but at this point I've gone over it for a week now and still can't figure it out so I'm gonna try and get it fixed this week
  25. #100
    Jul 2016
    Secunda, ZA
    '99 Z3 2.8 Roadster
    Good luck then, I hope you get it back soon.
    It would also be nice to see some pictures, while you still have it. Speaking of which, my car is still almost the same as when FoRmAtEEr had it, but I'll also try to post some new pictures soon.
    By the way, in case someone with the relevant knowledge sees this, my car's been acting up a bit lately:
    As I (partially) said earlier, I took it for a dyno tune, and after that I had some issues, that seemingly were caused by oil fouled plugs. Now the car seems to have developed nasty deadspots, the RPM is overall slow to drop since the tune, and for some reason the engine cuts out every now and then (the car jerks as if I'm slamming the brakes, and then the engine is dead until I start it a couple seconds later). I also get the idea that it's not pulling like it did directly after the tune, but I can't say for sure. The things I've been told to replace, but haven't done yet, are the plugs (they were just cleaned), rotor and distributor cap. Any ideas?
