Running Koni Single adjustables with M3 sways and HR race springs
Washedit1 by thedude60526, on Flickr11/10's Racing
94 325i #36/64 TEAM PENISTON OILS/ LARSENS BISCUITS
put a new cylinder head in mine..new MLS head gasket...new head bolts, new thermostate...new thermo housing...new water pump...new fan clutch...odd tho...ive done this kinda thing on it before...never had the problem im having now....car runs good...everything's as it should be...except im getting this load clacking noise that seems to be emminating from the head...any ideas?
Well, it has been a long time since I was here, let me show you why.
This is the last thing that I did to my E36, and also, the last thing that I will ever do to it...
Three flips end over end, Engine up against firewall, right front wheel/strut completely separated, 6 weeks in hospital, yadda yadda...
I assume the car has been melted down and turned into a blue Prius by now....
1998 318i : RIP
M44 Club Member #54
I changed the front shocks. I also pulled off a piece of plastic that was covering something on the underside of the car. I have no idea what it is that was covered, but the plastic was hanging down, so it was not doing its job anyway...
The protected part was cylindrical...
//Mike (Norway)
1997 316i hybrid
^ Thats funny. I just installed a rollbar on the e36, and while underneath, I too removed that pc of plastic that was hanging and not covering anything in particular........I also installed smoked side/corner markers, and I am cutting the diffuser to fit around my big ass exhaust.
Die Perfekte Verbindung Aus Sportlichkeit und Asthetik
I got stuck inside, because the drivers door became stuck closed....
I'm assuming the lock actuator is broken?
Sent it to the fixers
Just changed the steering wheel cover ... Ha ha..
Slip Kid,
I'm glad you lived to tell about it. Cars can be replaced.
Just got em back from the powercoaters. Good God they are 17lbs apc.
Put her in a car show today, only other roundel was on a bike, so yesterday I cleaned and polished. Thursday I replaced the left side projector lens and realized when I opened the hood that one hood strut was shot. Off to E-bay, they'll be here thursday.
air horn sounds like a future mod for this guy!!!!
bought parts to finish putting my front bumper and grille panel on!
filled her up so i can take it to get wet sanded and buffed in the morning!!
SPEED NEVER KILLED ANYONE! ITS THE ABRUPT STOP THAT GETS U!
93 325i sedan
I dont necessarily look for the hardest way to do things im just poor and thats the cheapest way to my goals
There are people out there that take those classes and graduate college to come up with a design that completely fool proof but they never took in count the inginuity of complete fools!
LIFE WITHOUT LIMITS
i have bad TASTE, weaves SUCK
moved it like 2 feet..it was parked under this stupid bird nest in my house..my hood was a poop deck..
Marco
god this thread is getting old
added 3qts of oil & stop-leak
installed all new bushings in rear!
new rear camber arms
painted diff
added royal purple
painted rear subframe
93 325i sedan
LIFE WITHOUT LIMITS
yesterday i washed and waxed her...then i had to break into her b/c i locked my keys in there...
-ducky
Put my new sunroof in! Now I can finally use the tilt again!
i'm not sure if its an AT feature or what, but on my car, when i turn the key to acc the doors lock automatically. i was messing with some stuff, and i turned the key on and inadvertently shut the door behind myself...as soon as i heard it shut i stopped dead in my tracks...and cursed myself its all good now though...just know that i can break into any e36 sedan (framed door windows) with a flat head screw driver and a wire hanger
-ducky
ducky, you card
As per my usual habit, I yelled at my car after I couldn't get the starter in today. It's a total bitch to get, and it doesn't help that the intake manifold is on the motor. (really don't want to take it off)
But in a few days when my fuel injectors get back from being serviced I should have it in and the front end re-constructed.
I might actually have a running car, finally!
1997 BMW 328is Alpine White // Dove Grey
ZF Swapped | 3.23 LSD | FK Coilovers | 17x8.5 Borbet Type C | 75mm Wheel Studs | 12mm Vorshlag Spacers | 5000k HIDs | Euro Taillights | Suede Headliner/Pillars
