FS: Eclipse CD8053 HU, Rare deck, 16V balanced outputs, PEQ, Active Xover, etc.
Really don't want to get rid of this, but I have a new deck for iPod compatibility, so this one needs to go. If you're on this page, you probably already know a lot about this deck. It is a pre-amp only, you need a separate amplifier. It contains balanced 16V outputs for use with a balanced amp or the converter (not included). Otherwise there are 8V preouts. It has an advanced PEQ and active crossover as well as time alignment for a wide variety of setups. It's in excellent shape, and I don't remember it ever skipping a CD. It will come with the knob remote (not cheap), trim ring, cage (used, but they can be re-used plenty of times), harness, and manual. These decks are still used in SQ competitions, and you'll understand why when you turn it on.
Here is a standard feature list:
Features
* Eclipse car audio CD8053 key features
* Balanced outputs
* High voltage 16V/8V and low impedance outputs
* All digital circuitry
* STAR DSP (newly designed Digital Signal Processor)
* 24-bit advanced multi-bit Digital-to-Analog Converter
* CD-R/CD-RW compatibility
* MP3 playback using optional ECLIPSE Commander Advance
* Full dot VF display
* Power tilting front panel
* Digital input
* Auxiliary input
* Eclipse car audio CD8053 power output
* High voltage 16V/8V Balanced Line Pre-Amp Only
* Eclipse car audio CD8053 CD features
* CD-R/RW Compatible
* ECLIPSE Memory Buffer
* CD Text
* CD Name Preset
* Track Scan
* Track Up/Down
* Fast Up/Down
* Repeat
* Random Play
* Eclipse car audio CD8053 tuner features
* PLL Frequency Synthesized Electric Tuner
* ECLIPSE STARTUNER V
* 24 Station Presets (18FM/6AM)
* Preset Scan
* Auto Station Memory (ASM)
* UP/Down Auto Seek
* One-Touch Station Memory
* Auto Local/Distant Seek Sensitivity
* Eclipse car audio CD8053 audio features
* Independent Bass/Mid/Treble Memory for each Source
* Balance Control
* Fader & Pre-Amp Fader Control
* Loudness
* Mute
* 6 Pairs of RCA Pre-Amp Outputs
The unit was working perfectly when I removed it and has been only sitting in the box since then. Before the sale I'll verify that ESN is turned off for you.
$225 obo.
M50 * Bilstein PSS9 * UUC Sway's * PFlex LCABs/RTABs * TMS Delrin/Alum Diff Bushings * X-Brace * Stoptech SS Brake lines * CDV delete * DEPO with 55W 5000K HID's * 35W 5000K HID fogs
Stock dyno: 201.7rwhp SAE corrected
