So it begins.
95 turbo 330ti. 01 maxpsi m3 e85. 01 m5. 01 m coupe. 03 AIM 996t e85. 06 x3 w/Meyers plow and winter daily. Prussian Motors is hiring!! prussianmotors.com/jobs
Current e39t LS Turbo swap: https://www.bimmerforums.com/forum/s...LS-e39-Touring
in for the begining
yes!
Is it just me or does the car look like its set crooked on the lift?
And sorry to hear about the whole motor thing, but now you get to go big!
can't wait to see this one
Nice Bob! What's in store for #4?
Go ahead and bite. Plenty for everyone.
Nice Bob! I'll hurry with the torque plate so you can use it
Cool bob. Interested to see what you do from here
Yup, I guess this counts as build 4.
1 purchase not running, get it running with bunch of new parts.
2 re use/re seal head gasket
3 new block/new head gasket/ARP2000's
4 forged pistons/stock head gasket/ARP2000's
Yup, it's crooked on the lift. I bent one of the arms with my fork lift while getting ride of a scrap BMW.
Roman, you're getting it? I totally told Jay to hold off. I'm going to have this thing on the road in two weeks!! Race ya.
Jon, I should probably listen to Cam: Put another stock block in; race gas; no wastegate. Videos.
Frankenstien. DO EET!
85' Turbo M50 E30 | 95' M3 Nitrous, Coilovers, DJ Autos, UUC SSK
lol Bob you better have it done quickly.. I've been waiting on the torque plate for 29 days.
dude i like how you are making quick work of this..
more updates later tonight for sure
Again sorry dude!! I can't wait for your new motor though! We'll have to meet up sometime and have a run or two! Maybe i'll drive to New Jersey and get tuned up at Maxpsi.
Good Luck bro!
373 whp at 11psi e85 "winter blend" - Dyno Dynamics
15psi now stock headgasket ~430+ whp - Butt Dyno
bob maybe you can get your manifold coated while its all apart?
Sucks about the lift arm, good luck with the build, you seem to work super quick.
ah yes, the ol community torque plate thats been used on so many high profile builds.lol This build is garunteed to be a success with jays magic torque plate.
1005whp/831wtq little bit of low boost pump gas magic...
hehe we infused the plate with magic
and bbq sauce
A little bit of piston melt-ageingness.
There was some scoring on the cylinder walls and ring land damage. Some of the rings in a couple pistons were also melted. Ready for the machine shop. Wisecos should be her by end of week, via Maximumpsi.
Jay stopped by for support, guidance, mentoring, lending of hand, etc etc.. Then we went out looking for trouble.
Damn - kind of what I suspected. Jay described the condish and I thought ringlands - but what sucks is that it was @ 12 psi or so with safe timing and AFRs according to all data.
Might want to get the injectors flowed and calibrate the wideband!
flowing the injectors would be a good idea..
hope i'm not stealing bobs thunder, but he ordered up a VEMS wideband / egt unit tonight.. this will help cross check his autronic wideband and add egt to the mix.
this build is going to be solid!
too bad we drove all the way down to philly (logan circle) and back and found nobody that wanted to make pulls. oh well.. we did play around with the traction control a bit and tried making some launches with & without.. pretty crazy how different it is!
Does New Sweden have that technology? (flow the injectors)
Maybe my fuel pump is not up to snuff? I figure that would be seen in the AFRs though, right?
I'm down for whatever, within reason. This car needs to run right for once.
We has the technology.
We can just put the fuel rail over some cupz and crank with the FP jumpered and constant voltage source. Pull the logs during cranking and see the PW, and determine Duty Cycle, and thus flow rate. Or, simply compare one injector to the next while cranking.
I think you definitely want to confirm the timing and fuel before putting the new motor in fo' sho'.
