how do you set dyno mode for an e46 m3 in DIS? basically to let the car to be ran on a dyno all the way to the rev limit.. i have read that its under "service functions" but i cant seem to find it
It might be somewhere in the settings for the DSC module... check out the mk60 in INPA, might be easier to find.
OPEY, answered in post 9 on the thread over at m3furms
thanks
For future references ... thanks to fnc1
DIS:
To Dyno the Car:
under DMS > Test plan > Service Functions > 12. Dyno/Rolling Road function.
Don't even waste your time with DIS, this worked like a charm on mine even when DIS failed, read post 14 and on:
http://www.m3forum.net/m3forum/showthread.php?t=312710
With all due respect, maybe it's a 3 series thing, but that guy is a pompous @$$.
yeah, that's when I peaced out.
Screen shots for those that can't find it:
First "Function Selection"
Then click "Test Schedule":
next the right arrow
and you'll see this screen
click the right arrow again and it'll bring you here click on "service functions"
Voila item 12 "Operation on roller dynamometer
Click "continue" and then hold the DSC button down for 10 seconds
my next question is.. how long does it stay in dyno mode? does DIS have to stay connected? is it until u turn off the ignition? can i set it at home before i go to the dyno?
It stays in Dyno mode until you turn the car off - once on the DSC light disappears and you can't turn it back on by pushing the button. Once you turn the car off and back on it goes back to normal, but it'll register a 'fault code' within DSC which you should clear with DIS.
