OK here we go!
First off tnx to Pavel for the push to just do it!
The projector lens
Old vs NEW
Take the headlight out of the car (see E38.org)
Remove the weather strip
Flip over and undo the 3 T20 screws
Slide out
Use a screwdriver to remove the clips
Remove the cover of the xenon
Back view
Use a screwdriver to pry both headlight adjusters off
Remove the headlight cover
Remove the screw in the corner
Remove cover and you see this
Use a pair of pliers to pinch the center so it pops (headlight adjuster)
Unplug the highbeam
Remove the ground wire
Remove the tabs (front and rear) yo remove the center piece
Now you see the back screws
Not sure what you call these (inverted torx?)
Undo all 3
Have a technical question, don't send me a PM but post it on the board so others can benefit from it!
Pull the lens straight out
Empty housing
The major difference in lens size!
But just as long!
Only one is marked RIGHT!
Nice and full!
When test fitting you can encounter the motor to hit the housing
I removed a little
The holes in the lens
The screw size
Drilled the holes a little bigger
Nice a tight fit!
Made them a little bigger for better adjustment
Align it correct!!!
Headlight without cover
With cover
The cover does not fit so we need to grind a little to make room
After I'm done
Nice and tight and does not touch
In place
Reconnect the ground wire
Gently slide it back in!!!
My projector was hitting the inside of the housing
So removed a little extra metal
Installed
Solder the wires (extend them)
And connect them to the brown (ground wire) and the white from the high beam light
But it back together and install in the car!
Here a new and old headlight!
New
Old
All done
And the AWESOME video
[ame]http://www.youtube.com/watch?v=WGadPVW3UWk[/ame]
And a Night video with both lenses in place
[ame]http://www.youtube.com/watch?v=lyP1rHoHnN0[/ame]
