just purchased an 02' 525i and have a set of 19inch HREs sitting in the garage...need to know specs for nice wheel fitment on the e39s so i can have an idea on what to do as far as re-spec my wheels. thanks
They are advising me to run 19x9 et24 and 19x10 et23. let me know what you guys think
A tasteful sight
who is advising you to run those specs ? HRE ??
Could you tell us the current specs and your wheels ?? Also, do you want to run the lowest offset possible for a more flush look or are you more concerned on running the widest rubber possible ... do you already have tires for these HRE ?? Are you planing on doing a moderate drop or slamming it ???
These are important things to know before deciding on offsets and things like that... congrats on the new car!!
btw, I love HREs ... which model do you have ?? I have 19" 540Rs myself (not on the e39 though)
2001 BMW 540i E39
Lots of mods and more to come...
under construcion... http://forums.bimmerforums.com/forum....php?t=1204241
The wheels need to have a 74.1mm center bore.
the lower the offset, the better.
HRE is recommending the 19x9 and 19x10 setup...they currently are 19x8 et37 19x9 et45 for e36s...i want it to be almost flush but not where i have to run a stretch tire to make it fit with coilovers (moderate drop). Ill leave the stretch to the M3, just trying to make this e39 a clean DD. probably run a 245 up front and 265/275 on rear. thanks
i love the questions....but lets see some e39s with great fitment please
Last edited by slammedm3sedan; 12-08-2009 at 11:41 PM. Reason: Automerged Doublepost
A tasteful sight
Man they dont know what theyre talking about then... theyre giving you E36 offsets!!!!!!!!!!
19x8.5 et15, 245/35/19
19x9.5 et20, 275/30/19
no drop..could definitely use one though, especially in front.
1999 540i | Dinan 5 | SuperSprint Exhaust | Sports Package
see sig
come on guys...read the first post (that is what HRE recommends). the 19x8 and 19x9 setup is what is the original setup was for my e36, i was just answering the question i was quoting. lets get real here, knock off LMs...come on now read the first post 19x9 and 19x10 setup and give suggestions. thanks
cant get info from sig...but the wagon is sick and that is exactly what im looking for....wheel spec and offsets. wicked Wagon!
Last edited by slammedm3sedan; 12-08-2009 at 11:23 PM. Reason: Automerged Doublepost
A tasteful sight
If HRE is recommending you use mid 20's offset's for 8J and 9J, I'd call another company. That's definitely NOT the right offset for e39's. Actually, I'd choose any other wheel brand over HRE. Their like expensive rota's. My 9.5's have ET 21 and my 8.5's have ET 15. And that's with a concave face.
Last edited by slammedm3sedan; 12-08-2009 at 11:39 PM. Reason: Automerged Doublepost
A tasteful sight
actually im being rational...im sending them off to HRE and they are replacing both rear inner barrels and lips and using the existing 2" lips for the fronts. 2" lips up front and 3.5" lips on rear. I just need ppl to read before they write wtf! and thats horrible offset, etc...u feel me? if they read in the first place, they would post pics up of their car with wheel specs and tire sizes...right? let me know if im wrong
but good one on the buying aspect of new wheels...wouldnt you just use the wheels in your garage to put on an extra car...would you not ask HRE for advice? and get them to rebuild them? just asking
Last edited by slammedm3sedan; 12-08-2009 at 11:49 PM. Reason: Automerged Doublepost
A tasteful sight
Just a thought, maybe sell your existing HRE wheels and then get another set made specifically for the E39. I think it's still going to cost quite a bit to have HRE modify your existing wheels
But, if you're set on having HRE "re-spec" the wheels....
1. Wheel hub bore needs to be the E39 specific 74.1mm (almost all other Bimmers have a 72.6mm hub)
2. For 19x9 fronts, generally you can run offsets ranging from +13mm to +20mm. Typical tire size would be 245/35-19. In my setup, my front wheels are 19x9 with +15mm offset, 245/35 tire and car is lowered on KW V2 coilovers. Sorry, i don't know exactly how much it has been lowered
3. For 19x10 rears, generally you can run offsets ranging from +22mm to +27mm. Typical tire size is 275/30, although some with lowered suspensions and maybe also running offsets closer to +20mm end go with a 265/30 tire size to avoid rubbing with the fender lip.
My setup is 19x10 w/ +22mm offset and 275/30 tires. I installed M5 wheel liners as an ultra-precaution (maybe did not need), and also needed to roll my fender lips due to rubbing only in certain driving and load conditions.
Aftermarket lowering (especially with coilovers) brings a lot of variables into play with fitment as you are obviously cutting things closer clearance-wise with the fender lip and maybe even the wheel liner. At this point, things like tire brand and model could possibly make differences in clearances as some tire brands run wider than others in the same size. Also tire shoulder shape (rounded vs. squarish) can make a difference.
Hope this helps.... best of luck with whatever you choose to do
2008 Lexus LS460
2016 Lexus NX200t
PUREVIP
Island Elites - West Coast Elites
Team Airrex
ClubLexusHawaii
2002 540iA Sport (SOLD)
1998 M3/4 (SOLD)
2001 BMW 540i E39
