I have a 2001 330ci (E46) that is approaching 90K miles. It has just started to missfire at times; mostly at idel. I have taken it to the BMW dealer 2 times and they can't seem to find the problem. They cleard the missfire codes and recommended that we change the plugs at a cost of $300. This sounds high to me. I thought of installing a set of Bosh Platnum plus 4's. Any one have a suggestion?
I would like to hear any thought on installing a set of performance coil packs.
Any grease monkey can change plugs... 300 seems high.
Platinum 4's are junk. If you want a performance plug get iridium with a single ground strap. With 4 straps the spark will just take the path of least resistance resulting in a weaker spark. The purpose of 4 is to make the plug last longer. Most of the guys that actually fiddle with ignition run really cheap plugs so they can play with the gap and just change them more often.
Stock coils work fine. You will see no improvement with performance coils over a properly running vehicle with OE coils.
I like small engines, so what!
Get a Stanley tool kit for 50 bucks and change the plugs yourself?
Yea 300 is high, they maybe figured in some expense incase they break something on accident?
It's already probably got performance packs...
You can do it! Robert
Tbd
Hey guys I have a 2001 bmw 330ci and I was looking at the coil packs and I can't tell which ones are the originals and which have been replaced. I guess my question mainly is, what did the original coil packs look like?
Lazy Saturday drive in my E34: https://www.youtube.com/watch?v=TnzvZgPnOos
Thank you SpeedsterBek I figured it out
