Have you unlocked your OBC? If so, you can do TEST #9 (WITH the engine running) and you can see how the system (alternator) is charging while you're driving around. It should stay somewhere above 13.6 volts (it may move around but should consistently be above 13.6v).
When the ignition is in POSITION 1 or 2 and the engine is NOT running...you will get a reading of the battery's health..and it should consistently read between 12.1v-12.8v.
To unlock your OBC is VERY easy...and once it's unlocked...it only takes a few seconds to run a TEST or you could leave the TEST running the whole time your driving around.
Every week I invariably suggest to someone to UNLOCK their OBC...I'm not sure if many do because they have to search for the instructions. Well, just in case someone doesn't feel like searching...below are the instructions on how to UNLOCK the OBC if you have the HIGH CLUSTER (the instrument cluster with the 20 digit alpha/numeric display). To unlock the LOW CLUSTER...go to www.bmwtips.com ...there are instructions there on how to unlock the low cluster which only has one button (on the left side) of the instrument cluster.
INSTRUCTIONS ON HOW TO UNLOCK THE OBC (on the high instrument cluster)
Here is the procedure to
unlock the system to get access to all 21 tests: (you're basically adding up the last 5 digits of your car's VIN...then you go to TEST #19 and enter the sum/value of whatever number you just came up with )
- Turn ignition to position 1 (position II can be used but the FASTEN YOUR SEATBELT warning stays on and won't relinquish the display until you buckle up )
- Push right button in the instrument cluster and keep it pushed. You will first see "Check Control OK", some seconds later you will see "Test Nr.01"
- Push the left button on the instrument cluster to see the car's identification number. Add the 5 digits together and write down that number, you will need it for unlocking all the functions. Example: DG23278 will lead to 2+3+2+7+8 = 22
- Push the right button until you see "Test Nr.19"
- Push left button until you see the number that is equal to the one you calculated above
- Push right button again
Now you will have unrestricted access to Test No.3-21. If you made an error in the procedure mentioned above, Test No.3-21 will only display Lock:ON
List of TESTS:- Display Car's identification number, HW/SW version, construction date
- Instrument cluster test...lights & gauges
- Current consumption (liters/hour)
- Average consumption (liters/100 km)
- Current range
- I think this is remaining fuel in tank. Three sets of numbers: A/B/C. And I've noticed A+B=C.
- Engine RPM / Coolant Temp (C)
- Current Speed (kph)
- System voltage at Term. "R" (Battery Voltage with engine NOT running || Alternator w/engine running)
- Country/Language (US, Spa, Ger, Jap, etc.)
- Units am/pm
- Average Speed
- GONG/Chime Sounds
- Date of Software Mask
- Production Diagnosis
- Oel Temp (oil temp...but nothing will display)
- Display Vehicle Specific Data
- Alarm Changeover (cont. vs. intermittent OBC chime)
- Lock/Unlock
- Correction factor for fuel consumption (nicht ändern!)
- Reset all defect codes
This is what appears in the display:
- Several numbers and data
- [Dispay Test]
- VBR: x,x (liters/hr)
- RW-VBR: x,x (liters/100 km)
- RW: x (km)
- T: (liters)
- TMTL: x,x (liters) / KTMP C
- V: x (kph)
- UB: xx,xx (V)
- LAND: 2=USA, 3=I, 4=E, 5=J, 6=F, 7=CDN, 8=AUS/GOLF, 0=D, 1=GB
- EINHEIT 1: B3, B4, B5, B6, B7, B8, B9, BA, BB, BC, BD, BE, BF, B0, B1 EINHEIT 2: [similar to above, I didn't want to mess with it]
- VANK: xx,x (kph)
- GONG
- ROM:
- DIAG: 01 01 000 E3
- OEL TEMP (only words appear, the actual oil temp won't display)
- PROM: 00 12, 01 37, 02 18, 03 E6, 04 02, 05 B3, 06 FF, 07 7E
- HORN: DTON or [DTON flashing]
- LOCK: ON
- KVBR: 1000
- RESET
The video below shows how easy & quick it is to do any of the TESTs once you've unlocked the OBC. The video below shows the owner doing TEST #2...after inserting the key into the ignition...you see him press the RIGHT instr cluster button until TEST 01 appears...then he presses the RIGHT button again to go to TEST #2...the presses the LEFT button to initiate the TEST:
[ame]http://ie.youtube.com/watch?v=89hf_vQfyGE[/ame]
