Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 122
Thread: 1972-1981 (E12) knowledge base
  1. #51
    Cypress, Tx
    See signature...
    A couple of thoughts:
    Your idle is low in pic number two.
    Rather than at 60 MPH but rather at 750 - 900 RPM
    does the oil pressure light go out and what does the gauge read?
    20W50 Valvoline VR1 non-synthetic is the oil you want to run.
    I'm not so sure I'd change the pump, but you are almost there, so...
    But, I for sure would make sure there is no sludge in the pan
    and that the oil pump pickup is clean and free of any crud.
    His disciple,
    Sherman, Sr.
    TexFest LSB&F IV... Oct. 12-13-14, 2012
    '79 528i - 1st 5er
    '86 535i - Snob (My DD)
    '88 ///M5 - The Beast
    '91 ///M5 - ///M-unization Donor
    '92 ///M5 - Her DD
    '95 525iT - ///M Donee
    BMW POWER bi-turbo
  2. #52
    Nov 2009
    Newark, NJ, USA
    1974 Bavaria, 1978 530i
    Again thank you Swatterssr for taking the time.
    Now, how do I adjust my idle and what should it be adjusted to?
    Does it matter that I already used a synthetic oil? (It was in the car for about 2 weeks only)
    I will check the oil pump pickup. Below is a picture of the current state of the oil pan. What do you think?
    One more thing, now that I have the pan out, would it be a good idea to change the pump or do these pumps are well made enough to last me for another 200k. The car currently has 160K.
    Just and FYI, does not look like the water pump from the 1988 528e (e28) will fit the 1978 530i (e12). I will post some pics of both. Not sure if the Fan Cluck will fit I will check and let you guys know.
  3. #53
    Cypress, Tx
    See signature...
    The how on the idle adjustment you'll have to search the firstfives.org archives.
    No biggie on the oil, but dump the synthetic and stay with the real deal.
    The pump should be good, but they do fail.
    Replacing it is a call you'll have to make.
    I'm guessing you didn't idle it at 750 - 900 and check the gauge and idiot light prior to pan removal.
    That suggestion was a step in diagnosing the pump's performance.
    No sure how to do that with it removed from the car.
    Water pumps from M20s are not interchangeable with M30s.
    The fan and clutch from an M20 is interchangeable with the E28 chassis M30.
    His disciple,
    Sherman, Sr.
    '79 528i - 1st 5er
    '92 ///M5 - Her DD
    BMW POWER bi-turbo
  4. #54
    Nov 2009
    Newark, NJ, USA
    Thank you one more time.
    I ended up changing the oil pan gasket,that was a job and a half... I had to remove the sub-frame and motor mounts. This was my first time and I am paying next time it needs to be done.
    Then I took your consideration and used 20W50 Valvoline VR1 Non synthetic she sounds beautiful and my oil pressure went up to about 8-10 bars when idling.
    Next I moved up to Change my water pump and thermostat (Not an easy job to figure... : ()
    To get to that last bolt on the passenger side was crazy aster trying to search online and thinking a lot, I could not find a way to get that one out...
    The I realized I had to take out the Radiator, then the fan and the bell bulley and that is how to get them out. Hope some one can benefit from this cus I was not able to find anything on how to remove a 1978 BMW 530i water pump.
    After a new pump and thermostat and of-course new fluids man... she runs nice!!!
    I think that happened that was kind of odd, my battery die so I charged it but when I try to crank her up nothing happen, I tried again and nothing it was only when I hit the starter with a hammer that she started up. It happened again today in the AM I had to hit the starter in other for her to start.
    She always started, WHY IS THIS HAPPENING NOW!!!
  5. #55
    Cypress, Tx
    See signature...
    Coincidence.
    Did you go back with the E12 pump and fan and clutch,
    or swap out to the E28 and later style spin on set up?
    His disciple,
    Sherman, Sr.
    '79 528i - 1st 5er
    '92 ///M5 - Her DD
    BMW POWER bi-turbo
  6. #56
    Nov 2009
    Newark, NJ, USA
    No I purchased a E12 Pump and a E28 Fan Clutch, that worked out fine.
    Now I just started realizing a very distinct ticking sound that is coming out of the valve cover. I am not sure if this is just how these engines should sound. I will take a video and upload it...
    My next move is replacing the power steering pump.
    My front shock are leaking, I would like to replace them but the setup I would like is a bit lower in the front and higher in the back. I was thinking on getting lowering springs for the front and normal ones for the back and installing Bilstein Sport Shocks, since they are stiffer. Right now I am running 17X10 in the back and 17X8.5 in the front and they touch the fender lip. What do you recommend?
