Evidence that raising the jack to high on one side is not good for you and the car.
I love ramps also, and the pic above is a great example of what you can make at home. I love my plastic ramps from Walmart that hold something like 12k pounds. I know they easily hold my Excursion.
Please stick to the standard jack pads, rear diff, front subframe, or rear subframe. Do not try jacking on the rocker panel or the unibody even though it looks like a frame. It will cave in.
"If everything seems under control, you're not going fast enough. - Mario Andretti"
there is also a jack point on the engine subframe where it crosses under the engine.
>'97 528i, 200000 miles, Hella Xenons, 17" Stilauto wheels, Vogtland Drop Springs, Dynomax Race Muffler, Homelink, 540 brake upgrade, 15mm spacers >'65 & '74 MG Midgets BFC OT Lego Club #48 Manual conversion in process!!!
The I6 cars do have a rubber thing on the front subframe to lift from. I dont recall seeing one on the 540i cars though. Maybe I just never looked for it.
Yeps!
My measly 525i has that center rubber jack point on the center of the front subframe.
Let find some pictures.
Please note that if your car is significantly lower, it will be VERY hard to find a jack to reach far enough to that front center jack point.
Yeps!
I also have the plastic Walmart ramps too.
However, I am only able to use them on the rear (backing up onto the ramps) since my car is so low, the car pushes the ramps out of the way when trying to drive forward onto the ramps.
Also, I think the plastic ramps I have are a little flimsy, and will fold a little at the high point of the ramp.
http://www.bimmerfest.com/forums/sho...d.php?t=341672
Bluebee's:
http://webcache.googleusercontent.co...ient=firefox-a
Last edited by Jason5driver; 06-04-2010 at 01:18 PM. Reason: Automerged Doublepost
e39 540:
Is that an e28 rolled over in the 2nd pic?
where does one jack the rear of an e39? Safe on the diff housing? Or forward of the diff on the chassis? Thanks.
If you're not comfortable under the diff with a piece of wood between the jack and the diff, then you can jack up the same way under the swing arms - do one side at a time and then place your jack stands in the usual place.
Or you can jack up using the jack point on the rocker panel, and then place the jack stand using part of the sub-frame.
gmak: The Good, the Bad, and the Ugly. A journey with my new-to-me 2000 540i
"Working on a BMW E39 is the best way to run out of time."
I was frustrated with the '03 because the trick of lifting at the front jack point until the rear is off the ground, didn't work! It worked for the '00 Sport but NOT the M-sport. After seeing this post from Q, I decided it was safe and as you can guess, it worked like a charm. Maybe one shouldn't do it too often but doing it occasionally appears to be safe enough...
Someone mentioned that it could potentially damage the subframe or diff bushings but so far, everything is golden.
'00 540iA Sport w/235k+ Original TCG's, Vanos and transmission.*Trans failure at 244k+...FS Now
Peel back the plastic that covers fuel filter, and the other side which covers brake lines.
Once this is done. The frame will be exposed. Put the jack stands under the frame evenly. And make sure all of the legs on the jack stands are touching the floor.
Yeah, aside from the main jacking points you have to go past the fuel lines and the brake lines to the frame which is safe to jack the car up. However, you want to use a block of wood for a larger contact area for a wide spread support on the frame to jack it up; otherwise, there is a possibility of pinching it first with just using a hydraulic jack and then pushing it up into the cabin's floor.
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
From my thread:
https://www.bimmerforums.com/forum/s...l-on-an-E39-I6
Rear/ hiney is in the air/ jacked up:
Thanks a bunch guys/gals! I was going to jack it up via the diff housing or by each rear subframe bushing (smaller not as convenient area). To replace the oil pan gasket, in addition to dropping the front subframe, should I also disconnect tie rods and rods going to the steering knuckle? Or is there enough clearance just by dropping the subframe?
IIIRC, read somewhere (or was it an E39soure video?) that you don't even need to remove the subframe bolts completely - that you undo the front ones on each side almost to coming out, then the middle ones a little less, and finally the back ones only as much as needed. This apparently gives clearance for the oil pan to come out.
ok good to know thanks! Have lots of tools. Just need to block off time to tackle this. In e36-land suspension bushings/ball joints need to be replaced every 80-100k or so. What's the service interval on the e39s? m52 auto at 99k miles.
If it ain't broke, don't fix it. You can always put the front on ramps and go under to look for leaky bushings - use a pry bar to see how much movement. Same pry bar for the ball joints. If you have a vibration in the steering wheel at arout 70 mph, then it's the thrust arm bushings. Wheel shimmy could be control arm or tie rod ends. Clunking.... get under the car and look (rinse and repeat).
No need to remove the tie rods.
Did you look at these threads?:
https://www.bimmerforums.com/forum/s...nt-illustrated
https://www.bimmerforums.com/forum/s...mies-2002-530i
And this on YouTube by "the 50's Kid":
https://www.youtube.com/watch?v=R1c2wfo4-jw
Thanks! I'm in the middle of this... how many of you removed:
brake calipers
abs sensor connectors from plastic housings
steering rack from subframe
struts from strut towers
I've been reading various DIY instructions, and there is no consensus. I have a bentley manual, but it doesn't mention any of these items. Another DIY mentions disconnecting the control arms and thrust arms (no need to mess with brake calipers or struts). I think this method makes the most sense...Thoughts?
I'm at a point where I can unbolt the rack and unbolt the subrame to drop it. Thanks again!
Follow the threads I linked above.
Especially "Texas530i".
Yeah that is one of the DIYs I'm following. I have to decide if I'm going to disconnect the thrust and control arms or lower the struts and remove the brake parts.... I think disconnecting the arms would be easier...