  7. #57
    Cypress, Tx
    See signature...
    Adjust the valves.
    His disciple,
    Sherman, Sr.
    '79 528i - 1st 5er
    '92 ///M5 - Her DD
    BMW POWER bi-turbo
  8. #58
    Nov 2009
    Newark, NJ, USA
    Great thank you, Any where I can find how to do the procedure and the tools I need...
    Also today something happen were I to her up to 80mph on the highway and when I stopped at a stopped light the oil engine light came on and the car felt like it wanted to turn off, it happen two times but then I drove away and everything was fine. Any Idea. I was reading online that this may be that my bearings I hope not... : (
    Also the she is really spending spending a lot of gas.
    Please help!
  9. #59
    Nov 2009
    Newark, NJ, USA
    Looks like I am in need of a Cylinder Head Gasket replacement, I have some oil coming out all around the engine block... : (
    What does this mean the car only has 107miles on it and it is already leaking oil that is landing on the exhaust and burning it. I Looked around on the internet and everyone that has done a cylinder head gasket replacement also does a head resurface and refinishing I am not sure what this is so I am not sure if I could do the job my self. I certainly don't want to pay $2500 for the job...
    What would cause this to happen and what is the damage, I am driving the car to work everyday about 39k round trip should I not be driving it.
    I paid $6500 for the car, over all the car is perfect and beautiful. Did I just paid to much for this car?
    Thank you for any help you can provide
  10. #60
    Cypress, Tx
    See signature...
    You sure it's not the valve cover gasket?
    His disciple,
    Sherman, Sr.
    '79 528i - 1st 5er
    '92 ///M5 - Her DD
    BMW POWER bi-turbo
  11. #61
    Nov 2009
    Newark, NJ, USA
    I don't think so. I replaced the oil pan gasket thinking that that it was were it was leaking from but after power cleaning the engine I saw where it was coming out of. See the pic below.
    Is this bad? I got the car now 2 months, should I take it back to the dealer where I got it and fit it? Is this going to cost me an arm and a leg?
    Any help will be nice.
  12. #62
    Cypress, Tx
    See signature...
    I doubt it's a head gasket.
    More than likely a seal or connecting part gasket.
    His disciple,
    Sherman, Sr.
    '79 528i - 1st 5er
    '92 ///M5 - Her DD
    BMW POWER bi-turbo
  13. #63
    Sep 2014
    Ga
    1978 633csi
    Hey I have a 78 e24 which is based off the e12 platform and when it cold outside or the engine is just starting up its hesitant and runs rough like when u accelerate u have to like hit the gas pedal twice real quick to get it to accelerate but once it has warmed up it seems to run fine
  14. #64
    Cypress, Tx
    See signature...
    Quote Originally Posted by nicknjg88 View Post
    Do you have an idle air valve on the E24?
    His disciple,
    Sherman, Sr.
    '79 528i - 1st 5er
    '92 ///M5 - Her DD
    BMW POWER bi-turbo
  15. #65
    Sep 2014
    Ga
    1978 633csi
    I believe so its got 2 or 3 of them to my knowledge
  16. #66
    Sep 2014
    Ga
    1978 633csi
  17. #67
    Cypress, Tx
    See signature...
    I'd start there.
    His disciple,
    Sherman, Sr.
    '79 528i - 1st 5er
    '92 ///M5 - Her DD
    BMW POWER bi-turbo
  18. #68
    Sep 2014
    mr
    m3
    I've an '80 528i that over heated and now runs poorly. Where do I want to start in repairs? Is the head likely cracked?? The engine wasn't in great condition initially. Do I want to rebuild this one or look at switching engines?
  19. #69
    In the Darkness, where fear and knowing are one
    1987 Fiero GT
    -Compression test
    -Leak test cooling system
  20. #70
    Cypress, Tx
    See signature...
    M30B35 swap.
    His disciple,
    Sherman, Sr.
    '79 528i - 1st 5er
    '92 ///M5 - Her DD
    BMW POWER bi-turbo
  21. #71
    Oct 2014
    mr
    m3
    How much do E12's weigh?
  22. #72
    Cypress, Tx
    See signature...
    His disciple,
    Sherman, Sr.
    '79 528i - 1st 5er
    '92 ///M5 - Her DD
    BMW POWER bi-turbo
  23. #73
    Oct 2014
    mr
    m3
    Will they accept a BMW V8 without much modification?
  24. #74
    Oct 2014
    mr
    m3
    Any interior shots from any of you e12 guys???
  25. #75
    Oct 2014
    me
    m3
    Thanks. Yeah, the car had just been painted. If you look carefully you can see the windshield was set in temporary and the wipers not yet installed.
